Author Topic: How to use WinUAE Loader without database  (Read 3639 times)
EMDB
  • Project RetroCade
« on: May 18, 2014, 03:47:39 pm »
I want to use WinUAE Loader to launch WinUAE (obvious) to have ESC as exit and simulate the mouse with my second joystick. I can't get this to work with AutoHotKey myself. I just want a hand full games to run so I don't want to use any of the supported game sets but directly launch my own disk images. Can this be done?
headkaze
  • 0x2b|~0x2b?
Re: How to use WinUAE Loader without database
« Reply #1 on: May 18, 2014, 07:18:38 pm »
You can create a bunch of shortcuts for each game.
EMDB
  • Project RetroCade
« Reply #2 on: May 19, 2014, 05:15:33 am »
You mean use the 'Generate UAE Files' button in the Config tab? It creates one config file per game, not a bunch per game?
How should I launch the games than? WinUAELoader -rom "romname.adf" or are the key mappings added to the config file and should I just call winuae -f gamename.config -0 gamename.adf?
headkaze
  • 0x2b|~0x2b?
« Reply #3 on: May 19, 2014, 11:45:18 am »
WinUAELoader -rom "romname.adf" should work. Check the parameters by launching WinUAELoader by itself.
Unfortunately I use my own key mapping system because to use WinUAE's built in key mapping I would have to do a lot of extra work. I do actually have a lot of that extra work done but at the moment it's still not fully implemented.
EMDB
  • Project RetroCade
« Reply #4 on: May 19, 2014, 12:32:33 pm »
Thanks. Should I still create the configs per game? And should the kickstart roms be in the WinUAELoader\WHD\Devs\Kickstarts folder for this?
Is there a WinUAELoader log file?
« Last Edit: May 19, 2014, 12:41:24 pm by EMDB »
headkaze
  • 0x2b|~0x2b?
« Reply #5 on: May 19, 2014, 12:49:44 pm »
Yes there is a log file. Read the ReadMe.txt file that comes with the download or check out the notes section here
EMDB
  • Project RetroCade
« Reply #6 on: May 19, 2014, 06:11:46 pm »
I set up WinUAELoader like this:
I generated the config files for the games in the Disks folder.
I tried both
WinUAELoader -rom "rickdangerous.adf" and WinUAELoader -rom "f:\emulators\Amiga\WINUADE2800\Disks\rickdangerous.adf"
in both cases the log file says:
20-5-2014 00:10:46: WinUAELoader v1.78
20-5-2014 00:10:46: Error: "rickdangerous.adf" Not Found.
20-5-2014 00:10:46: Error Launching: "rickdangerous.adf"
20-5-2014 00:10:46: Exiting.
 :dizzy:
EMDB
  • Project RetroCade
« Reply #7 on: May 19, 2014, 06:54:59 pm »
I found a workaround. I guess WinUAELoader is only meant to be used with one of the databases. So I picked GameBase as it contains the largest number of games. I set the path to a newly created folder:
I looked in GameBase.xml and found the path and name for Rick Dangerous. I created Rick Dangerous.zip in the folder GameBase\R\ and launched WinUAELoader with
WinUAELoader -mode GameBase -rom "rick dangerous.zip"
Still no go. Than I tried
WinUAELoader -mode GameBase -rom "Rick Dangerous.zip"
and voila. WinUAE was launched, Rick Dangerous booted and I could move the mouse with my second joystick and quit with ESC. Thats all I need. Well... I would like the pause function of WinUAE to be mappable to a key (preferable 'P') as I try to use the MAME keyboard shortcuts for all my emulators so they all work with my admin buttons. So far I managed to remap all emulators (Odyssey 2, Atari 2600, Colecovision, SNES, Sega MegaDrive, Sjaak's Fix It Felix Jr, Flappy Bird Arcade Edition, Space Commander) via their options or with a small AutoHotKey script. WinUAE was the only one I could not succeed with but thanks to HeadKaze's WinUAELoader I finally got it working now.  :applaud: :cheers:
« Last Edit: May 20, 2014, 12:51:45 am by EMDB »
headkaze
  • 0x2b|~0x2b?
« Reply #8 on: May 20, 2014, 01:51:35 pm »
I'm glad you got it working  :cheers:
Yeah the "Generate UAE Files" is actually a different application I integrated into WinUAE Loader. It is just meant for people who need to generate a uae for each game for sets such as TOSEC.
Yes for GameBase/WHDLoad/SPS/DemoBase you need the GameBase databases. The reason is many games need particular settings to launch and this information is in the database.
EMDB
  • Project RetroCade
« Reply #9 on: May 20, 2014, 04:24:28 pm »
Thanks for your response. What about my little feature request: remapping the pause button just like the exit. I think this is the only thing making WinUAE fully arcade ready...
