Author Topic: F-15E Hawk Tactical Control Stick Suncom Technologies Flight Simulator Joystick  (Read 7887 times)
janey6152
  • Last login:April 02, 2025, 09:49:52 pm
Will this work for Mame and Hyperspin ?????
 Not sure if i should purchase this .
 thanks
 janet
ark_ader
  • I glow in the dark.
 thanks
 janet
Link please....
Generic Eric
 thanks
 janet
Assuming  you are talking about this
Not for mame or hyperspin.  That is for flight sims.
You want a stick.  You could get something like this for less than $10
Start here: http://newwiki.arcadecontrols.com/index.php?title=Main_Page
or here:  http://www.amazon.com/Project-Arcade-Build-Your-Machine/dp/047089153X/ref=sr_1_1_title_1_pap?s=books&ie=UTF8&qid=1398805614&sr=1-1&keywords=project+arcade
janey6152
Yes that's the one .. Ohhh Thanks was almost gonna buy it.
 I have a 2 joystick. I want to put a flight trigger stick on my Control panel.
 Thanks again
 Janet
Generic Eric
 Thanks again
 Janet
Maybe this is more what you were after?
http://groovygamegear.com/webstore/index.php?main_page=product_info&products_id=319
If you really want a flight stick  on your panel, go for it.  Do you have pictures of your existing cabinet?  What game do you want to play with a flight stick on your arcade control panel?
janey6152
 I'm upgrading and want a spinner. flippers and plunger for the pinball too.
I think i need to add more buttons too  Below is a yellow button that powers on the PC.
janey6152
@ Generic Eric  I have 2 of these 8 way Joystick can i then mode this and put on the Tron Handles ??
Generic Eric
That is a tall order. Just tackle it one piece at a time.
If you look at that link for the blue tron handle, you'll see the following
Quote from: groovygamegear
Accessories for this item are available, including a Switch Assembly, Graphic Backplates, and in the not too distant future, mounting hardware to adapt it to standard joysticks, etc.
Quantities are currently limted. We'll have another production run made if there is high demand, but with this kind of niche' interest part it's not guaranteed. So be sure to stock up!
I haven't done this, but it seems you'd want something with a hollow shaft so you can feed the wire through.  Again I haven't done it.  Good luck.
janey6152
Generic Eric
Or Should i purchase this one ???
http://na.suzohapp.com/amusement_products/joysticks/95-0393-00?SS=ON
Hard to say.  That isn't something I would do, not that you can't though.
Yeah, I put a flightstick on my CP, and I've found that I just about never use it, plus it sticks way up.
Just about any joystick that shows up as a USB game controller will work with mame, though. If it's a flight stick, you'll have a ton of extra "buttons" that represent the hat switches, triggers, etc.
There's not many games that I like that require a flight stick. Might want to run Romlister to get a list of the roms that would use one and see if there's enough there to justify it.
janey6152
Thats true Ok.. Maybe i should skip it then.
 Thanks Guys...
 J
Xiaou2
  • Last login:February 28, 2026, 09:51:52 pm
  • NOM NOM NOM
Hello Janet,
  Nothing wrong with a trigger stick on a control panel.   Dont listen to these naysayers.  Base your decisions on what you would prefer playing:
 As It really depends on what kind of games you wish to play...
 If you want to play  Afterburner II, Space Harrier, or any similar analog game... the you want an analog trigger stick for best control.  (the joystick you posted pics of last)
 If you want to play  Mad Planets, Discs of Tron, Tron (if you modify the grommet or use a diagonals hack),  Satans Hollow, Gorf, and many other digital games..   then you want a leafswitch or microswitch trigger stick... such as:
http://na.suzohapp.com/amusement_products/joysticks/50-9975-00?SS=ON
 Some of these guys may try to talk you into one of these multi-function joysticks.   While they can do both analog and digital...  they are expensive, and they do not do either digital or analog very well.
 Any analog joystick for a PC can be used with Mame.   They generally are not very strong however...  so its best to use a real arcade joystick, rather than a hacked PC controller.  (PC stuff is generally made of plastic, and so it bends and breaks easily...  where as Arcade controls are mostly made of metal, and are very strong and durable.
 If you didnt know:
 Analog = A range of values..  such as  1,2,3... 10     ...Such as a gas pedal.
 Digital   = On / Off     ...such as a simple lightswitch or push button.
 Analog controls mostly use Pots.  They are round in shape (with exception to sliders),  and the shaft turns.
 Digital Controls mostly use microswitches, or leaf switches.
 I personally prefer digital trigger stick for most games...  but certain games, such as Afterburner II, really require an analog stick.   Analog sticks can also be used for driving games.  (Not as nice as a steering wheel... but it can be usable)
 Mad Planets, on its own, is well worth the addition of a Trigger stick + spinner.
ark_ader
+1 what everyone said.
Find a flight stick you like and clamp to your CP.
If you do the clamp right, you can add a racing wheel too.
Xiaou2
  • NOM NOM NOM
 Almost forgot Janet...
 Those blue ball top sticks are really nice Rotary Joysticks.  They are used in games like Ikari Warriors..   Where you can move the stick to walk.. and twist the stick to aim in a different direction than you are walking.
 Id use those for the games that use Rotary controls.   If you do not want to.. then re-sell them to someone, or trade for something else.  They are valuable, and not always easy to find them..
  • Last login:Today at 05:02:13 am
There's a list of rotary games here along with the needed MAME settings.   ;D
« Last Edit: April 30, 2014, 06:45:10 am by PL1 »
