Author Topic: Check out this place where I found all these cool DOS programs....  (Read 3289 times)
ark_ader
  • I glow in the dark.
So I open some boxes I have in storage, and I find this cool aluminium case with some hard drives in there.  Most of them were the stock xbox drives I pulled, but there was this one Fujitsu 4.3 looking lonely so I decided to fire it up and have a look inside.  Low and behold it was my long lost DOS programs I had in my old 486DX50!  :woot
So I download DOSBOX and D-Fend and get it all wooking and play some LHX.  But something isn't right as the graphics emulation is fine, but the sound it all choppy.  I tried everything in the readme and various youtube and DOS forums but I cannot get anything to work.  I think the PC is too fast, so I tried a VM and plopped DOSBOX in there to no avail.
Is there any DOSBOX gurus out there that can help me get LHX to run in full SoundBlaster Pro glory?
  • Last login:Today at 12:52:28 am
Re: Check out this place where I found all these cool DOS programs....
« Reply #1 on: May 21, 2014, 03:11:45 am »
You know, with older games instead of trying to install them manually I usually try to find a torrent online.  Because the average pc user today is what I like to call "dos retarded" typically when you grab a dos game off of a torrent it's already packaged with dos-box and has a batch file setup to launch straight into the game with the proper blaster settings.
Long story short the best way to setup dos-box is to get someone else to do it for you.  ;)
What all did you find on it, just out of curiosity?
ark_ader
« Reply #2 on: May 21, 2014, 03:28:30 am »
Heck if you are my age, then the blaster settings are so well burned in that it is easier to remember than your social security number.
I'll make you a list.  The Dig is in there also my modded Xwing with 1000 tie fighters.  Imaging 100000 tie fighters right now.
Torrents are fine with console stuff but with PC games, can be more problematic then they are worth.  :dizzy:
« Reply #3 on: May 21, 2014, 03:43:48 am »
I've had really good luck with the torrents.  It's just important to get it off a reliable site.  Ironically probably the best one is the infamous ---No torrents please - thanks!---.
Heh, I wonder if I still have my Quake mods lying around.  They were on a floppy so I don't know how in the world I would read them, but it would be nice to see how far my modding/hacking has progressed.
I got into the tail end of DOS gaming.  I can remember monkeying with the sound-blaster settings on a few games but by that time most games would configure the card automatically.  I can remember having trouble with sound in MAME though.  :)
JDFan
« Reply #4 on: May 21, 2014, 10:22:48 am »
Just downloaded from http://dosgamer.com/lhx-attack-chopper/ and installed using d-fend reloaded and after going into the sound options and turning sound on (was off by default) it is working fine here. Here is a screen of the various d-fend reloaded settings it created when installing hopefully they will help. Also here is a printout of the .conf file that d-fend reloaded created.
Code: [Select]
# This DOSBox configuration file was automatically created by D-Fend Reloaded.
# Changes made to this file will NOT be transfered to D-Rend Reloaded profiles list.
# D-Fend Reloaded will delete this file from temp directory on program close.
# Command line used when starting DOSBox:
# -CONF "C:\Users\JDFan\AppData\Local\Temp\LHX.conf" -NOCONSOLE
# Config file for profile "LHX"
[sdl]
fullscreen=true
fulldouble=false
fullresolution=original
windowresolution=original
output=surface
autolock=false
sensitivity=100
waitonerror=true
usescancodes=true
priority=higher,normal
mapperfile=C:\Users\JDFan\D-Fend Reloaded\mapper.map
[dosbox]
machine=svga_s3
captures=C:\Users\JDFan\D-Fend Reloaded\Capture\LHX\
memsize=32
[render]
frameskip=0
aspect=false
scaler=normal2x
[cpu]
core=normal
cputype=auto
cycles=auto
cycleup=500
cycledown=20
[mixer]
nosound=false
rate=44100
blocksize=2048
prebuffer=10
[midi]
mpu401=intelligent
mididevice=default
midiconfig=
[sblaster]
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
sbmixer=true
oplmode=auto
oplrate=44100
oplemu=default
[gus]
gus=true
gusrate=22050
gusbase=240
gusirq=5
gusdma=1
ultradir=C:\ULTRASND
[speaker]
pcspeaker=true
pcrate=44100
tandy=auto
tandyrate=44100
disney=true
[dos]
xms=true
ems=true
umb=true
keyboardlayout=US
[joystick]
joysticktype=none
timed=true
autofire=false
swap34=false
buttonwrap=false
[serial]
serial1=dummy
serial2=dummy
serial3=disabled
serial4=disabled
[autoexec]
@echo off
SET PATH=Z:\
keyb US 437
mount C "C:\Users\JDFan\D-FEND~1\VIRTUA~1\"
mount D "C:\Users\JDFan\Desktop\lhx\"
echo.
D:
cd\
Z:\config.com -securemode > nul
LHX.EXE
exit
ark_ader
« Reply #5 on: May 22, 2014, 05:58:35 am »
I lied. The problem is with Elite Frontier.  I got LHX working with adlibsound vga in the command line.
Thanks for the configs and I will use them.  :applaud:
lamprey
« Reply #6 on: May 23, 2014, 01:35:40 pm »
OMG, I just had a mini-flashback of trying to get games running in DOS and Windows pre-direct-everything-is-handled-for-you. *shudder*  >:D
