July 20, 2025, 10:52:12 pm
When doing this you are actually tapping into the supply from the outlet not the PSU - so it doesn't matter what size the PSU is since it is not taking any wattage from the PSU (it is splicing into the incoming wiring before it goes to the PSU.) That said what you do need to be concerned about is that the wire coming from the outlet plug to the system is thick enough gauge to pull enough wattage for both the computer and the monitor ( usually not a problem unless using a very cheap PSU cable but best to calculate the total wattage it might pull from the outlet and make sure the cable is rated to handle at least that amount to be safe.
is there a diagram on wiring this?
