Author Topic: Cap Kit lists for Mouser (updated 7/10/15) (now with pics!)  (Read 51188 times)
Sarver Systems
  • Last login:October 07, 2020, 12:46:05 am
    BULK REPAIR KIT FOR TECHS Cost +/-$272.00
    ^^^click me for full shopping list^^^
      ALUMINUM ELECTROLYTIC
      • 25    100uf @ 200V
      • 25     330uf @ 50V
      • 25     33uf @ 35V
      • 25     4.7uf @ 250V
      • 100   1uf @ 50V
      • 50     1uf @ 250V
      • 10     1uf @ 450V
      • 100   2.2uf @ 50V
      • 25     2.2uf @ 250V
      • 25     3.3uf @ 50V
      • 25     3.3uf @ 250V
      • 100   4.7uf @ 50V
      • 25     4.7 @ 250V
      • 100   10uf @ 50V
      • 30     10uf @ 160V
      • 30     10uf @ 250V
      • 25     22uf @ 50V
      • 25     22uf @ 250V
      • 100   47uf @ 50V
      • 20     47uf @ 250V
      • 100   100uf @ 50V
      • 25     100uf @ 160V
      • 50     220uf @ 35V
      • 30     470uf @ 35V
      • 25     1000uf @ 25V
      • 25     1000uf @ 35V
      • 25     2200uf @ 35V
      BIPOLAR ALUMINUM ELECTROLYTIC
      • 20     1uf @ 50V BP
      • 20     4.7uf @ 50V BP
      • 20     10uf @ 50V BP
      TANTALUM
      • 10     4.7uf @ 10V
        FUSES AND PARTS
        • 10     1.2A fuse
        • 10     3A fuse
        • 20     small fuse clips
        • 20     large fuse clips
        RESISTORS
        • 10     1 ohm 1/2W
        • 10     4.7k ohm 1/2W    TBA
        TRANSISTORS (optional)
        • 5   2SD870 transistor (Bob Roberts)
        • 5   2SD1398 transistor   (Bob Roberts)
    [/list]
    « Last Edit: July 10, 2015, 01:53:10 pm by Sarver Systems »
    Sarver Systems
    Re: Bulk Cap Kit list for Mouser (updated 7/10/15)
    « Reply #1 on: June 10, 2014, 12:29:00 pm »
    PRICE WATCHER
    $237.92 updated 6/10/14 (no back orders)
    $242.82 updated 6/13/14 (no back orders)
    $252.93 updated 7/1/14 (no back orders)
    $264.07 updated 7/15/14 (no back orders)
    $264.07 updated 7/18/14 (2 parts backordered)
    $264.07 updated 7/23/14 (no back orders)
    $264.07 updated 7/28/14 (2 parts on backorder)
    $264.07 updated 8/3/14  (2 parts on backorder)
    $264.07 updated 8/7/14  (2 parts on backorder)
    $268.59 updated 8/10/14 (added fuse clips, added resistors, 1 part swapped due to backorders, 1 part backordered, see note above.)
    $268.59 updated 8/15/14 (2 parts on backorder)
    $269.70 updated 8/24/14 (removed fuse clips, added 2 new caps, 3 parts on backorder)
    $269.70 updated 8/27/24 (4 parts on backorder)
    $269.70 updated 9/1/14 (4 parts on backorder)
    $269.90 updated 9/5/14 (4 parts on backorder)
    $283.43 updated 9/10/14 (added 1 new cap, 5 parts on backorder)
    $283.43 updated 9/12/14 (5 parts on backorder)
    $310.43 updated 9/23/14 (added 1 new cap, 5 parts on backorder)
    $310.68 updated 10/13/14 (7 parts on backorder)
    $272.00 updated 10/27/14 (6 parts on backorder)
    $277.00 updated 11/21/14 (3 parts on backorder)
    $272.65 updated 12/10/14 (4 parts on backorder)
    $272.81 updated 12/30/14 (3 parts on backorder)
    $272.81 updated 1/19/15 (4 parts on backorder)
    $272.81 updated 2/16/15 (4 parts on backorder)
    $272.82 updated 3/27/15 (1 part on backorder)
    $272.82 updated 4/27/15 (3 parts on backorder)
    $272.82 updated 6/17/15 (1 part on backorder)
    $272.82 updated 7/10/15 (1 part on backorder)
    Here is the case shown above:
    http://www.harborfreight.com/multi-compartment-utility-box-40528.html
    But here is a better alternative, since it is larger in size:
    http://www.harborfreight.com/toolbox-organizer-with-4-drawers-68238-8143.html
    « Last Edit: July 10, 2015, 01:54:21 pm by Sarver Systems »
    Ken Layton
    • Guru
    • Technician
    Re: Bulk Cap Kit list for Mouser (updated 6/7/14)
    « Reply #2 on: June 12, 2014, 02:24:51 pm »
    Electrohome monitors use pigtail GMA style 1.25 amp fuse for the B+ fuse. I replace it with two of Jameco Electronics # 119280 side terminal fuse clips. The circuit board already has the spots for the fuse clips. Makes replacing fuses a lot easier and cheaper.
