Author Topic: 2/3 24.8" Tri-Mode Makvision VGA Input Not Synching  (Read 1105 times)
MK3FAN
« on: June 24, 2014, 07:41:12 pm »
Hey everyone. I have 3 24.8" Tri-Mode Makvisions and only 1 of them has a functioning VGA input. The other two don't sync. It's not a problem of input signal or anything like that because I'm using the same setup to test all 3. One of them works and the other 2 don't. It's definitely a sync issue because I am getting the vertical split lines and multiple identical images on the screen. Anyone ever experience this issue with their Makvision or have any knowledge on what causes it, other than simply having a bad chassis? Thanks for your time - Mike.
Edit: yes, the "1K/75K switch is in the 75K position."
« Last Edit: June 24, 2014, 07:52:54 pm by MK3FAN »
