Author Topic: Ms pacman help  (Read 4439 times)
perkwes
  • Last login:October 24, 2015, 11:09:56 am
Ms pacman help
« on: June 06, 2014, 11:10:54 am »
So I'm kinda new to the arcade seen as far as restoring them , so I picked up a ms pacman upright for $75 it came complete with all orginal components other than the monitor was new.  So the guy told me he bought this and could never get it to work,  he said the monitor was good the pcb was tested and working. And he also bought a new power supply.  So if all that stuff is true that leads me into the wiring ? I will post some pics later.  But any tips you guys could give me would be great since I have never took on a project like this before
jennifer
Re: Ms pacman help
« Reply #1 on: June 06, 2014, 11:48:24 am »
    Does it come on at all ?..... There is a safety interlock switch on the back door, if the door is off you have to pull the switch out into service mode, With that said the edge connector, and traces on the pcb is worth taking a look at, they are problematic.
perkwes
Re: Ms pacman help
« Reply #2 on: June 06, 2014, 01:04:06 pm »
To be honest I haven't tried anything yet just brought it home this morning .  I will take a look at it though.
perkwes
Re: Ms pacman help
« Reply #3 on: June 06, 2014, 01:19:05 pm »
Also how hard is it too Change out the wiring harness?
ed12
Re: Ms pacman help
« Reply #4 on: June 06, 2014, 01:26:26 pm »
are u going to mame it ?
or use a multi board ?
if u are leaving it origanal then repair the harness
ed
perkwes
Re: Ms pacman help
« Reply #5 on: June 06, 2014, 02:08:50 pm »
Plan was to leave it as original as possible
perkwes
Re: Ms pacman help
« Reply #6 on: June 06, 2014, 09:50:02 pm »
So it looks like previous owner installed a pac power switcher kit from the real bob Roberts .  It looks like a mess .  I'm not sure if this typical but he cut off the original connector and soldered his leads to the pac power kit ?
ed12
Re: Ms pacman help
« Reply #7 on: June 06, 2014, 10:14:52 pm »
well with out pictures here?,
i will through in a guess.
the old header was bad >common< for it's age.
and the other person did not want to spend the extra buck or 2 to get the nessary header's,
or they did not have the nessary tool's to do the job.
your task now if u want it origanal as u said u did
is to track down the header's and pin's,and put them in.
it is just not that hard of a job
ed
perkwes
Re: Ms pacman help
« Reply #8 on: June 07, 2014, 12:40:48 pm »
Alright so I checked the switcher I'm getting proper voltage out of it. When I power up I can hear the monitor turn on.  But no picture or sound. I found wires coming from the monitor not landed anywhere .  What are they for do I need these hooked up ?
ed12
Re: Ms pacman help
« Reply #9 on: June 07, 2014, 12:57:31 pm »
ya that looks like your r/g/b/gnd/sync
ed
perkwes
Re: Ms pacman help
« Reply #10 on: June 07, 2014, 01:04:03 pm »
So where do those wires go ?
ed12
Re: Ms pacman help
« Reply #11 on: June 07, 2014, 01:26:21 pm »
on your wells monitor
u will see a molex plug with 7 pins
ia any thing hooked to it ?
as it should be from left to right >looking from the back<
r/g/b/gnd/sync-/sync+
with a space betwen gnd and the first sync
might even be marked on the board :50/50 there:
ed
perkwes
Re: Ms pacman help
« Reply #12 on: June 07, 2014, 02:01:48 pm »
Yea there hooked up to the monitor but not tied in on the other side not sure where they go
ed12
Re: Ms pacman help
« Reply #13 on: June 07, 2014, 02:19:00 pm »
so if they are hooked to the monitor?
then they are free flying ?
u need to get a ms pacman schmeatic
and find the r/g/b/gnd/sync pin's and ties them in there >to the header plug<
ed
perkwes
Re: Ms pacman help
« Reply #14 on: June 07, 2014, 02:32:06 pm »
Yea that's what I assumed but just wanna to double check
ed12
Re: Ms pacman help
« Reply #15 on: June 07, 2014, 02:35:08 pm »
also look for an aux board ?
it should be there..it will normaly hook to the board's header
and then the harness will hook to it..
leaving that aside
17=sync
u=blue
16=green
t=red
the top side start's 1-xx
the bottom or solder side start's a-xx
all pins from the top side
start from left to right
ed
perkwes
Re: Ms pacman help
« Reply #16 on: June 07, 2014, 07:40:01 pm »
Ok I will start looking at that tommorw .....but I should have still got sound right just no video
perkwes
Re: Ms pacman help
« Reply #17 on: June 07, 2014, 07:44:44 pm »
As far as the aux board it is connected by a ribbon cable
ed12
Re: Ms pacman help
« Reply #18 on: June 07, 2014, 08:30:59 pm »
sound loop's through the aux board on f @ h
ed
perkwes
Re: Ms pacman help
« Reply #19 on: June 08, 2014, 09:49:33 am »
So the sync wires just tie into the main harness if the pinout I was looking out was correct
ed12
Re: Ms pacman help
« Reply #20 on: June 08, 2014, 12:19:37 pm »
can u upload picture's ?
this would help greatly
ed
perkwes
Re: Ms pacman help
« Reply #21 on: June 08, 2014, 12:38:28 pm »
Yea I will what all do you want me to take pics of ?
ed12
Re: Ms pacman help
« Reply #22 on: June 08, 2014, 12:45:20 pm »
the game board and the harness >point towards the end that is to plug into the game board<
ed
ed12
Re: Ms pacman help
« Reply #23 on: June 08, 2014, 04:03:47 pm »
ok from what i can see u do not have the adapter board that they sent out with that machine,instead u have a modified header board..we did that back in the day,to make the cab's more unverisal.
i will post u the pinout and or .zip it for u and send it to u.
the harness is there buying a new 1 will just open a can of worm's u do not want to get into
save the $$$.
if u are going to leave it mspacman/pacman/donkeygong,then we will just redo the wiring
i trust u can solder ? and have a meter ?,
if so u are gold
ed
perkwes
Re: Ms pacman help
« Reply #24 on: June 08, 2014, 04:07:26 pm »
Yep I can
ed12
Re: Ms pacman help
« Reply #25 on: June 08, 2014, 04:46:20 pm »
ok i need u to lookie it over >the manual<
yw btw.
what we want to do is remove 1 of the hearder's
and olny come off of the main board with a single header.
now most important
top side = part's side = 1-xx
bottom side=solder side = a-z
alway's left to right,use the main board for refernce,it is in the picture that show's
the header's..-5v or -12v is not used at all.
what we want to do
is remove the all of the wires and start freash >about 3hr's given the chat time<
now what we want to do also
is group the wire's
ie power supply = group 1
control's = group 2
coin door = group 3
monitor = group 4 r/g/b/gnd/sync
speaker =group 5
once this is done u are 1/2 there
ed
perkwes
Re: Ms pacman help
« Reply #26 on: June 08, 2014, 06:25:23 pm »
Ok I started but just a quick thought that header was bought to be able to use a switcher
ed12
Re: Ms pacman help
« Reply #27 on: June 08, 2014, 07:05:23 pm »
thats fair enough
but unless u are planning on installing board's that need to switched in  and out ?
it is not required..
our quest here is to get the machine running again..
if u have ever seen a jamma harness they come off in groups
this is the best effect..no fuss no muss
ed
