Author Topic: Questions for XBMC users  (Read 1366 times)
  • Last login:February 22, 2026, 09:34:29 am
« on: December 23, 2013, 09:53:06 am »
I was thinking about building an xbmc box, but not sure if it's worth the trouble for no more tv than I watch.
A few questions:
1. Does the Hulu plugin allow you to watch the shows that are on the Hulu website, but not available on Hulu Plus?
    If so, does the Hulu plugin require updating to keep up with the Hulu website making changes?  (same for Amazon Prime?)
2. I read a post one time that you can watch the firstrowsports streams on xmbc.  True?
    If so, does it allow you to cycle through available streams of each game to find the best one?
4. Does it integrate some type of recording for over the air broadcasts?
5. How often do you have to update or make changes to the installation to keep everything working?
« Last Edit: December 23, 2013, 10:51:56 am by BadMouth »
s_busby_uk
  • Last login:August 22, 2017, 02:28:51 pm
Re: Questions for XMBC users
« Reply #1 on: December 23, 2013, 10:21:35 am »
1. Not sure, sorry
2. you can certainly watch some streams with the right add ons. Not sure about firstrowsports.
4. You can get a PVR version which will record TV for you, provided you have a TV card that is (this can be a bit fiddly though in my experience)
5. Depends if you mean the software or the hardware I guess. They update every now and again and it's always seemed fine for me. Hardware changes shouldn't affect things much as it's just running on the top of Windows/OSX/Linux anyway.
I've been using XBMC for a year or so now and I absolutely love it, though I use it mainly to play movies and TV shows I've ripped or otherwise acquired on a NAS. I started off running it on top of Windows 7 and then Windows 8, but as I don't use that PC for anything else I moved to OpenELEC, which is basically the Linux version of XBMC but with everything but the necessaries stripped out. If you don't want to use the computer for anything else I recommend this method as it's super easy (you don't really see or need to access the Linux bit of it because it boots straight into XBMC) and you don't have to spend ages stripping out Windows components you won't need that get in the way. The OpenELEC team are only a few days behind the main releases from what I can tell in terms of getting the updates out there (they integrate an autoupdate feature into their version as well).
ark_ader
  • I glow in the dark.
Re: Questions for XBMC users
« Reply #2 on: December 23, 2013, 03:41:12 pm »
I have it on the Xbox and it is worth its weight in gold.
lilshawn
  • Last login:February 20, 2026, 07:25:33 pm
« Reply #3 on: December 23, 2013, 07:49:40 pm »
i run xboxes in the bedrooms and this:
http://www.geexbox.org/
it works on any computer and is more capable performance wise than the xbox, so i use it on an old HP P4 on my livingroom tv.
