Author Topic: Which front end...  (Read 1568 times)
chrisindfw
  • Last login:May 09, 2020, 05:57:34 pm
  • I drank what?
Which front end...
« on: December 09, 2003, 11:11:16 am »
Greetings,
I've done some searching and decided to just come out and ask.
I am looking for a front end that is...
Easy to use
Easy to switch between emulators
Easy to swtich between favorites list (ie Combat,Driving, etc)
I was looking at Mame-Wah but was wondering if there was an easier way for a front end to switch between the emulators.
Jakobud
  • Last login:December 23, 2025, 02:48:26 am
Re:Which front end...
« Reply #1 on: December 09, 2003, 01:32:17 pm »
Its very easy to switch between emulators in Game Launcher.  Easy to set up custom lists too.
Cave
  • Last login:June 07, 2009, 10:27:58 am
« Reply #2 on: December 09, 2003, 02:03:02 pm »
It doesn't get any easier than pressing one button  ;)
(press 4 to cycle emulators or change it to something else)
chrisindfw
  • I drank what?
« Reply #3 on: December 09, 2003, 02:24:57 pm »
I see that now. It is working good...
Right now I am running Mame-Wah with Mame and Stella as emulators. When I run an Atari game and I hit escape to get back to mamewah, it gets hosed and messes up. Any ideas?
TalkingOctopus
    • My Arcade
« Reply #4 on: December 09, 2003, 02:59:48 pm »
I would recommend using z26 for an atari emulator with mamewah.  You can get it here:
http://members.lycos.co.uk/stuzza12/downloads.htm
chrisindfw
  • I drank what?
« Reply #5 on: December 09, 2003, 04:21:48 pm »
I got z26 and made the changes but it still locks up after hitting escape from an atari game.
« Reply #6 on: December 09, 2003, 06:31:19 pm »
See what happens if you run the game from a commandline...
chrisindfw
  • I drank what?
« Reply #7 on: December 10, 2003, 08:18:23 am »
It runs fine from the command line. The problem is when running z26 with mamewah. The game loads and plays fine. Its when I hit escape to exit back to mamewah that mamewah locks up and hoses all the windows. I have to "end task" it and start over.
Any ideas?
chrisindfw
  • I drank what?
« Reply #8 on: December 10, 2003, 09:02:20 am »
Nevermind.. I got it!
Syntax
  • Last login:November 23, 2003, 07:57:37 pm
« Reply #9 on: December 10, 2003, 06:10:56 pm »
you should tell us how you fixed it incase someone else gets the same problem.
pmisbedah
  • Last login:April 09, 2004, 12:50:57 pm
« Reply #10 on: February 25, 2004, 04:56:22 pm »
I would like to know what you did to fix it as I'm having this problem, too.
Thanks,
Paul.
