Author Topic: Spintrak spinner wiring  (Read 1796 times)
Bambam1963
  • Last login:March 09, 2024, 11:46:07 pm
  • I love this stuff man!-
« on: January 07, 2014, 10:47:28 pm »
Does anyone know how to wire this spinner up.  I have a small PCB board with two rows of pins. The bottom row has four pins and the top row has three.  I presume the bottom row is for the connector from the Spintrak to plug into.  I do not, however, know which is the right way up.  Additionally, I assume the top three pins are for the spinner buttons.  Do I just solder a wire to each of these top pins to a corresponding button?
John
I am an oldie, who used to troll here years ago.  Now I am back to tweak my machine and help a friend build his.
surface tension
  • Last login:July 01, 2018, 08:45:48 am
  • feel the tension...
    • surface tension tables
Re: Spintrak spinner wiring
« Reply #1 on: January 09, 2014, 08:09:19 am »
I've always connected the SpinTrak to the Mini-PAC. But from the Ultimarc page, when you use the USB board, it looks like the SpinTrak connects to the top row and you connect mouse buttons to the bottom row (nearest the board)
http://www.ultimarc.com/SpinTrak.htm
I don't know if the board tells you the connections, but it's written on the plastic cover on the SpinTrak, so you should be able to work the orientation out from there tracing the ground connection.
Bambam1963
« Reply #2 on: January 09, 2014, 08:33:25 am »
Ah yes.  Never even noticed that.  Good eye.  The mouse buttons are labelled too.
Bambam1963
« Reply #3 on: January 09, 2014, 08:35:23 am »
Here is the other one.  Thanks for pointing it out.  :cheers:
