Author Topic: Makvision 29" CRT in MK4 cabinet  (Read 1552 times)
Pixeljunkie
  • Last login:August 03, 2023, 03:38:20 pm
« on: August 18, 2014, 09:06:39 am »
Hi everyone
First of all i'd like to introduce myself a bit since i'm new here.
I'm from Belgium and i've been into arcades ever since I was 12y old, my first games being MK1,2,3 and Streetfighter :)
I have already restored and converted a War Gods cabinet into an MK2 cab, of which you can find a clip here :
I recently bought a decent MK4 cabinet that I would like to convert to a Killer Instinct or MK3 cab. As part of the restoration, I bought a brand spanking new Makvision 29" Tri-mode arcade monitor, but that's where the problems begin. I know that this cab is originally a 25" cab, but I found a thread on another forum where a guy was able to fit a 29" into his MK4 cab : http://forums.arcade-museum.com/showthread.php?t=285360
Thing is, something has gone wrong in translation (inch to cm's) because I just can't seem to align the brackets so that the monitor fits properly..has anyone here tried the same or does somebody have the right measurements for me ?
Re: Makvision 29" CRT in MK4 cabinet
« Reply #1 on: August 18, 2014, 09:58:34 am »
When I mounted a 27" medium res monitor into an MK4 cab, I had to drill new holes in the monitor frame bracket and drill new holes in the top cabinet brackets. I basically drilled 2 holes as far down as I could, then slid the existing bolts from the side of the cab into them. Then I put 2 lath screws into the existing hole for just a bit of extra support.
Its tough to see the bolt holes in the monitor , but this is the only picture I kept.  I couldnt get a picture on the tube due to a chassis problem, so I pulled the CRT and put an LCD in there instead.
Pixeljunkie
« Reply #2 on: August 18, 2014, 10:14:47 am »
Thanks for the reply Malenko. I drilled new holes in the existing brackets, but the (additional) problem I have is that the provided monitor bezel is too short on top, so it's kinda hard to install the monitor without a proper bezel to align it to :(
I need the same bezel but un-trimmed
