Author Topic: win xp with autostart mamewah questions  (Read 2324 times)
dreamfreak
  • Last login:August 23, 2005, 08:10:58 am
« on: December 02, 2003, 03:39:52 am »
hi,
I use mamewah under winxp and I have mamewah in my autostart
the problem is that mamewah starts and the windows task-list is visible
at this point MWah ist not active
I have to press a mouse button and then everything is ok
what can I do to solve this problem  ???
thx
« Last Edit: December 02, 2003, 03:40:24 am by dreamfreak »
Re:win xp with autostart mamewah questions
« Reply #1 on: December 02, 2003, 04:31:24 am »
Drop me a PM with your email address - I have a version which *may* solve the problem ;)
dreamfreak
« Reply #2 on: December 02, 2003, 06:27:36 am »
I did it
thank you
Frostillicus
  • Arcade Artist
  • Last login:April 18, 2023, 07:36:29 am
    • My MAME cabinet site
« Reply #3 on: December 02, 2003, 11:23:30 am »
can you  make that version available minwah?  I have the same problem.
« Reply #4 on: December 02, 2003, 01:48:35 pm »
dreamfreak: email sent - let me know if it works (btw when you say 'autostart' I take it you mean the Startup folder?)
Frosty: Yes I should've made a download-able version by now, but PM me your email - I am using very nearly all my time cab building atm...
lokki
  • Last login:May 05, 2025, 06:18:51 pm
« Reply #5 on: December 02, 2003, 02:29:19 pm »
Hi,
I have a similar (maybe not related problem).
I have XP set up to autologin. And Mamewah to autostart.
If any key is pressed during the XP startup process.  Mamewah will start but it will not be the active process. have to ctrl tab, to make the active process.
If leave XP alone (don't touch any key or control) Mamewah starts up as expected.
« Reply #6 on: December 02, 2003, 08:00:52 pm »
Hi,
Not sure if that is normal (?)  Does it do the same if you start a program other than MAMEWAH?
slycrel
  • Last login:June 25, 2025, 07:42:34 pm
  • Mmm... Portal.
« Reply #7 on: December 03, 2003, 02:46:24 am »
  I'm having some similar issues, but it happens when I return from a game.  I'm using no name mame, so that could be the problem.  I'll also have to try turning off the show dos box.  More to come when I get more info.  =)
lokki
« Reply #8 on: December 03, 2003, 09:24:18 am »
I don't think I have noticed this on other programs. (but this is a dedicated machine so mamewah is pretty much the only thing running). At first I thought it could be some other application (virus scan/etc) that was also in the startup that was causing the problem. But I removed everything and still have the problem.
dreamfreak
« Reply #9 on: December 03, 2003, 01:14:45 pm »
hi minwah,
I tryed it with your special version but it is the same problem  ???
do you have a different idea ?
by
Dreamfreak
« Reply #10 on: December 03, 2003, 07:32:57 pm »
hi minwah,
by
Dreamfreak
Sorry I just replyed to your mail, but couldn't quite remember who you were here  ::)
Does it run OK if you don't have it in your startup?  And is it in your Startup folder or are you running as shell?
dreamfreak
« Reply #11 on: December 04, 2003, 02:37:32 am »
good morning,
it runs normal when I start it
if it
« Reply #12 on: December 04, 2003, 07:08:06 am »
good morning,
if it
dreamfreak
« Reply #13 on: December 05, 2003, 10:44:41 am »
hi,
I