    Electrohome and several other monitors use a 2SD870 horizontal output transistor.
    Wells K7000 uses a 2SD1398 for the horizontal output.
    Sarver Systems
    « Reply #3 on: June 12, 2014, 02:38:46 pm »
    Based on the number of caps in the above list, how many of those parts you posted would you suggest having on hand? Obviously it would depend on how many of that particular monitor, but assuming it was an average mix of monitors....
    Ken Layton
    • Guru
    • Technician
    « Reply #4 on: June 12, 2014, 02:51:48 pm »
    I would keep a couple of the 2SD870 transistors on hand and a couple of the 2SD1398 on hand.
    The fuse clips I like to keep 20 on hand. That will do 10 Electrohome G07 monitors.
    Sarver Systems
    « Reply #5 on: June 12, 2014, 03:34:13 pm »
    I'll have to cross reference those to Mouser parts, I didn't see any of those 2 listed on their site.
    ed12
    « Reply #6 on: June 12, 2014, 03:56:16 pm »
    for good measure through in the g07/08 flyback,and the 3pin regulator,
    i know we are on topic about cap's,but a full rebuild demand's it
    ed
    Sarver Systems
    « Reply #7 on: June 12, 2014, 03:57:56 pm »
    Are those available from mouser though? I don't recall seeing any flybacks there.
    Can you post a part number on the regulator? I don't have one in front of me at the moment.
    ed12
    « Reply #8 on: June 12, 2014, 04:03:29 pm »
    a few places sell them
    they are not adver's here so i dare not list them
    google g07/go8 flyback's
    it will get u to a www. under cup's
    the reg i forget off of the top >ken please chime in<
    + add the horz freq tantalium..this is a common failure point in horz shift/hold/sync-lock-up
    it is a small 1  4.7 or less at 16v and must be just about exact
    ed
    Ken Layton
    • Guru
    • Technician
    « Reply #9 on: June 12, 2014, 04:40:38 pm »
    The Electrohome G07 regulator is a 2SC1106A.
    Mouser generally does not carry Japanese semiconductor numbers (2SA, 2SB, 2SC, 2SD, etc), but they do carry American numbers (2N, 1N, etc).
    For Japanese semiconductors you want to go to MCM Electronics.
    Sarver Systems
    « Reply #10 on: June 13, 2014, 01:08:52 am »
    Thank you both for the info.
    I will update the list ASAP.
    Sarver Systems
    « Reply #11 on: June 13, 2014, 08:33:29 am »
    Ken: I'm still not getting any results on mouser searching for combination of 2NC1106A, 1NC1106A, 2SC1106A, or even 1106A. Could provide mouser part numbers, since you know those particular parts much better than I?
    Ed12: How many of those caps would suggest adding to the list, based off the quantities of the other caps in the list?  4.7MFD @ 16V Tantalum. Is that a radial or axial package?
    Ken Layton
    • Guru
    • Technician
    « Reply #12 on: June 13, 2014, 11:35:32 am »
    Type 2SC1106A has been obsolete for a long time. It is now very hard to find. It does cross to an NTE 94.
    None of the major parts distributors carry the 2SC1106A any more.
    Sarver Systems
    « Reply #13 on: June 13, 2014, 12:06:00 pm »
    No matches for NTE 94 either. Ugh. This is proving to be pretty difficult!
    ed12
    « Reply #14 on: June 13, 2014, 12:08:56 pm »
    saver
    there is 1 used per chassic
    highly recmond u add it..it solves alot of horz problems
    ed
    Sarver Systems
    « Reply #15 on: June 13, 2014, 12:19:41 pm »
    Is it a radial or axial package?
    ed12
    « Reply #16 on: June 13, 2014, 01:20:08 pm »
    radial
    it is under the tin sheild
    ed
    Sarver Systems
    « Reply #17 on: June 13, 2014, 01:58:17 pm »
    10 of the tantalum caps have been added.
    I still need part numbers for the fuses, clips, and transistors.
    If someone can tell me the value of the fuse, I can cross reference it to a part number.
    ed12
    Re: Bulk Cap Kit list for Mouser (updated 6/13/14)
    « Reply #18 on: June 13, 2014, 02:40:25 pm »
    make sure u make note in there
    the value must be dead on..
    ed
    Sarver Systems
    « Reply #19 on: June 13, 2014, 03:03:06 pm »
    Do you mean to just measure it before installing it? Or to just make the part ordered is the part ordered?
    ed12
    « Reply #20 on: June 13, 2014, 03:51:23 pm »
    either
    as a rule tan's do not :drift: until exposed to heat
    but i tend to error on the safe side
    and spec it to dead nut's as it were..
    u have to under stand what it dose it >set's the horz freq and lock through a phase lock loop<..so bang on is better
    ed
    Sarver Systems
    « Reply #21 on: June 13, 2014, 03:53:15 pm »
    So it needs to be measured with a ESR meter?
    ed12
    « Reply #22 on: June 13, 2014, 04:09:21 pm »
    tan's are 90% always right on.
