Author Topic: 2005 golden tee fore  (Read 1759 times)
Joep1999
  • Last login:February 01, 2014, 11:32:31 am
  • Golden tee fan
« on: January 08, 2014, 04:39:40 pm »
I have a 2005 golden tee for that started running very slow.. Sometimes it would take up to a minute between shots, now it's stuck on the start up screen... Would this be a hard drive issue?  Thanks I am new to this so I'm sorry if I posted this in the wrong area
Joe
ed12
Re: 2005 golden tee fore
« Reply #1 on: January 08, 2014, 08:17:07 pm »
the harddrive or the power supply >very common<,if the fan becomes plugged it will suck the ps down,also u should make sure u have a fan on the video card
as that will at times do it also.
but start at the power supply
ed
Joep1999
  • Golden tee fan
« Reply #2 on: January 09, 2014, 11:14:04 am »
Thanks ed, I checked the power supply and it's good. When you first power it up it says
Detecting IDE hard drive...
1
Hard drive detected
Checking filesystems. Note: this can
Take several minutes to complete
Please be patient.
Checking filesystem number: 0
I left it on for about 20 minutes and never made any progress
ed12
« Reply #3 on: January 09, 2014, 11:47:32 am »
chk both ends of the harddrives ide hook up cable
make sure it is seated tightly
the post back
ed
Joep1999
  • Golden tee fan
« Reply #4 on: January 09, 2014, 12:12:03 pm »
Yes they are tight.. I unplugged them and plugged them back in.
ed12
« Reply #5 on: January 09, 2014, 12:31:49 pm »
if i rem right
that machine should have come with cd's..if
so plug in any old crom
and load the rescuse disk
and follow the prompts
as from i see track 1 is shot on your hardrive
ed
Joep1999
  • Golden tee fan
« Reply #6 on: January 09, 2014, 01:01:50 pm »
I don't have the disk, I found the hard drives on eBay for 25 bucks.. Maybe I'll just get a new one
ed12
« Reply #7 on: January 09, 2014, 01:30:52 pm »
imho i would go for the disk's
i could up-load mine..but i am in canada
and our s/w is dif then your's
so it is no good for usa game unless u swap out u17
which again imho is not worth it..
reason i do not tend to buy used hd's from fleabay is u never know how they were handled,lord u got to know some one with the size drive u need ?
if not go to a local putter shop or electronic repair shop they will have them
just make sure it is freshley formated..reason is in the windows formating it will chk track 0 and 1,they must pass a test,
then with the disks,u start at rescue..it will format the drive for u also
then it will start to load the game
ed
