Author Topic: Monitor won't turn on, Board fried?  (Read 3005 times)
Jetto Funk
  • Last login:April 09, 2013, 03:10:28 pm
  • Moo
« on: December 06, 2003, 11:28:14 am »
Ok my mame machine monitor doesn't work, I had it shipped here after a year and a half in storage and now it won't turn on, my buddy tried trouble shooting it a bit, after turning the machine on and having power running into the arcade machine he went to discharge the monitor and nothing happend, he said that no power was going to the monitor and he thinks my board could be fried. I don't know jack about monitors but what do yall think?
My monitor is a Zeneth and the OEM# is 138032, does anyone know where I could get a new board for it if this is the problem?
menace
Re:Monitor won't turn on, Board fried?
« Reply #1 on: December 06, 2003, 11:33:55 am »
post a pic--that way we can identify what chassis (the board) you have.  Also, check for loose connections on the board and burn marks to see if something went pop (you never know).  also check your fuses on the monitor and in the cabinet.
Ken Layton
  • Guru
  • Technician
« Reply #2 on: December 06, 2003, 11:56:37 am »
Check for signs of mice in the cabinet. Mice eat wiring and pee on circuit boards! If the game has been in storage was the storage space heated? Monitors and moisture don't mix.
Jetto Funk
  • Moo
« Reply #3 on: December 06, 2003, 12:40:03 pm »
here's some pics, my buddy did mention a small burn mark on the board but he said it could've been from the heat since they get hot, not sure where the burn was at.
Here's a few pics
Jetto Funk
  • Moo
« Reply #4 on: December 06, 2003, 12:41:41 pm »
sorry about the bad pics, havn't taken the board out of the machine yet, not too comfortable messing around with it myself
Jetto Funk
  • Moo
« Reply #5 on: December 06, 2003, 12:43:27 pm »
last one, dunno if you can tell anything by these pics but if it helps it used to be street fighter two (jamma)
Ken Layton
  • Guru
  • Technician
« Reply #6 on: December 06, 2003, 01:44:29 pm »
Looks like one of the Kortek/Imperial/Sharp Image/Penn-Ray monitors.
Jetto Funk
  • Moo
« Reply #7 on: December 06, 2003, 01:58:54 pm »
dunno, the monitor itself has a zenith sticker on the back of it....
SirPeale
  • Green Mountain Man
« Reply #8 on: December 06, 2003, 03:22:28 pm »
That's just who made the tube.
Jetto Funk
  • Moo
« Reply #9 on: December 06, 2003, 03:39:23 pm »
so uhm, any idea where I could get one of those boards?
Will it have to be a specific board or could I get any kind of board?
APFelon
  • Last login:July 04, 2024, 08:51:53 pm
« Reply #10 on: December 06, 2003, 06:09:25 pm »
Check the 110 to the monitor.
Check the chassis for a blown fuse.
"Nothing happening" during monitor discharge is normal sometimes... No pop, no nothing. That didn't mean it didn't have a charge.
Look for "glow" at the neck.
Check the silly stuff first before you start counting the couch coins for a new chassis. :)
APf
And how!
I liked that so much, I had to quote it. :)
Jetto Funk
  • Moo
« Reply #11 on: December 06, 2003, 06:20:50 pm »
no glue and the fuses are good  :(
Ken Layton
  • Guru
  • Technician
« Reply #12 on: December 06, 2003, 06:23:16 pm »
Get either a multimeter or one of those neon test lights and test the power at the monitor power cord  connector to see if AC power is making up to the monitor. If not then there must be a blown fuse in the bottom of the game somewhere or the isolation transformer is bad or possibly has a wire broken off it. If power is getting to the monitor power connector then something is wrong on the monitor circuit board (a.k.a. "the chassis"). There are several persons/companies who do monitor chassis repair on the newsgroup rec.games.video.arcade.collecting who can fix your chassis if you send it to them. Usual cost to repair is in the $50 to $100 range.
