Author Topic: MA Command Lines  (Read 3403 times)
nevbuster
  • Last login:March 08, 2014, 06:35:03 am
MA Command Lines
« on: January 03, 2014, 07:32:03 am »
I'm finding that the default command lines aren't working and I'm fixing them manually. The filename variable needs "" around it and the extra commands need to be removed for it to work. I'm using MESS 0.152 and MAME 0.151. Anyone else had this problem ?
I also learned to not have spaces in subdirectory names as this screws up the command line as well.
Sometimes I wish I still had my Sinclair ZX81.
nevbuster
Re: MA Command Lines
« Reply #1 on: January 19, 2014, 04:37:25 am »
Got about 6 consoles set up on MA in two weeks when it took about 2 months in hyper spin. Going smooth now.
« Last Edit: January 19, 2014, 04:40:42 am by nevbuster »
Smudge418
  • Last login:March 20, 2016, 02:45:17 pm
  • Maximus arcade is very much alive......
« Reply #2 on: April 26, 2014, 11:59:37 am »
Could you explain a bit more on the command lines and give some examples please
Smudge418
« Reply #3 on: May 26, 2014, 04:44:46 pm »
bump
