Author Topic: WG 25K7197 New Wei Ya Chassis - UPDATE: Might have just fried it  (Read 26070 times)
MaxAsh
  • Last login:April 19, 2025, 09:42:33 am
  • This... is my boomstick!
Hello all - new guy learning the ways of the arcade world. Been reading a lot, so I think I'm on the right track, but I want to make sure before moving forward. If you have a moment and could provide some quick advice, I'd appreciate it. Thanks! Here's my situation:
Short version of my story: picked up an Ultimate Mortal Kombat 3 game (built into a MK1 cab) that plays blind. The chassis was completely missing from the WG K7000-series monitor, which was still in place. To test the game itself, I hooked it up to a Hantarex Polo 25" from another cab temporarily. Worked beautifully, so I knew the game output video just fine.
I threw a Wei Ya 25" universal chassis into the existing WG monitor after testing the yoke readings to make sure they were within range. I didn't go through the "Americanize" process for the Wei Ya I've seen Ken Layton describe, since I wanted to just wire it up with some splicing/rigging to find out if the monitor itself even works. I figured if it did, I'd go ahead and setup the chassis permanently. I'll go over the problems, what I've done, and where I'm at below:
I fired it up, and the monitor came to life immediately - good sign. I noticed 3 problems with the image immediately. 1) upside down 2) backwards 3) out of phase/sync and shaky.
I noticed the Wei Ya chassis had two separate Yoke hook-up locations side by side, so I moved it to the other yoke hook-up. This solved issue #1, flipping the screen. Next, I cut the yoke connector in half, and reversed the Red/Blue positions. This solved issue #2.
My final issue is (I think) a sync issue. (See Pics) The UMK3 output has the white sync wire in pin position 5 instead of pin position 6. The Wei Ya board has no pin 5 for the RGBGrSync pinout. To resolve this, I simply spliced the white sync wire to position 6 on the connector at the chassis end. It's the only sync pin available, so I would think it would work. Please see the picture links for details.
Is the problem simply that I need to "Americanize" (in Ken Layton's terms) the Wei Ya chassis, replacing it with a 6-pin connector, and moving my sync back to position 5? I thought that sounded odd, as I would think the Wei Ya not having a pin there would mean that position has no trace or connections to it. I can post additional pictures if it helps. Thank you in advance everyone!
« Last Edit: June 07, 2014, 08:04:36 pm by MaxAsh »
MaxAsh
Re: Sync Issue? New Chassis
« Reply #1 on: June 07, 2014, 06:19:19 pm »
Uh oh. This just got a whole lot worse. So I figured I'd play around with the H and V holds, which stabilized the image a little, but not by much. I was playing around with them for about 4-5 minutes when I noticed a burning smell. I checked everything, didn't notice anything awry, but the tall white (cement?) resistor was radiating a lot of heat. That's where I think the heat was coming from anyway. So I reached over to cut the power, and a second before I did there was a Pop/Pffft sound and a huge cloud of white smoke came out of the chassis area.
Did I just fry it? There's an isolation transformer all setup (can see it blurry in the background of one of the pics) so I'm pretty sure that's okay. Did I just lose this chassis? Flyback?
Side note: is that smoke unsafe, I've got the room blowing air outside at the moment, but I breathed in a heck of a lot when it first puffed out.
EDIT: Adding pics of Isolation Transformer/wiring. I found another Ken Layton Post where he discusses a Wei Ya chassis with a Hantarex Polo. He mentioned that the isolation transformer should ONLY have the monitor power coming off one side, not other things (coin door, marquee lights, etc). Looking at mine, I see several connections coming off the left side. The yellow wires appear to trace to the coin door area. I followed the (4) purple wires and found that 2 went up towards the marquee area. Two others ended up joining up with leads coming DIRECTLY off the switching power supply (see pic #2... wire tape connector). My monitor is powered by the latter connections... the wire tapped switching PSU AC + Isolation transformer connections.
Is this causing the problem perhaps?
« Last Edit: June 07, 2014, 07:30:40 pm by MaxAsh »
Ken Layton
  • Guru
  • Technician
Re: WG 25K7197 New Wei Ya Chassis - UPDATE: Might have just fried it
« Reply #2 on: June 07, 2014, 10:33:14 pm »
What model of Wei-ya chassis did you get?
