Author Topic: Mala Frontend quit Epsxe with esc???  (Read 1739 times)
prefor
  • Last login:June 28, 2014, 10:51:50 am
« on: June 22, 2014, 08:36:11 am »
Hi guys, i am trying to quit the emulator Epsxe with the hotkey attached to ESC. All of my emulator works with that except for PSX emulator (Epsxe). And whenever i click esc i come back to the mala menu, and all i can see is "starting" and the emulator in the background, so i have to use taskmanager to kill it.
How can i make it to quit when i click the ESC button??
jaharr01
Re: Mala Frontend quit Epsxe with esc???
« Reply #1 on: June 22, 2014, 02:24:04 pm »
Can you map a different key to make the emulator quit that you aren't using like delete or backspace?
prefor
« Reply #2 on: June 22, 2014, 03:18:20 pm »
It doesn't help because the emulator is still playing in the background... i have to use task manager to kill the process...
Is there a way i can make a hotkey to make it kill the process??
I've downloaded autohotkey but i have no idea how i should begin and how i can exit it from Mala frontend :/
Can you guys help me?
