Author Topic: TIP: How to install GroovyArcade from USB  (Read 6132 times)
Whipon
  • Last login:May 18, 2015, 11:32:08 am
« on: May 22, 2014, 05:58:09 pm »
Good afternoon!.
I just wanted to share a little but useful tip.
Some weeks ago, when I was ready to install GroovyArcade I didn't had any CD to burn it.
So I needed to install it from an USB Pendrive.
Searching the web I found the perfect solution:
USBWriter:
http://sourceforge.net/projects/usbwriter/
This program is very easy to use, just point it to your Groovy ISO, then your USB Flash drive, click write and there you go.
A bootlable USB drive ready to install Groovy goodness in any computer.
I think this info may be useful.
Regards and thanks a lot to everyone involved in this project.
Whipon.
Calamity
  • Moderator
  • Last login:Today at 05:45:19 am
  • Quote me with care
Re: TIP: How to install GroovyArcade from USB
« Reply #1 on: May 23, 2014, 11:31:06 am »
Hi Whipon,
Thanks for the tip. If you feel like adding a little entry to the wiki in the google code site, it will be welcome. I'm also thinking of the joystick configuration. Just a few lines explanation should be enough.
Steps to create a log:
cools
  • Last login:August 19, 2025, 04:19:37 pm
  • Arcade Otaku Sysadmin
    • Arcade Otaku
« Reply #2 on: May 23, 2014, 03:37:25 pm »
Indeed, it took me half a dozen attempts and a couple of hours messing around to figure out a decent tool to do this a couple of weeks ago, would have been useful ;)
Whipon
« Reply #3 on: May 28, 2014, 05:55:51 pm »
Sorry, I've been busy these days.
You're welcome!.
I will add some lines to the wiki then, I'm glad you liked it ;).
EDIT: I had to leave a comment, since I don't have permissions to edit it.
Regards.
« Last Edit: May 28, 2014, 06:09:05 pm by Whipon »