MaxAsh
« Reply #3 on: June 07, 2014, 10:54:22 pm »
It was supposed to be a 25" model, ordered from dirt cheap trading. Just looked closer... it's 429H... 29" model. But, according to their website, this should work as long as my yoke readings are in range 6-12ohms (vert), and higher than 1.5 ohms (horiz). My readings were 10.1 and 2.1 respectively if that helps. Thanks
« Last Edit: June 07, 2014, 11:45:56 pm by MaxAsh »
Ken Layton
  • Guru
  • Technician
« Reply #4 on: June 08, 2014, 12:17:33 am »
I have no information on any Wei-ya models above 25". The only information I have is just the picture of the model label you posted.
I *think* this chassis needs to be run from an isolation transformer. That might be what happened to you. Be sure to remember this: if you have a chassis designed for a 29" tube and you're using it on a 25" instead, then the picture is likely going to be way too big and probably will not be able to adjust small enough to fit your 25" tube.
A great many Mortal Kombat cabinets were shipped with the isolation transformer wired wrong. Many cabinets had a Wells-Gardner U5000 monitor installed which does not need isolation so the problem was not noticed at the factory. Only the monitor should be powered by the output of the isolation transformer. Any other line voltage AC powered stuff (light fixture, switching power supply, bill acceptor, etc) should be connected to the input side of the isolation transformer.
MaxAsh
« Reply #5 on: June 08, 2014, 12:36:41 am »
Thanks for the quick replies Ken! The information the seller posted says the chassis can be used for 25" and 29", which seemed odd to me. They did update their listing to state clearly that an isolation transformer is required, but I assumed since I had one I was okay. What I really don't  understand is what the ac terminals on the switching power supply would be connected with two of the wires coming off the isolation transformer, then going to the monitor chassis. It's as if the isolation transformer is feeding both the monitor and the switching psu on the same output? That seems crazy, or am I wrong?
From what I can tell (going to really look closely tomorrow) there are 4 wires coming off the upper part of the isoT. 2 go to the monitor (and switching psu) and two go up to the marquee (which is disconnected). I think the coin door lines are coming off the lower side of the iso... not sure.
So what are the odds I fried the chassis? Despite the puff of white smoke and smell, the monitor was still working when I shut down the power. Is it possible I might have just blown the resistor? Just trying to figure out my next step. I do have the option of just pulling the monitor completely and replacing it with a hantarex polo 25 I have, which doesn't need an isolation trans I think. Ideally, I'd like to get this WG to work though.
« Last Edit: June 08, 2014, 12:39:23 am by MaxAsh »
ed12
« Reply #6 on: June 08, 2014, 12:47:51 am »
i just ran a search on that chassic
it turn's out in our monitor threads there is some info there but they are all pointing
toward's iso trans must be used
ed
Ken Layton
  • Guru
  • Technician
« Reply #7 on: June 08, 2014, 12:51:04 am »
It's hard to say what happened for sure without a schematic. It's possible something is cooked, but you'd need to pull the chassis and eyeball it good.
You might have blown some diodes, resistors, capacitors, or transistors. You'd need to whip out your test equipment and start checking components.
grantspain
« Reply #8 on: June 08, 2014, 06:05:55 am »
that could be a shorting deflection yoke,the picture has locked perfectly at the top.
i had an almost identical issue on a wg7000 a few months back,I am trying to find a photo as its very similar.
The problem with this kind of fault is that you won't be able to read the short even using an inductance meter as it almost certainly shorts only when voltage is applied.
the chassis is an almost perfect match for the deflection yoke spec and in any case you would have to very far out to get issues anyway,for instance i test nanao ms9 on sanwa es31 yokes and k7000 on hantarex polo 1 yokes.
if we had a schematic for that chassis and the resistor number that smoked then we could probably id the issue,although a ceramic resistor would most likely be in the power regulation circuit rather than the deflection circuit so atm i am just guessing
an iso should power the monitor only so you should consider rewiring
MaxAsh
« Reply #9 on: June 08, 2014, 06:37:34 am »
The image I posted might be a little misleading as it is a frozen representation. The effect I was seeing was more of a wavy, moving, distortion. The picture just happened to be taken when top/bottom appeared clearer. I'll keep that in mind though, if I end up still being able to use this chassis.
