Author Topic: Genesis/Mega Drive to monitor?  (Read 8918 times)
rowie4life
  • Last login:April 09, 2004, 03:55:52 pm
« on: December 02, 2003, 05:40:08 am »
how to connect a Genesis/Mega Drive to a monitor.
thanx
Rowie
« Last Edit: December 02, 2003, 11:54:21 pm by rowie4life »
Spaced Invader
  • Last login:July 15, 2008, 07:27:49 am
  • Resistance is... probably a good idea.
Re:does anyone know........?
« Reply #1 on: December 02, 2003, 09:40:38 am »
thanx
Rowie
A Composite Monitor? RGB? Arcade? VGA?
Vague title/vague question.  ;)
All Your Base Are Belong To Us!
rowie4life
Re:Genesis/Mega Drive to monitor?
« Reply #2 on: December 03, 2003, 12:23:53 am »
all of them
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
« Reply #3 on: December 03, 2003, 02:03:20 am »
All the info you need is on gamesx.com...specifically check this link out:
http://www.gamesx.com/avpinouts/genesisav.htm
You will be able to hook up to a either a composite monitor (tv), or an an RGB/SCART  monitor (or arcade standard resolution monitor).  To hookup to a computer monitor you will need to use an upscanner (preferably  upscanning the RGB signal rather than the composite signal).
Happy hacking.
« Last Edit: December 03, 2003, 02:04:02 am by Dave_K. »
rowie4life
« Reply #4 on: December 03, 2003, 05:03:39 am »
Thanks for the site Dave_K.
have i done it right
and what goes to the Luma (Y) and Chroma (C)
1.  Blue ...................... 3  Blue
2.  5 VDC ................... 5.  +5v
3.  Green ................... 2.  Green
4.  Comp Video .......... ?.  ???
5.  Sync ...................... 4.  Video/Sync
6.  Audio Mono ........... ?.  ???
7.  Red ....................... 1.  Red
8.  Stereo L ................ 7.  Left Audio
9.  Stereo R ................ 6.  Right Audio
« Last Edit: December 03, 2003, 05:05:45 am by rowie4life »
Dave_K.
    • Arcade Fever
« Reply #5 on: December 04, 2003, 01:11:15 am »
It doesn't look like the genisis supports s-video out, so there is no Y and C.  If you are hooking to an rgb monitor you don't need those anyway.
rowie4life
« Reply #6 on: December 04, 2003, 06:40:49 am »
Would this work...?
Dave_K.
    • Arcade Fever
« Reply #7 on: December 04, 2003, 12:15:21 pm »
The RGB output of the genisis/2 will be at 15.7khz...a VGA monitor will not accept this (unless you have something like an old amiga monitor).  VGA starts at 31.5khz to display a 640x480 signal.  So what you would need is an upscanner inbetween those two connections that take the RGB signal and upscans it to 31.5khz.  The XRGB-2 upscanner is a good example (but not cheap at around $250).
I don't believe you need to hookup the 5vdc (in fact I'd think the 5vdc output on the genisis connector is to power external devices).  So if you were hooking straight up to an arcade monitor (which will accept a 15.7khz signla), then all you need is the R/G/B Gnd and Composite Sync lines (you may also need to put some caps in-line with the r/g/b inputs to brighten it up a bit...see the Game Consoles faq for more info on that.
rowie4life
« Reply #8 on: December 09, 2003, 05:30:06 am »
Ive found two sorts of fingerboard which should i use.
(see above posts please)
« Last Edit: December 10, 2003, 12:43:27 am by rowie4life »
Dave_K.
    • Arcade Fever
« Reply #9 on: December 09, 2003, 12:54:29 pm »
I'm not sure what a jamma fingerboard has to do with you wanting to hookup a gensis to a monitor? Are you saying you have an arcade cabinet?  You seem to be leaving out a lot of details here...
rowie4life
« Reply #10 on: December 09, 2003, 11:09:47 pm »
I not got one yet (arcade machine) so i'm not 100% sure what i
« Last Edit: December 10, 2003, 12:56:48 am by rowie4life »
Dave_K.
    • Arcade Fever
« Reply #11 on: December 10, 2003, 12:56:29 pm »
So I guessed that I needed one (Fingerboard) now I think I don't so what do I need for my Mega Drive 2 (Genesis 2) to a arcade monitor?
Yeah, you don't need to worry about the jamma fingerboard.  If you are hooking up your genisis to a normal arcade monitor (standard res), then just hookup the red/green/blue/ground and sync lines to the monitor inputs.  The sync line will go to the horizontal input.  You may need to put 220uf capacitors in line with the red/green/blue lines to the monitor to brighten up the picture (try first without it and see).
rowie4life
« Reply #12 on: December 11, 2003, 02:15:01 am »
id just though id say thanx
if i cant find a arcade machine would this monitor work alright seens how its 15 khz and not 15.7 khz (or whaever the pal version is)
Dave_K.
    • Arcade Fever
« Reply #13 on: December 11, 2003, 12:30:01 pm »
Yes that monitor will work.  I have a hanatrex 25" polo in my arcade cabinet.  Most people round off the sync rate and just say 15khz, but its the same thing.
