Author Topic: Jamma Harness Question - Noob building first Bartop  (Read 1382 times)
Gluyys
  • Last login:January 24, 2014, 12:05:25 am
« on: January 22, 2014, 07:52:42 pm »
Hey all, I am a noob here and have been working on my first Bartop Build. It is a simple Jamma 60-1 multi-cade, figured I would start small and work my way up to bigger and better games.
But to the point, there are a lot of wires on the Jamma harness that I am not using (like coin door, 2 player buttons, ect.). And in an attempt to conserve space and make wiring my cab easier. I was wondering if it is okay to disconnect the extra wires (disconnect the pins out of the harness, not just cut them off).
I can't really see much being wrong with this. But I figured I would ask to make sure I don't mess anything up before I start disconnecting a bunch of extra wires.
I appreciate anyone's help! And if you have a sweet bartop build that you completed recently, I wouldn't mind a link to check out your work also!
Thank you,
-Tyler
chopperthedog
  • Last login:Yesterday at 09:30:21 pm
Re: Jamma Harness Question - Noob building first Bartop
« Reply #1 on: January 22, 2014, 07:58:03 pm »
Snip away, you could always re solder if needed. My last 3 jamma projects have left me with so much left over wire, next projects I'm just gonna order up some edge connectors and make my own.
good day.
Gluyys
« Reply #2 on: January 22, 2014, 08:05:54 pm »
good day.
Awesome! Thank you very much for the quick reply!
Yeah, only need maybe 1/4 of the wire in the harness lol