I'll discharge and pull it today and start taking a look. I'll post some pics as well. I'm still relatively new to this, so my experience with board-level work has primarily been replacing caps/resistors/general soldering. I'll google (and search the forums) for testing procedures for my situation. If anyone has a direct link, feel free to toss it my way to save me some hunting, thanks!
Just to double-check, consensus seems to be that the most likely culprit is that the isolation transformer is not dedicated solely to the monitor, correct? Based on comments, the fact that the iso leads for the monitor are shared with the switching power supply is a big no-no and easily causes a blow like this?
I'm also going to disassemble a bunch of the power wiring and trace it out (taking pictures/notes). I found Bob Roberts explanation on AC wiring, but it appears to be more of a from-scratch setup, slightly different from mine. I'm sure it's the same principle setup, but I'll double check with you guys as I go. Thanks all, more to come in a bit...
« Last Edit: June 08, 2014, 06:39:17 am by MaxAsh »
MaxAsh
« Reply #10 on: June 08, 2014, 06:49:40 am »
Because it never hurts to document as much data as possible for future viewers - here are some images of the only documentation that came with the Wei Ya 429H. It's not fancy, but it's something. R804 is (I think) where the heat and eventual smoke came from. C918 and the 2A / 6A fuses all look good. I'll have to pull it to see much more. EDIT: Correction - C918 is blown.
« Last Edit: June 08, 2014, 07:00:12 am by MaxAsh »
MaxAsh
« Reply #11 on: June 08, 2014, 08:43:20 am »
Pulled the chassis, took several pictures (see two of them below). In the close-up, you can see the blown C918 large capacitor, and just to the left the tall white resistor. If you look closely, you can see the crack running down from the top to bottom, which I'm assuming is an indicator of it being blown (and probably the source of my white smoke earlier?). All I can read on the side of it is that it's 25W, not sure beyond that. I assume I can scoop these up at mouser or digikey, etc.
I also included an aerial shot of the whole chassis for reference. You can't tell from that aerial shot, but none of the other capacitors appear to be bulging. I'll do some overall testing now and update this post in a bit. Thoughts/comments so far? Any special advice on what/where to test besides the basics is welcome. Thanks
EDIT: Update - Just went through and tested a lot of components. Everything seems pretty good aside from:
  • Tall white R804 resistor that's cracked (test showed a negative reading that then steadily climbed into positive and just kept climbing in reading)
  • Large capacitor shown in the image aka C918 (clearly blown in the image)
  • Possibly transistor on the far bottom of the aerial chassis image, a little to the right of the blown large cap. Labeled Q801. When I tested the transistor, I got a ~0.50 reading on one outer leg, but no reading on the other. I tested the other transistor (near the flyback area) and both legs read about 0.50.
So far everything else seems okay, continuing to test just in case. I'm getting continuity and proper resistance testing on all the other components so far. Am I correct in my assumption that the transistor with the non-reading on an outer leg is bad now?
« Last Edit: June 08, 2014, 09:52:00 am by MaxAsh »
MK3FAN
« Reply #12 on: June 08, 2014, 11:09:52 am »
That big, blown capacitor is most likely the filter cap. I would start with replacing it, the large, tall, vertical ceramic resistor next to it and see what that does for you. I didn't see, but did you test your HOT?
grantspain
« Reply #13 on: June 08, 2014, 11:17:34 am »
blimey a mains filter cap exploded,only ever seen that when ac input voltage is way too high
MaxAsh
« Reply #14 on: June 08, 2014, 11:29:14 am »
Assuming I'm testing the right things (being new to this), I believe I tested both transistors (3 pin just to the left of the big blown capacitor and 3 pin over near the flyback area). I'm not sure which is the HOT, but I can tell you the one closest to the large blown cap has a leg with no reading (leg closest to the cap). The other leg is fine @ 0.50. The transistor near the flyback is fine on both legs.
