Author Topic: arcade vga woes  (Read 1466 times)
aliea
  • Last login:April 23, 2014, 01:09:12 pm
arcade vga woes
« on: April 20, 2014, 01:23:56 am »
ok! got the arcage vga all set up and installed. installed it on my dvi monitor set up the trimode settings rebooted and it works! pluged in my arcade monitor to the vga port boots through the bios but then when boots widows i get a bit of garbage the no screen just hangs with a blank picture? any idead why or if someone hand the same problem?
twistedsymphony
  • Last login:February 03, 2024, 11:13:51 pm
  • Play stupid games... win stupid prizes.
    • solid-orange.com
    • CollectorsEdition.org
Re: arcade vga woes
« Reply #1 on: April 21, 2014, 11:34:03 pm »
I dont have any experience with arcade vga but what version of windows are you running and are you sure windows is set to 640x480 60Hz?
ed12
Re: arcade vga woes
« Reply #2 on: April 21, 2014, 11:50:57 pm »
look in the fourms and find 15khz.zip or such,it is a proggie we use to make
the converion right
it will help u a ton...
i do not know if it carrys the file or not ?
http://forum.arcadecontrols.com/index.php/topic,66402.0.html
but u will get the idea
i use it in native windows when i am doing ega/cga and or rgb monitor repairs
so i can see xp run
ed
« Last Edit: April 21, 2014, 11:53:54 pm by ed12 »
twistedsymphony
    • solid-orange.com
Re: arcade vga woes
« Reply #3 on: April 22, 2014, 10:08:23 am »
the converion right
so i can see xp run
ed
The whole point of arcade vga is that you dont nedd to use soft15khz... not to mention soft15khz dosnt work in win 7 or 8.
  • Last login:Yesterday at 12:16:10 pm
Re: arcade vga woes
« Reply #4 on: April 26, 2014, 12:21:25 am »
Sounds like you set up the Arcade VGA on the wrong port.  You should set it up on the VGA port (Dsub) and not the DVI port.  Once it's working on the VGA port with another monitor at 640 x 480 with the modified ATI drivers at Ultimarc.com it should work once you plug your arcade monitor in.
DeLuSioNaL29
