Author Topic: .  (Read 33682 times)
ChanceKJ
« on: March 20, 2014, 01:39:22 am »
« Last Edit: March 18, 2021, 11:34:16 pm by ChanceKJ »
ChanceKJ
« Reply #1 on: April 06, 2014, 11:50:57 pm »
« Last Edit: March 18, 2021, 11:34:21 pm by ChanceKJ »
gilligan5000
  • Last login:March 20, 2017, 10:51:59 pm
  • Professional half-asser
    • Sonic Slim Cab
Re: Project: Super PlayChoice.
« Reply #2 on: April 07, 2014, 07:11:57 am »
I'm interested in seeing what you can do with the teensy!
« Reply #3 on: April 07, 2014, 08:05:42 am »
just curious, would you be opposed to making a new base for it to add a little inside height?
ChanceKJ
« Reply #4 on: April 07, 2014, 10:52:58 am »
« Last Edit: March 18, 2021, 11:34:26 pm by ChanceKJ »
Unstupid
« Reply #5 on: April 07, 2014, 05:24:41 pm »
What an awesome idea... Whoever thought of that must be a genius!
I think you are going to run into lag problems with the wireless Air Play -> AppleTV solution.  When I use the airplay feature to mirror my ipad screen through the apple TV there is a good half second of lag which would make playing a video game impossible.
ChanceKJ
« Reply #6 on: April 07, 2014, 06:54:43 pm »
« Last Edit: March 18, 2021, 11:34:33 pm by ChanceKJ »
ChanceKJ
« Reply #7 on: April 08, 2014, 01:22:36 am »
« Last Edit: March 18, 2021, 11:34:37 pm by ChanceKJ »
Louis Tully
« Reply #8 on: April 08, 2014, 04:24:14 am »
« Last Edit: February 12, 2015, 05:02:37 pm by Louis Tully »
Cia91
  • Last login:June 25, 2014, 08:09:54 am
« Reply #9 on: April 08, 2014, 10:13:56 am »
Nice build, why not a Raspberry inside?
ChanceKJ
« Reply #10 on: April 08, 2014, 10:16:10 am »
« Last Edit: March 18, 2021, 11:34:43 pm by ChanceKJ »
ChanceKJ
« Reply #11 on: April 08, 2014, 10:26:56 am »
« Last Edit: March 18, 2021, 11:34:48 pm by ChanceKJ »
ChanceKJ
« Reply #12 on: April 08, 2014, 07:32:45 pm »
« Last Edit: March 18, 2021, 11:34:52 pm by ChanceKJ »
gabrielmtl
  • Last login:March 18, 2016, 10:19:03 pm
  • This is...
« Reply #13 on: April 08, 2014, 07:36:03 pm »
I love your project! Good luck. :cheers:
matt4949
« Reply #14 on: April 08, 2014, 07:57:02 pm »
Cool Idea
I wonder if I could turn one of these into a Madden 92 ?
Just playing, but hey a really cool Idea.
« Reply #15 on: April 08, 2014, 08:15:09 pm »
Side note: I think I've figured a way to chop some height off the NUC. I may be able to get a thermal block from a passive cooling case that I'll mount directly to the massive metal base of the controller. That will remove the fan and cut a third off the height.  I'm just talking to the supplier to try and get my hands on the part.
Its the kind of project that puts ones engineering ability to the test. I know how that feels. So far so good! :cheers:
ChanceKJ
« Reply #16 on: April 08, 2014, 08:19:32 pm »
« Last Edit: March 18, 2021, 11:34:59 pm by ChanceKJ »
Unstupid
« Reply #17 on: April 08, 2014, 09:03:02 pm »
Which one did you get?  The one with the older i3 or newer i5 or the older celeron?
ChanceKJ
« Reply #18 on: April 08, 2014, 09:19:53 pm »
« Last Edit: March 18, 2021, 11:35:04 pm by ChanceKJ »
ChanceKJ
« Reply #19 on: April 09, 2014, 07:09:17 pm »
« Last Edit: March 18, 2021, 11:35:09 pm by ChanceKJ »
ChanceKJ
« Reply #20 on: April 15, 2014, 02:31:30 pm »
« Last Edit: March 18, 2021, 11:35:13 pm by ChanceKJ »
RyoriNoTetsujin
  • Last login:March 23, 2024, 03:55:45 pm
« Reply #21 on: April 15, 2014, 05:10:29 pm »
Hmmm... Very cool project! It'll be interesting to see how this turns out.  :cheers:
I have to say, this is also my primary question. Direct connection from the NUC to a monitor should have absolutely no issues at all, but what are you planning to do to mitigate the lag of the wireless display? Do you have a really beefy wireless router and network setup in your home?