Some more pictures and info regarding the power setup. I can draw a full diagram if necessary, but I think laying it out here in text should work, supported by the images attached. I'm starting to wonder if this is even setup as an isolation transformer. The look of it doesn't seem to match anything I'm seeing in setup videos, etc. Feedback is welcome, thanks all!
Voltage Readings
- Monitor Power:  131.4 V
- Marquee Power:  131.4 V
- Switching Power Supply:  132.4 V
- Coin Door Lights/etc:  6.1V
DC off switching PSU is good (12.8 / 5.0 as it should be)
Wiring Details
As you can see from the pictures, the transformer is sitting on top of the incoming power block. In one image, labeled "Transform_RightSide", you can see the incoming AC cord, fuses, and also the outgoing wires to the cabinet power switch (black & white with stripes).
On one side of the transformer (RightSide in pictures), I have a big bundle of wires that enters a large connector block. The black and white (striped) wires that I assume are the power switch wires mentioned above also go into this large connector block. Exiting that block are only 4 wires, all of which appear to go to the switch. (black, white, blue, yellow).
On the other side of the transformer (LeftSide in pictures) I see several things.
- First, coming out of the power block area are two yellow wires. One yellow wire goes directly to the coin door area. The other appears to pass thru the bottom area of the transformer, then continue to the coin door area as well.
- Coming out of the top area, as shown in pictures, are (4) purple wires. They enter a 4-pin connector. Two of the wires (the two in the center of the connector) go directly to the Marquee lights. I have disconnected the marquee lights since the initial problem occurred, but testing shows 131.4V at the marquee connector.
  The other two purple wires leaving the transformer (outer wires coming out of the 4-pin connector) travel a short distance and are spliced together with the two wires coming off the two AC terminals on the switching power supply (see pic labeled "Monitor_SwitchPSU-merge"). And then continue on to the monitor power connector.
Assuming I'm interpreting this all correctly, here's what that means: The transformer in question is outputting directly to the cabinet power switch on one side. On the other side I have a lower connection outputting 6.1V to the coin door area. On the upper connection I have:
131.4V existing on (4) wires and feeding three things: Monitor, Switching PSU (share two wires out of transformer through splice), Marquee light (2 wires to itself).
So here's the big question: is this even an isolation transformer, or is this just a transformer and this cabinet has no isolation transformer? If it IS an isolation transformer, can I peel back the paper covering and rewire it in a way that will isolate the monitor, but still feed power to the marquee and switching PSU?
Thank you, apologies for the long post, but I wanted to include as much detail as possible. If additional info is needed, please let me know. Thanks to everyone for their help!
MaxAsh
« Reply #15 on: June 08, 2014, 11:32:33 am »
With all the outputs from the power/transformer area being 131.4 ~ 132.4 V , guessing that's spot on.
Edit: Sidenote... I have a second cabinet (Time Killers) which contains a Hantarex Polo 25". Looking at the power setup and wiring it is 100% identical to the Mortal Kombat wiring. Right down to the Switching PSU and Monitor being fed off the same wires from the transformer area. The big difference, based on what I've read: Hantarex Polo 25 doesn't need an isolation transformer. This explains why, when waiting for my chassis to arrive for the MK cabinet, when I tested the video output of the game to the Hantarex Polo, everything was perfect. Live and learn. /end Sidenote
« Last Edit: June 08, 2014, 11:57:51 am by MaxAsh »
Ken Layton
  • Guru
  • Technician
« Reply #16 on: June 08, 2014, 12:22:02 pm »
Blimey a mains filter cap exploded. Only ever seen that when ac input voltage is way too high.
Or when a chassis that needs isolation is run without an isolation transformer.
The exploded main filter capacitor will have to be replaced and I bet one or more of the four diodes next to it are shorted. Possibly a blown foil trace on the foil side of the board. Transistor Q801 is the B+ regulator and it should get tested to see if it's shorted along with transistors Q802 and Q803 (also part of the power supply circuit.
The big resistor is generally 140 or 160 ohms @ 25 watts and should be replaced if it cracked.
