Author Topic: Help on Cruis'n World Cab WGU5000, need new monitor/board  (Read 5333 times)
blubberpud
  • Last login:May 15, 2021, 10:04:04 am
« on: August 12, 2014, 08:20:18 pm »
Hey,
I have a Cruis'n World Cab, with a Wells Garner U5000 25" chassis.  The board is blown and I need some ideas of what I can do to fix / replace it??
Is it worth trying to fix the board?
Replace with a new/used chassis? What can I use?
Replace with LCD?  What can I use?
Thanks in advance,
Jay
« Last Edit: August 19, 2014, 10:53:27 am by blubberpud »
crtrrss
blubberpud
Re: Help on Cruis'n World Cab WGU5000, need new monitor/board
« Reply #2 on: August 13, 2014, 08:44:01 am »
Thx for the reply.
This board has had a cap kit done on it sometime in it's life, the issue that i'm seeing...well is nothing, no video, but a steady tick..tick..tick...etc... from the board on power up, the rest of the cabinet seems to work fine.
Sarver Systems
  • Last login:October 07, 2020, 12:46:05 am
« Reply #3 on: August 13, 2014, 12:06:53 pm »
Did you replace the flyback?
THat boards looks pristine to me. I wouldnt throw it away in a million years, unless you see obvious signs of burning, or tons of lifted traces.
Can you take a pic of the back of the board?
blubberpud
« Reply #4 on: August 13, 2014, 10:18:25 pm »
I re-flowed any connections that looked like they could be a problem, cold joint etc...  still no joy.
Found the service manual :
"In the event of excessive current demand from the main B+ rail, the switcher is designed to shut-down its output............blah blah blah.......Periodically, the switcher attempts to restart.  If the fault persists, it will once again shut itself down.  This condition can be heard as a faint "ticking" within the switching supply."
Sounds like the issue, but what could cause "excessive current demand on the B+ rail"??
Also another "U5000 Troubleshooting Guide"
SYMPTOM: NO PICTURE/ VIDEO COMMENT: TICKING SOUND CAUSE: IC U500, Q501,C116, ICU101, CRT
These components are all on the neck-board, could a one of these bad components be the issue??
ed12
« Reply #5 on: August 13, 2014, 11:01:53 pm »
that board from what i can see has had 1 of the  >3< service kit's put in it >vertictial<..
what u might want to look at >IS< the vert ic,it will pull down the b+ to tick tick stage..
in our monitor fourm's u find a boat load of info on these..inculding a bad
diode/resistor combo on the lower b+ side..22volt to 12volt
go look there before giving up..that board just look's to good
ed
MK3FAN
« Reply #6 on: August 14, 2014, 12:02:24 am »
The "tick tick tick" is also an indication of a blown horizontal output transistor. Replace the HOT and I bet you'll be back in business.
« Last Edit: August 14, 2014, 12:03:58 am by MK3FAN »
blubberpud
« Reply #7 on: August 15, 2014, 10:57:43 am »
I appreciate the responses!  I'll see what I can accomplish this weekend and let you know the results.
blubberpud
« Reply #8 on: August 23, 2014, 05:00:46 pm »
Okay, finally got some time to get parts and work on this, replaced the H.O.T. (Q704) and 3 other transistors (Q703,705 & Q708) from the "Horizontal Output Update" Service Kit.....No Joy!!! still tick...tick...tick..... :angry:
Need to do some research on the Vertical IC, to find out what circuit and parts are included in that.
Anything else I can look at or advice?
Thx, Jay
adidas1984x
  • Last login:January 06, 2023, 07:14:53 am
« Reply #9 on: August 23, 2014, 05:19:29 pm »
i sent my u5000 to the arcade buffett and got a k7000 im going to use but have to add the isolation transformer tho
blubberpud
« Reply #10 on: August 23, 2014, 05:54:40 pm »
I'm not sure what arcade buffett is?  http://thearcadebuffett.com/  seems to be down?
Rickn
  • Last login:May 08, 2020, 01:32:28 pm
« Reply #11 on: August 26, 2014, 09:17:45 am »
E-mail me if you do not get the attachment?
Rick@niemandisplays.com
Always happy to help.., for the best in displays
Rick Nieman
Rick@Niemandisplays.com
www.niemandisplays.com
1023 Rife Rd Cambridge, Ontario Canada N1R5S3
519-621-1722
blubberpud
« Reply #12 on: February 09, 2015, 08:28:53 pm »
I hate threads that just die, so here is a final update.  Bought a CGA->VGA converter and went LCD with it, couldn't put anymore time into troubleshooting the board.  Looks sweet on a LCD.
