Author Topic: Original Pac-Man Upright Cabinet Restoration  (Read 10372 times)
thk
  • Last login:December 13, 2015, 11:00:09 pm
  • KEEP MOVING FORWARD
« on: July 23, 2014, 10:29:39 pm »
Ok, so this is my first ever restoration. I have chosen PacMan which I bought for $325 plus $100 in gas = $425
It was a 4 hour drive to get it and another 4 hours to get it back home. LONG RIDE but WORTH IT (in my opinion).
The pics speak for themselves but yes I know it needs work. But where to begin? Ideas? Comments? Suggestions?
Thank you to anybody who cares enough to comment. :)
“The truth is, everyone is going to hurt you. You just got to find the ones worth suffering for.”
― Bob Marley
jennifer
Re: Original Pac-Man Upright Cabinet Restoration
« Reply #1 on: July 23, 2014, 11:05:53 pm »
   Oh for fun  (and IMO) The price was reasonable.... There is a lot of parts and support for him, so a real good choice for your first, Since its working, I would @ this point start saving new parts for the "big day" and just enjoy it now as pre restored.... The monitor is most likely the first thing that will go, normally a cap kit will prolong it but judging that pic, there seems to be some burn on the screen, the colors will become less vibrant over time, even if you bring the chassis back to specs.(but use it till You cant).... The art is #2 in my opinion, Gently clean it and scan it (if you can) before you do anything with that.
     Congrats on your new baby !!!!
ed12
« Reply #2 on: July 23, 2014, 11:12:02 pm »
+1 to what jennifer
has to say..olny thing i would inculde is
touch up the foucs on the crt,and give er a good cleaning
then follow bellow advice
nice call jennifer
ed
thk
« Reply #3 on: July 23, 2014, 11:16:19 pm »
Thanks for the info Jennifer and Ed
I want to make a few dollars and would like to restore the coin mech to working order......
A friend if mine mentioned a cap kit as well. They said it will most likely get rid of that squiggly line on the right side.
― Bob Marley
Cobolisdead
« Reply #4 on: July 23, 2014, 11:24:55 pm »
I hope that whomever you bought it from didn't get your tag number, because at $350, you stole it from them!  :cheers:
It has the back piece, the bezel looks good, the Marque is not only there but in good shape, and it works!
Oh, and definitely do the capkit, especially if you can solder.
thk
« Reply #5 on: July 23, 2014, 11:28:27 pm »
I was curious on what that means. Scan the artwork on a giant arcade machine? Is this for a reference when I touch it up? I don't want to use any side art stickers. I really like the original paint. I know I need to bondo or fill in holes and broken corners.
Whew...now I am slightly overwhelmed. "deep breaths"....more studying to do.....
― Bob Marley
thk
« Reply #6 on: July 23, 2014, 11:33:17 pm »
bezel looks good
Bezel looks "ok" I guess. It does have some damage on it and I can see some light coming from the back where the black boarder of the bezel seems to have rubbed out.
― Bob Marley
Cobolisdead
« Reply #7 on: July 23, 2014, 11:58:16 pm »
You could take a risk in touching up the original bezel, buy a reproduction one off of ebay for around $100, or you can scour the web for originals that might be better than the one you have.
I found this one, no good pics to see if it is in better shape or not though.
http://www.ebay.com/itm/Pacman-Non-Jamma-Pcb-Bezel-/261471954362?pt=LH_DefaultDomain_0&hash=item3ce0f165ba
jennifer
« Reply #8 on: July 24, 2014, 06:48:47 am »
     The clean and scan thing is done with multiple scans and reassembled in photoshop, normally done to preserve the art before it gets all messed up with bondo. Not real important with that one however there are a few good reference copys already available.... You will run into some problems with your plan however, That art was originally a screenprint on wood, that's not going to be reproduced commercially like ever (more likely than not) and after fixing that cab that art will be trashed.... So 3 options, the first (and what Jenn does) paint the cab sunburst yellow and slap a sticker over it, #2 airbrushing, a very time
consuming and expensive approach, or Make a screen set (or stencils)... Be careful who you talk to with that last one, That cab has some very protected copyrights on it.... And FWIW, the "T" moldings on that cab was orange originally, somebody changed that one.
thk
« Reply #9 on: July 24, 2014, 11:42:53 pm »
 :dunno
CAP KIT INFO. Trying to locate a cap kit but does anybody know which one I need? Here is a pic.....
― Bob Marley
Cobolisdead
Cobolisdead
« Reply #11 on: July 25, 2014, 02:08:31 pm »
Also, This might be an interesting watch for you:
Apparently, they just touched up the paint.
thk
« Reply #12 on: July 25, 2014, 06:27:05 pm »
Thanks for the info.
****QUESTION****
I talked to this arcade repair guy and he said to check the 50/60 hertz switch and that may be the reason for the vertical line on the screen.
Does anyone know where the heck this is located????
― Bob Marley
jennifer
« Reply #13 on: July 26, 2014, 09:01:03 am »
    If you bought that in the us Its already hooked up for the 60hz, (That's your cord input on the transformer)... But more than likely those hum bars are the result of bad filter caps on the power supply. **Yes those BIG ones.
Cobolisdead
« Reply #14 on: July 26, 2014, 12:01:58 pm »
Which on PacMan are on the main board, as I recently found out.
thk
« Reply #15 on: July 26, 2014, 10:03:17 pm »
Oh NO  :banghead:
― Bob Marley
jennifer
« Reply #16 on: July 27, 2014, 07:18:38 am »
Oh NO  :banghead:
  Jennifer laughs, and laughs.... and laughs,  There is no going back , you are one of us now.... Welcome to the forum!!!!
thk
« Reply #17 on: July 27, 2014, 03:42:31 pm »
Ok I am regrouping after my rant  :angry:
1. Done With Rant
2. ...Continue to make progress.....