Pdf page 40 (3-4 original page number) of the manual shows cabinet wiring of Mortal Kombat:
http://arcarc.xmission.com/PDF_Arcade_Manuals_and_Schematics/Mortal_Kombat_1_%2816-40025-101_July_1992%29.pdf
« Last Edit: June 08, 2014, 12:38:00 pm by Ken Layton »
MaxAsh
« Reply #17 on: June 08, 2014, 02:10:50 pm »
Great, thanks Ken. Now for a couple new guy questions:
- Best place to get replacements? (I've used digikey in the past) I've bought the wrong components before, so any advice on specific part numbers or what to search for would be welcome. Helps me avoid over ordering when I get paranoid and think I've got the wrong part ha.
   For example, the large blown cap... never bought one that large. It says 470uF, 200WV, 85deg C. Diameter appears to be 22mm, height around 42mm. Would something like this work?
http://www.mouser.com/ProductDetail/Nichicon/UVK2D471MRD/?qs=sGAEpiMZZMvwFf0viD3Y3UC90LIngmp6xVvwqDKC7jE%3d
or
http://www.digikey.com/product-detail/en/200VXR470MEFCSN22X40/200VXR470MEFCSN22X40-ND/3565112
- Testing - Do I need to desolder everything for testing, or will on board work in most cases?
I appreciate everyone's patience  and advice as I learn more about this every day. If there's a how-to for testing that I miss please redirect me, I haven't found a good one yet. Thanks all!
« Last Edit: June 08, 2014, 04:18:05 pm by MaxAsh »
MaxAsh
« Reply #18 on: June 08, 2014, 05:01:31 pm »
Four diodes next to the exploded main filter capacitor all test at 0.566, so seem to be okay. Transistors on the other hand, not so much. Q801 is coming up 0.511 on one outside leg, but no reading on the other outside leg at all. Q802 is reading 0.672 on one side and 1.070 on the other. Q803 is reading 0.511 on one side, and toning with 0.004 on the other. I'm assuming this means all three transistors (Q801, Q802, Q803) are all in need of replacement? Or is Q802 borderline? Quick shot of the backside of Q801 attached. I don't see any foil traces blown at a glance.
MK3FAN
« Reply #19 on: June 08, 2014, 06:30:42 pm »
I would remove all the transistors from the circuit to test them properly and avoid any erroneous readings that might lead you astray.
MaxAsh
« Reply #20 on: June 08, 2014, 06:38:12 pm »
Okay, will do. I haven't had any luck finding a replacement tall white resistor. Can someone direct me to them at mouser or another site? Thanks EDIT: Found a picture I took of the chassis before that resistor popped, writing on the side was: 25W 140 ohm J.
Also, anyone have thoughts on the "isolation" transformer pictures/questions above? Still wondering if I can even re-wire what's shown, or if I need to buy another isolation transformer.
« Last Edit: June 08, 2014, 07:57:35 pm by MaxAsh »
MaxAsh
« Reply #21 on: June 09, 2014, 11:09:28 am »
I cannot for the life of me find a 25W 140 ohm resistor like the one I blew. I found a 25W 150 ohm on radio shacks eBay outlet, but that's the closest I've come. This is driving me nuts as I've never dealth with resistors like this one in the past.
http://www.ebay.com/itm/NE-25W115-25W-Cermet-Power-Wirewound-Resistor-150-Ohms-5-25W115-/360800801697?pt=LH_DefaultDomain_0&hash=item54016753a1#ht_1145wt_1105
My desoldering pump broke, new one arrives tomorrow so I'll be pulling components for additional testing tomorrow night. In the meantime, if someone has feedback on what to do with the transformer situation above, I'll work on that piece. Thanks all
Ken Layton
  • Guru
  • Technician
« Reply #22 on: June 09, 2014, 12:04:52 pm »
You'll probably have to use the 150 ohm 25 watt one. Mouser is out of stock of the only resistor close to the one you need and it listed as being another 12 weeks before they have one.
Digi-Key and Jameco don't even carry anything close.
