Author Topic: Powering a WG D9200  (Read 1066 times)
Bunghoolio
  • Last login:October 02, 2015, 06:04:30 pm
  • St. Paul
Powering a WG D9200
« on: January 08, 2014, 08:03:20 pm »
Noob question, hooking up my monitor for the first time. Should I use an inline fuse on the black or white wire, or just cut up an old PC cord and tie in the three wires (black white green)direct to AC power?
Damnit! I'm running low on TP
grantspain
Re: Powering a WG D9200
« Reply #1 on: January 10, 2014, 04:25:09 pm »
you can go direct to AC mains,that monitor is full range AC-works on any voltage from 90 to 255VAC direct from mains socket
lilshawn
  • Last login:Yesterday at 11:01:31 pm
« Reply #2 on: January 10, 2014, 09:47:28 pm »
the chassis itself also has a fuse built into it on the AC input, so there is a bit of protection there.
