Author Topic: Mini-PAC question regarding ground and 5v wiring  (Read 1206 times)
markc74
  • Last login:November 27, 2025, 06:32:39 pm
  • Flipping out
« on: May 06, 2014, 03:28:50 am »
Hi all – I’m hoping Andy (or someone) can help me with a question I have about the Mini-PAC.  I’m specifically using the older model that has a PS/2 keyboard connection.
I’m planning on using swappable controls with the mini-PAC wired to a jamma edge connector. Each swappable control panel will connect via a specially wired jamma connector. The problem I’m having is that I ‘ve ran out of available pins.
Looking at the minipac pinout (http://www.ultimarc.com/Mini-PAC%20Manual1.pdf) it seems I have three separate 5v connections and four separate ground connections.
So – my question is – can I join all the grounds together onto one pin, likewise can I join all the 5v’s together which would mean five overall less connections needed?  If I did would there be any problems with this? i.e. would I have problems with the trackball and/or spinner if everything uses the same ground and power lines?
Any help would be much appreciated before I start on a massive soldering job!
surface tension
  • Last login:July 01, 2018, 08:45:48 am
  • feel the tension...
    • surface tension tables
Re: Mini-PAC question regarding ground and 5v wiring
« Reply #1 on: May 06, 2014, 08:21:47 am »
Yes, no problem with that. You can connect all the 5v together and the 0v together.
  • Last login:Today at 09:58:32 pm
« Reply #2 on: May 06, 2014, 09:04:25 am »
Be sure you don't exceed the current capacity of the remaining wire.
markc74
  • Flipping out
« Reply #3 on: May 06, 2014, 10:37:12 am »
Aces - thanks for the speedy replies chaps!