MaxAsh
« Reply #23 on: June 09, 2014, 12:39:13 pm »
Okay, thanks Ken. As long as the 150ohm 25W one won't cause trouble, I'll give it a try. Any thoughts on the original cause of my problem? Just curious if I need to order an isolation transformer before going any further, or if I can use what I have and re-wire. Something about it all just seems odd.
ed12
« Reply #24 on: June 09, 2014, 01:04:00 pm »
10 ohms is not really that big of a deal
rember 140 ohm +/- 10%,
it is there as a dropper/in-rush limiter
ed
MaxAsh
« Reply #25 on: June 09, 2014, 01:53:24 pm »
Okay, thanks Ed12. Assuming no one has objections, while I wait for a few items to arrive in the mail I'm going to dismantle the entire power section and check everything. I assume I can just peel back the "paper" around the transformer to see how everything underneath is wired, correct?
I went through the wiring diagrams in the document Ken linked (Thanks Ken) and found the Power Wiring info shown in the attached picture. This is exactly how mine is wired... yet the consensus seems to be that this wiring is incorrect if the chassis requires isolation, am I correct? Would it make sense to just take the monitor off this transformer (leaving everything else the same), and just buy a new isolation transformer for $20 or so, place it next to this one and wire it solely for monitor?
EDIT: Adding image showing Transformer Chart. As you can see, the output of the transformer shows "120V Isolated for Monitor and Power Supply" (The Marquee Light Fixture is also coming out from that spot). All of my wiring exactly matches these two diagrams. Based on the above comments, this is what blew my new Chassis, correct? Is that's accurate, where do I go from here? Thanks again everyone, I know this thread has grown into quite a series of questions.
« Last Edit: June 09, 2014, 06:08:43 pm by MaxAsh »
MaxAsh
« Reply #26 on: June 10, 2014, 08:26:29 am »
Just found an older post from KenLayton about the same Midway wiring setup where he says you never unwrap the transformer, so I've left it alone. But that leaves me a little stuck as to my next step. If I can't rewire the transformer, which appears to be improperly setup for isolation, then I'm not sure where to go from here. Ideal situation would be I test/replace various parts on the chassis that blew, then hook it up and try again, but until I figure out the root cause of the initial blow and handle it, I'd just be wasting time/money on repairs. After a lot of success early in this hobby, I knew I was due for a bump in the road. Definitely frustrating, I would be going insane without you guys! Many thanks - let me know which steps to take next and I'll get on it asap.
ed12
« Reply #27 on: June 10, 2014, 11:58:05 am »
with a meter
chk the primary blue and yellow to any lead on the secondary side
if u get counity then IT IS NOT AND ISOLATION TRANSFORMER,HOWEVER IF U DO NOT
THEN IT IS AN ISOLATION TRANSFORMER
also make sure to un-hook the transformer >any plug's going to it<
so u are chking the transformer olny,and do this with the machine un-plugged from any
power source
easy as pie
ed
« Last Edit: June 10, 2014, 12:08:37 pm by ed12 »
MaxAsh
« Reply #28 on: June 10, 2014, 01:41:32 pm »
with a meter chk the primary blue and yellow to any lead on the secondary side
ed
Just performed the test (hopefully correctly), see attached image. I checked all the purple (and for kicks the yellow) wires against the incoming blue/yellow connections on the other side. I placed one probe in the yellow connector pin and tested all the purple wires, then again on the blue pin. No continuity with everything unplugged.
Just so I'm certain I did this correctly, the wires I tested on the secondary side were the ones that connect to the blue/yellow wires from the cabinet switch going into the transformer, right? They actually change color from blue/yellow into blacks/whites as they go into the transformer (and the blue gets split a bunch of ways in the connector).Attaching a pic of the large connector when it is plugged in, just for clarity. Thanks for the patience Ed!
I also performed a Voltage test with the secondary side hooked up to power. Incoming from the cabinet switch I'm receiving 119.7 Volts going into the transformer, but on the other side all of the purple wires are testing as 131.4 Volts.
