Author Topic: WinIPAC interface issue  (Read 1561 times)
jedimasta
  • Last login:February 26, 2025, 12:24:05 am
« on: July 06, 2014, 06:52:26 pm »
After deciding to take my cocktail cab and shove its guts into a more portable unit, I came across an issue that is more of an annoyance than a functional problem that I just can't figure out.
When I load up WinIPAC to make button assignment additions or changes, the window is totally off kilter. What I mean by that is that the left hand menu click hit states are all out of whack. The panel area with which to drop buttons onto is all screwy too, so often times when I drag a button onto the 'stage' it just disappears, because the stage actually start further over to the right than indicated. Text from panels bleeds over too. I've tried complete uninstallation and changing screen resolution. The window can't be resized either.
There's a couple screenshots below to show you what I mean. Note in the second screen how the hilighted border SHOULD be around the blue swatch but is over to the right and down between the purple and the black. I've made sure to download the latest version and I don't have the same issue on newer computers. The one affected is a WindowXP Pro with an ATI Radeon Mobility 9700 gfx card if that helps at all.
Thanks for having a look.
wildcat
  • Last login:September 12, 2015, 10:03:49 am
Re: WinIPAC interface issue
« Reply #1 on: October 08, 2014, 08:06:43 pm »
That is Bizarre.. how did you get buttons outside the window?
