Author Topic: SOLVED: Getting started with layouts. Background picture not showing.  (Read 3910 times)
jimmer
  • Last login:February 17, 2025, 02:48:38 pm
  • I want to play Defender like at the arcade.
I downloaded a couple of layouts: streetfighter and pacmala.
In malatree I've chosen different layouts for diffferent gamelists.
Using layout editor I choose my background file but it doesn't show up. In the same background edit window, if I change the backround colour, that works OK.
any ideas?
« Last Edit: June 06, 2014, 07:26:56 am by jimmer »
On forums jimmer speaks for himself as a Defender fan, not as proprietor of www.jbgaming.co.uk  << Is that advertising or disclosure ? or both ?
  • Last login:December 10, 2025, 07:49:38 am
Re: Getting started with layouts. Background picture not showing.
« Reply #1 on: June 04, 2014, 09:07:54 am »
It's usually a format thing.  Mala prefers 24-bit PNGs.  I've had to open pics in editing software and resave them as 24-bit before (usually resize them to the resolution I'm running Mala at for good measure).
If these are already finished layouts someone uploaded though, then it probably isn't a format issue.
Just to be clear, you're saying that it doesn't even show up in Layout Editor, correct?
If it shows up in layout editor, but not when Mala is running, it's usually a path issue.
When having Mala switch layouts based on gamelist, the layout name and folder the pic is in need to be formatted like: emulator_gamelist
ex. mame_beatemups
The wiki is here: http://wiki.arcadecontrols.com/wiki/Mala_Layout
« Last Edit: June 04, 2014, 09:30:00 am by BadMouth »
jimmer
« Reply #2 on: June 04, 2014, 11:13:57 am »
Thanks, got it working.
I had tried putting the layout folder in /templates  and putting the png in Mala root, but not the folder in root.