« Last Edit: June 10, 2014, 01:43:47 pm by MaxAsh »
ed12
« Reply #29 on: June 10, 2014, 02:33:50 pm »
if u got no countiy between primary and secondary side
then it is an isolation transformer
117 in and 131 out = no seconday side load
that 131 will drop to 120 fast enough under load
btw just for refernce a smps power supply dose not require a isolation transformer
as it is already isolated by design,we just do it for good measure..
if u need rfernce to the ^^^^ statment i just made
look at any spms power sullp schmeatic
u will catch on fast to the fact..but as i said to avoid the aurgment
we do it for good measure..
so all that aside when u go to repower the unit
un-plug any and all marque light's as showen in ken's pix..
this way u ar truly isolated
ed
MaxAsh
« Reply #30 on: June 10, 2014, 03:32:45 pm »
So based on the test, it is an isolation transformer. And from what you said, the 131.4V coming out is okay. Sounds like the SMPS sharing the output with the monitor is okay from your comments as well. So the culprit would just be the marquee light? The really strange part is that the marquee light has no bulb, so it wasn't lit, not sure if that matters. Is it really possible that just because the unlit, unbulbed marquee shares the output with the monitor, it fried my chassis? Wow.
Is there anything else I should check? What about something being grounded, or not grounded, that should be? The only ground on the chassis that I recall connecting was the monitor strap over to the neckboard ground pin. I'm also wondering if part of the chassis might have been touching the metal monitor frame by accident. Just some random thoughts/questions.
ed12
« Reply #31 on: June 10, 2014, 03:47:10 pm »
wow my last post was classic case of slow down when typing >ed<
for good measure just un-plug any marques..
your chassic should have a green wire from the meatl pan to ground
ie 3rd wire >green< on a north american 120 volt system
again just good measure
ed
MaxAsh
« Reply #32 on: June 10, 2014, 04:51:05 pm »
ed
Looked around the metal frame, look what I found. Chopped off ground wire, lovely. Sounds like this wouldn't have caused my problem, but it's something to keep in mind. So to sum up where I'm at, since this thread has gotten long:
1) Wired up chassis exactly as I saw it setup, however output from transformer is shared with Switching Power Supply and Marquee Light
2) Turned on cabinet, 5 minutes later smelled burning, felt extreme heat from large resistor area, then cloud of white smoke, shut everything down.
3) Found blown main large capacitor, cracked large resistor. Possibly blown transistors, though diodes near power supply test okay.
Things Tested/Discovered:
1) No continuity across transformer with everything unplugged.
2) 119.7V coming into transformer, 131.4V coming out when hooked to household power
3) Tested DC across transformer with 6V battery, DC does not pass through.
4) Marquee, Chassis and Switching Power Supply all share the same output terminals on the transformer
5) Marquee fixture was plugged in at the time of chassis blowout, but there is no bulb in it. Further inspection reveals the fixture looks broken/damaged.
6) Chassis frame not grounded
7) Cabinet is wired in old Midway style, exactly as shown in power wiring diagrams earlier in thread.
Probably a few other items, but that's the general idea. Thanks all for everything so far, you've been great! What's next?
MaxAsh
« Reply #33 on: June 11, 2014, 02:37:06 pm »
It's been suggested by a local tech that I may have let a portion of the chassis touch the metal frame of the monitor. I'm not 100% certain the chassis was properly mounted/separated upon reflection, so it's possible this is true. So my question would be: is it possible for a chassis to be improperly touching the metal frame, function for 5 minutes, then blow? Or would that be an instant burn out situation?
PS - I'll be desoldering more parts and testing them tonight, so I'll post an update of the test results as soon as I have them.
MaxAsh
« Reply #34 on: June 11, 2014, 08:43:04 pm »
Okay everyone, here's where I'm at testing. Feedback is welcome, many thanks:
Q801 - Good (.511 and .548 readings)
Q802 - Good (Base to Emitter .699, Base to Collector .671)
Q803 - Bad (No readings and/or Tone on all measurements)
D801, D802, D803, D804, D810   Good (.500-.599 range)
R808, R809, R810   Good
We know large capacitor (C918) and resistor (R804) are blown
EDIT: Tested Q401, I think it's Bad (Base to Emitter .088 , Base to Collector 0.501) - this is way over by the flyback area
Attaching a pic of Q401 from the back, should it look this messy?