My experience with wireless display is relatively small (a couple of different devices, admittedly I've never messed with AirPlay) but wow, none of it has been good enough to play video games with. That delay would drive me nuts.
ChanceKJ
« Reply #22 on: April 15, 2014, 06:30:12 pm »
« Last Edit: March 18, 2021, 11:35:19 pm by ChanceKJ »
ChanceKJ
« Reply #23 on: April 16, 2014, 12:14:54 am »
« Last Edit: March 18, 2021, 11:35:24 pm by ChanceKJ »
Locke141
  • Never grow up.
« Reply #24 on: April 16, 2014, 05:03:59 am »
I'm loving this idea.
I have a broken NES advantage sitting in a box at my parents house. Perhaps I should do the poor mans version of this with a R-pi and liminit it to the old two button or less systems (Atari 2600, NES, Sega master system, game boy advanced, and so on). The fact that the older systems need less processing power to emulate lends its self will to the limits of the R-Pi.
Can you go in to more details on how you interfaced the Teensy USB Dev Board to the Advantage? Is there a web site you can point to with all the info some one would need readily available?
ChanceKJ
« Reply #25 on: April 16, 2014, 10:33:20 am »
« Last Edit: March 18, 2021, 11:35:29 pm by ChanceKJ »
Draco_Elessar
  • Last login:May 05, 2018, 12:40:02 pm
  • Way too curious for my own good.
« Reply #26 on: April 16, 2014, 10:51:48 am »
Awesome idea! Have you found any heat issues with using the NUC over time?
ChanceKJ
« Reply #27 on: April 16, 2014, 11:11:09 am »
« Last Edit: March 18, 2021, 11:35:34 pm by ChanceKJ »
ChanceKJ
« Reply #28 on: April 19, 2014, 01:59:41 am »
« Last Edit: March 18, 2021, 11:35:39 pm by ChanceKJ »
Unstupid
« Reply #29 on: April 19, 2014, 02:29:47 am »
You got mame running on the NUC yet?  You should be able to test lag once you do.
ChanceKJ
« Reply #30 on: April 19, 2014, 02:48:42 am »
« Last Edit: March 18, 2021, 11:35:44 pm by ChanceKJ »
ChanceKJ
« Reply #31 on: April 19, 2014, 05:29:38 am »
« Last Edit: March 18, 2021, 11:35:49 pm by ChanceKJ »
ChanceKJ
« Reply #32 on: April 19, 2014, 06:01:02 pm »
« Last Edit: March 18, 2021, 11:35:54 pm by ChanceKJ »
ChanceKJ
« Reply #33 on: April 25, 2014, 03:20:06 am »
« Last Edit: March 18, 2021, 11:35:58 pm by ChanceKJ »
Unstupid
« Reply #34 on: April 25, 2014, 11:58:12 pm »
Good news is the lag isn't an issue at all. I might hide an HDMI connection on the back. nothing too intrusive.
I dunno...  I was watching the video and there is definite lag...  You really won't notice until you play some real fast paced games (pac man, racing games etc...)  Took a screen grab and if you look closely the screen on the right is a good ~100ms (hard to measure from a youtube grab) behind.  If you look at the image You can see that the image on the left Mario already hit the block and is already on his way down, while the image on the right shows Mario just leaving the ground.
ChanceKJ
« Reply #35 on: April 26, 2014, 12:01:33 am »
« Last Edit: March 18, 2021, 11:36:04 pm by ChanceKJ »
ChanceKJ
« Reply #36 on: May 03, 2014, 12:37:48 am »
« Last Edit: March 18, 2021, 11:36:09 pm by ChanceKJ »
  • Last login:Yesterday at 10:37:15 am
Re: Project: Super PlayChoice. (FINISHED!!!!)
« Reply #37 on: May 03, 2014, 06:42:02 am »
Very impressive! :cheers:
« Reply #38 on: May 03, 2014, 09:49:04 am »
looks great, I think the grey balltop looks better than the purple one.  :cheers:
 I suppose you tested it enough to discern if air flow/heat is an issue? You said it doesnt get blistering hot, but Im not sure exactly what that means, last thing youd wanna do is start melting that old plastic, lol.   I'd probably try to retro fit a couple of tiny fans in there to push/pull air. and by tiny I mean like  20mm x 20mm x 6mm
Louis Tully
« Reply #39 on: May 03, 2014, 11:21:05 am »
« Last Edit: February 12, 2015, 05:09:10 pm by Louis Tully »