    but good measure say' yes when u are buying them..
    to remove 1 and test it? it is a 50/50..no need to guess
    btw the clip u are looking for is called a >s< clip for fuse's
    what ken is refering to is u can put in a pigtail and or a blade type fuse
    the board make's it that way,until latter on in the serial # run
    rickn was the lead eng on the g07/go8 stuff
    nice guy and is chatty when u ask him q's
    ed
    Sarver Systems
    « Reply #23 on: June 17, 2014, 02:02:47 pm »
    What value should the fuse be?
    ed12
    « Reply #24 on: June 17, 2014, 03:13:15 pm »
    let me see if this will make it easier for u
    btw there is 2 fuses used
    1 is the main input fuse
    the other is the b+ fuse
    plus u might need a few resistor's,
    these are 1 ohm job's and act as a fuse AFTER  the flyback
    ed
    Sarver Systems
    « Reply #25 on: June 17, 2014, 08:27:17 pm »
    Fuses have been added.
    ed12
    « Reply #26 on: June 17, 2014, 08:55:26 pm »
    oh btw
    when they did the nla on the requlator
    to3  style
    we went to a plastic 1
    i would need some byte's to dig out the info for u
    ed
    Sarver Systems
    « Reply #27 on: July 01, 2014, 02:44:12 pm »
    prices went up a smidge over the weekend. All caps are still in stock though!
    Sarver Systems
    Re: Bulk Cap Kit list for Mouser (updated 7/1/14)
    « Reply #28 on: July 01, 2014, 02:45:39 pm »
    I am still unable to located the following parts on Mouser, or anywhere else. If someone could post the part #, I'll get it added.
    ITEMS TO BE ADDED
    •5     2SD870 transistor   <--- need part #
    •5     2SD1398 transistor   <--- need part #
    Ken Layton
    • Guru
    • Technician
    « Reply #29 on: July 01, 2014, 03:47:43 pm »
    Bob Roberts stocks the 2SD870 and 2SD1398:
    http://homearcade.org/BBBB/parts.html#semiconductors
    Sarver Systems
    « Reply #30 on: July 01, 2014, 03:56:58 pm »
    Cool, I'll update the list ASAP.
    Sarver Systems
    « Reply #31 on: July 02, 2014, 12:40:59 pm »
    Mouser is saying these are compatible with the 2 power transistors.
    511-2STF1550
    http://www.mouser.com/ProductDetail/STMicroelectronics/2STF1550/?qs=%2fha2pyFaduiNgDmMT2bHla6bE372AY3LNuQFCvgjlxlhbSvNzlb8hg%3d%3d
    726-BC817K-40E6327
    http://www.mouser.com/ProductDetail/Infineon/BC-817K-40-E6327/?qs=%2fha2pyFadugrTOFV51sTPMgipnvexUuvXCkrSblYotHURl196ZIQ3XTSvlsXHMqC
    Comments?
    I don't have any of the originals in front of me, but both suggestions are SMD devices.
    ed12
    « Reply #32 on: July 02, 2014, 12:51:04 pm »
    no home run them..sorry bud
    try going to 2sc #'s in t03 pkg's
    if u want i will dig my list out
    here is what u need to rember must have interel damper diode and handle greater then 1600v
    ed
    Sarver Systems
    « Reply #33 on: July 02, 2014, 01:39:49 pm »
    I'm sure mouser has something, I'm just not having any luck cross referencing anything, and apparently neither is Mouser.
    If they were truly obsolete, Bob would (rightfully so) be charging a fortune for them.
    ed12
    « Reply #34 on: July 02, 2014, 02:23:33 pm »
    chk your pm
    DO NOT POST THE LINK
    some one here get's real pissie about it ....
    ed
    Sarver Systems
    « Reply #35 on: July 02, 2014, 02:30:11 pm »
    OK??? I don't want to know.
    ed12
    « Reply #36 on: July 02, 2014, 02:34:17 pm »
    it carrys every part
    inculding the horz freq coil for g07/8's >common fault< as it burns itself out
    u will find your req,and horz out
    in-stock
    i get all my g07/g08/well's kit's from them
    beat's bob prices hand's down
    ed
    Dr. Willy
    • Last login:November 16, 2018, 10:49:08 pm
    Re: Bulk Cap Kit list for Mouser (updated 7/18/14)
    « Reply #37 on: July 21, 2014, 07:49:30 pm »
    Not sure if you want to update the list (perhaps do a seperate one) cause there are not items on backorder and it says they are about 18 weeks out.
    Sarver Systems
    « Reply #38 on: July 22, 2014, 01:32:30 pm »
    I've been watching it near daily. I do notice items go on backorder every now and then, but they usually come off back order in a day or 2.
    I'll continue to watch it and see if anything stays on backorder for more than a week. If it does, I'll swap that part out for a more readily available part.
    Thanks you for noticing that, I'm glad to see people are using the list.
    Sarver Systems
    Re: Bulk Cap Kit list for Mouser (updated 7/23/14)
    « Reply #39 on: July 23, 2014, 10:53:18 am »
    All parts are available again.
