Author Topic: Xin mo problems  (Read 1271 times)
jugger18
  • Last login:February 25, 2020, 09:58:30 am
  • Time to make a bitchen man cave
Xin mo problems
« on: July 08, 2014, 10:53:01 pm »
I picked up a xin mo NIB off the forums.  Got my test box (a cardboard box) wired up.  Daisy chained the ground to common, and all switches to NO.  Plugged it into PC, Xin mo is recognized.  When I go into test it does not recognize any inputs, same when I try to calibrate.  Any ideas?
thomas_surles
Re: Xin mo problems
« Reply #1 on: July 09, 2014, 01:24:39 am »
Hmm I had the same problem once but it fixed itself. Though I don't use mine as a gamepad I use joy to key
jugger18
Re: Xin mo problems
« Reply #2 on: July 09, 2014, 10:11:39 am »
It was possibly an ID10T error.  Moved the ground harness to the plugs on P2 side and all was well.
thomas_surles
Re: Xin mo problems
« Reply #3 on: July 09, 2014, 11:18:13 am »
weird I also had a problem with mine wherw it wouldnt work on a certain usb port anymore.
