Author Topic: FS: Wico Leaf Joysticks, Other Sticks, & Parts [Salt Lake City, UT, USA]  (Read 1669 times)
benll64
  • Last login:November 07, 2024, 03:37:15 pm
Over the years I've collected various spare joysticks and parts. I need to clear them out, and am hoping some of the random parts will be useful to someone. Prices as listed; if no price, make an offer. Shipping quotes will be given if you PM with a ZIP code. Thanks for looking.
[2] Wico 8-Way Leaf Switch Sticks: These are the original, classic Wico sticks. Cosmetically, one balltop is in excellent shape and the other is OK - could use some cleanup/polishing. Both have quite a heavy patina of stain/age on the steel shafts, which you can clean off if you're good at that sort of thing. One is fairly "soft" and the other is quite "firm" due to differences in the age of their rubber centering grommets. Both are complete and funcitonal. Included for good measure are a 3rd Wico balltop shaft and 2 spare leaf switches. For sale as a unit, please. $80
https://db.tt/1UZuYJXR
https://db.tt/LXzUlG53
[4] Happ Ultimate 8-way Sticks: 2 of these have a heavier spring installed; the other 2 have the default lighter spring. They have very good diagonal feedback, so they're great for fighters. All 4 are complete and in good shape, except one of them is missing the dustwasher. 1 for $10, 2 for $18, all 4 for $32
https://db.tt/UIzISsQg
[2] Happ Super 8-Way Shafts and Accessories: These are brand-new stainless battop shafts. Each comes with the shaft, dustwasher, 2 plastic spacers for wood or metal installation, and e-clip. You provide the base unit, switches, and actuator. These shafts are versatile and may work in other units, too. $6 each or $10 for both.
https://db.tt/kbG0lV4y
[1] Unknown molded red balltop shaft and parts: This is an 80's era molded red stick, but I can't figure out what it was used in originally. If anyone reading this knows, please shed some light for the rest of us! It comes with various plastic parts, a metal spacer, and e-clip. Obviously missing the base unit, and I assume it probably used leaf switches. The red part of the shaft is in incredible shape and looks nearly brand-new.
https://db.tt/ZszbZJNZ
[2] Sets of black Triggerstick shells and restrictors: These came off of an original Xenophobe machine. Includes the hollow shell halves, red trigger, and molded rubber 8-way restrictors. For use on a heavy-duty triggerstik base, leaf or microswitch compatible.
https://db.tt/HXe1TcIp
[2] Unknown joystick base units: These appear to be similar to Happ Competition bases, but I'm not sure.
https://db.tt/NlMpV0Ny
[3] Black plastic dustwashers: 1 of the 3 has a slightly larger center hole opening than the others.
https://db.tt/W03cc6iN
404
Re: FS: Wico Leaf Joysticks, Other Sticks, & Parts [Salt Lake City, UT, USA]
« Reply #1 on: January 30, 2014, 10:47:23 am »
just a little fyi. I'm almost positive that the red balltop shaft goes with the happ style bases. Those sticks were very common in early dynamo cabinets, especially the early dynamo capcom cabinets.
see the bastardized street fighter 1 dynamo cab below
benll64
« Reply #2 on: January 30, 2014, 02:52:14 pm »
Hey, thanks.
That certainly does look like it.