« Last Edit: June 11, 2014, 08:52:06 pm by MaxAsh »
ed12
« Reply #35 on: June 11, 2014, 08:58:58 pm »
good measure say's replace it if in doubt.
the messy part u speak of is flux
left over from another replacement,
ie: the tech never used flux remover..nothing to worrie about
ed
MaxAsh
« Reply #36 on: June 11, 2014, 09:09:00 pm »
ed
Okay, thanks. Based on the original images of the board, is there anything else I should test? I could spend half the night desoldering everything, but the impression I got was that I should test the diodes/resistors near the power section, as well as all the transistors. I've done that, so should I be good to order the parts on the bad components, solder them on, and give it another try (after ensuring isolation again)? Just want to make sure I order everything in one batch if possible.
« Last Edit: June 11, 2014, 09:29:20 pm by MaxAsh »
ed12
« Reply #37 on: June 11, 2014, 10:10:58 pm »
i have a few q's,but i want some clearity on this statment
>It's been suggested by a local tech that I may have let a portion of the chassis touch the metal frame of the monitor<
how did this person deduce this information.?
the reason i ask is easy u touch any hot chassic to ground and u WILL have a very beautifull black mark
and a few blowen trace's,plus a black mark on the chassic pan..is this what u are seeing ?
if  not it was not isoalted right,at which point i would worrie about the mother board >game-board<,
at this point is wish u had a varic..but i will hand u a piece of advice
60 watt light bulb >yes real bulb<,it is to used as a fuse,reason is if u have problem we can better save u the money on another set of part's.
the bulb replace's the main fuse for the time beenin
ed
MaxAsh
« Reply #38 on: June 11, 2014, 10:49:01 pm »
I'll do my best to answer, thanks Ed
While speaking with him on the phone, he asked if I had properly secured the chassis to the frame and ensured no metal was in contact with the chassis that shouldn't be. I had not fully secured the board, but it was resting on the plastic mounting stands all over the frame. He said he blew out a board once by letting it touch the frame, so he thought it was a possibility.
the reason i ask is easy u touch any hot chassic to ground and u WILL have a very beautifull black mark and a few blowen trace's,plus a black mark on the chassic pan..is this what u are seeing ?
No, no black marks or blown traces, and the damage happened after about 5 minutes of running. The resistor/capacitor gradually got hotter and hotter until there was a blow (from what I could tell). Sounds like the chassis wasn't touching the frame based on your comments. That's a good thing.
Game still plays fine blind, no issues from what I can tell. I have a Hantarex Polo 25 that I'm told requires no isolation, I could hook it up again to test it if you want.
Not sure what a Varic is... maybe Variac? If so, I don't have one no sorry  :(
..but i will hand u a piece of advice 60 watt light bulb >yes real bulb<,it is to used as a fuse,reason is if u have problem we can better save u the money on another set of part's.
Sorry, you lost me a bit here. Not sure what you're suggesting, don't forget I'm a noob still learning this stuff. I've seen a bulb trick used in TV repair in place of a resistor, but that was once long ago. If you could clarify that would be great.
As for parts, here's what I ordered so far:
(1) 25W, 150 ohm resistor to replace the tall white one that blew/cracked. The original was 25W, 140ohm, but I'm told this one is okay. It arrived today, cost $1.29
(1) 470uF, 200V capacitor to replace the main cap that blew
(1) C5296 Transistor to replace Q401, which tested bad
(1) C2688 Transistor to replace Q803, which tested bad
So far that's all I ordered. Everything else I tested (diodes, resistors, etc) all came up good after I removed and tested them. I only tested the components around the power/flyback areas.
My plan is to reterminate the Marquee and Switching PS to the incoming AC (taking them off the transformer). This will leave only the chassis power supply coming off the transformer on that side at the top (the 6V to coin door will still be on that side, but on the bottom from what I can tell). Is it okay if I just cut and cap the wires going coming off the transformer to the Marquee and Switching PS for now, and re-terminate them incoming AC using new wiring?
« Last Edit: June 11, 2014, 10:51:57 pm by MaxAsh »
ed12
« Reply #39 on: June 11, 2014, 11:26:45 pm »
the answer to the bulb question is it goes in place of the fuse >main fuse<
it act's as a load,if it light's bright = dead short..simple.. if it is dim
then it is under load..save's replacing a wack of part's
so in short u solder 2 wire's to the bulb
1=outside ring
1=center tab
solder to the fuse holder
u are gold....
ed