3. Check for Board Cap Kits
(Ebay Auction)  $11.90 w/Shipping if winning bid doesn't increase.
UPDATE:
I WON THE AUCTION
So now I just have to wait for the caps and swap them out. I hope this gets rid of that bending of the maze. Otherwise its the monitor...one step at a time...
« Last Edit: July 27, 2014, 10:46:36 pm by thk »
― Bob Marley
thk
Coin Bucket
« Reply #18 on: July 27, 2014, 10:48:12 pm »
Purchased for
$13.45 Total
― Bob Marley
Cobolisdead
« Reply #19 on: July 28, 2014, 10:32:59 am »
Good price! Before I got mine form the arcade junkyard, I was looking online and the best that I could find was $15 shipped.
« Reply #20 on: July 28, 2014, 10:57:26 am »
for the sides and front, I'd try to gentle just touch the paint up. There is NO SHAME in a  30 year old cabinet looking 30 years old. For the bezel, just paint the BACK (underside) of the "missing area" black. that'll stop the light and not mess with the existing art.
Really I'd just do a minimalist touch up job and enjoy the cab.  As for mechs and making money...... sounds like a tax permit nightmare.
orion
« Reply #21 on: July 28, 2014, 06:28:51 pm »
The first thing you should do with a Pac or Galaxian is replace the fuse holder and fuses and the edge connector going from the wiring harness to the games PCB. Bad edge connectors are almost always responsible for hum bars in the monitor. If it's original it needes to be replaced.
thk
« Reply #22 on: July 31, 2014, 06:11:33 am »
Ok so I just ordered a used "Pacman Wiring Harness & Transformer Assembly" from TNT Amusements. $35 Shipped
The old wiring was chopped up bad and there was no telling what could be shorting out.
I also ordered 2 new fuse blocks with new fuses with a new updated 3 prong power cord from Bob Roberts. $28 Shipped
http://www.therealbobroberts.net/
Hopefully this should take care of any electrical/signal issues. Still waiting on my Cap Kits for the PCB Board. When those arrive I will solder those in.
I also ordered 4 new legs for underneath the cabinet $9.30 Shipped
http://www.ebay.com/itm/261422655393?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Coin Bucket arrived and it fits like a glove! (Shout out to "TwistedQuarter") They have a website but they are more reasonably priced on eBay!
http://www.ebay.com/itm/120370341780?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Replacement coin door should arrive tomorrow. I have to strip it all down, repaint and put it all back together.
Just a waiting game now.
p.s. Found this guy on YouTube, his show is called "John's Arcade" This guy is a genius! His video on a pacman restoration is crazy and you really learn alot.
« Last Edit: August 01, 2014, 01:15:36 am by thk »
― Bob Marley
thk
Coin Door Resto
« Reply #23 on: July 31, 2014, 11:31:34 pm »
The coin door came in FINALLY.  :applaud:
$27.29 Shipped (which was a good deal, it just could of came a little quicker).
I pulled it all apart like in the "John's Arcade" YouTube videos. (which are awesome)!
I used "Citristrip" to coat the whole thing so it will strip the paint off. It is sitting overnight now (24 hours).
It came with the coin mechs and wiring too, so its a big plus to have that. (hopefully it will be plug and play but nothings ever that easy).
So now I have to wait on a few things before I can proceed.  We're getting there  :)
« Last Edit: July 31, 2014, 11:48:07 pm by thk »
― Bob Marley
Generic Eric
« Reply #24 on: August 01, 2014, 12:07:00 am »
I have watched many John's Arcade videos.  He would be a total lock for a radio show.
thk
« Reply #25 on: August 01, 2014, 12:13:36 am »
Agreed
Check out this guy too!
http://youtu.be/FO7oanyMGqE?list=UUyjs8rzlagt8XfWxdPQnVRw
I noticed right off the bat that player 1 and player 2 have orange buttons instead of the traditional white. LOL
No blue speckle on this original cabinet but it was nice to see they actually touched up the artwork and did not use those dreadful sticky decals!
« Last Edit: August 01, 2014, 02:57:27 am by thk »
― Bob Marley
thk
« Reply #26 on: August 02, 2014, 10:44:07 pm »
UPDATE
__________________
PICS of door before I stripped it down
PICS of door drying after a few coats of paint
I want it to look a little better still. Looking for a medium gloss with a light hammer touch finish.
I know the original door didn't have that hole punch out, so I might end up restoring it and selling it. Time will tell.
« Last Edit: August 02, 2014, 10:46:56 pm by thk »
― Bob Marley
jennifer
« Reply #27 on: August 03, 2014, 03:19:51 am »
     I wouldn't worry about that punchout, In fact that kind of an option if you ever sell that thing, its for a free play button. You could strip it again putty over it and repaint, but after you get all the glamor on you wont even notice it... That coin bucket however, not sure what to make of that, its not the real thing, or its been modified for some reason, but if it fits nobody will ever be the wiser all locked up in there.
thk
« Reply #28 on: August 04, 2014, 11:34:38 pm »
Ok did a little more research for anyone interested.
Space Invaders Door
From what I can gather some games did not have a "free play" option so they needed that hole for a credit button.
Optional Credit Button
Credit Button Installed
― Bob Marley
Spyridon
« Reply #29 on: August 07, 2014, 02:19:06 pm »
You can check out my restore thread and it will give you a lot of information on a Pac-man restore.
And if you decide to go all in and repaint with stencils you can turn that cab into this:
« Last Edit: August 07, 2014, 02:20:47 pm by Spyridon »
thk
« Reply #30 on: August 10, 2014, 10:36:14 pm »
WOW  :notworthy:
― Bob Marley
