February 09, 2010, 08:11:14 AM *
Welcome, Guest. Please login or register.
Login with username, password and session length
News:
   Home   Help Arcade Search Login Register
Main Woodworking Reviews Software Monitor/Video
Audio/Jukebox/MP3 Project Announcements Artwork Consoles Buy/Sell/Trade
Arcade Miscellaneous Everything Else Politics n Religion Forum Discussion Wiki Discussion
DOS/WinCab PowerMAME SK Jukebox UncleTs Jukebox Project Arcade
Linux Restorations Pinball MaLa Frontend
Recent posts | Arcade | Rules | Old Boards | Old Archives | Chatroom | Wiki | File Repository | RSS
Pages: [1]   Go Down
  Send this topic  |  Print
Author Topic: AdvanceMame and MetalSlug3 Video Problems  (Read 688 times)
mm_can
Trade Count: (0)
Full Member
Offline Offline
View Profile WWW
« on: March 25, 2002, 12:15:54 PM »
Just wondering if anyone else can test MetalSlug3 and Advancemame (latest).  When mine loads I get all the colors messed up, almost looks negitive color screen.  Same roms works great with dos mame .58
Mike
« Last Edit: December 31, 1969, 07:00:00 PM by 1026619200 » Logged
frank_black
Trade Count: (0)
Jr. Member
Offline Offline
What ever happened to pong?
View Profile
« Reply #1 on: March 25, 2002, 03:12:25 PM »
Metal Slug 3 works fine with my setup and the latest AdvanceMAME.  You might want to post your problem here: http://www.geocrawler.com/lists/3/SourceForge/14936/0/
You will probably get ignored just the same there,(especially if you don't share more info like: what video card or what kind of monitor or the contents of your advmame.rc file) But if you look through past messages in THAT forum, you'll be more likely to find out why you are having trouble. Hope this helps..
drabbit
Trade Count: (0)
Full Member
Offline Offline
Keeps playing, and playing.....
View Profile
« Reply #2 on: March 25, 2002, 04:43:21 PM »
Had the same problem myself, you are probably set to use 32bpp, I corrected this by seting it back to 16bpp or on AUTO.
If you check, you probably have the same symptoms in Metal Slug 2, but not in other versions of Metal Slug...
Let us know if this was the problem!
drabbit
Trade Count: (0)
Full Member
Offline Offline
View Profile
« Reply #3 on: March 25, 2002, 04:45:12 PM »
BTW This is not only related to AdvanceMame, this is a problem in all flavours of Mame!
Logged
mm_can
Trade Count: (0)
Full Member
Offline Offline
View Profile WWW
« Reply #4 on: March 25, 2002, 09:02:38 PM »
More info on my setup: ATI Rage Pro 128 agp card.  P3-900Mhz
Problem is found in : Metal Slug2,3 and Neo Turfmasters.
These programs run fine with dos mame (default settings)
In Advancemame I am using generate.
The mode it picks for the games is: 304x228x15.  I tried changing the depth to 16 since it is already on auto. I tried rgb yes / no.  Still same issues.
Note: Metal Slug X works fine.
Still puzzled.  - Oh last thing is I use a wg 1465 arcade monitor via jpac.
Thanks again
Mike
mm_can
Trade Count: (0)
Full Member
Offline Offline
View Profile WWW
« Reply #5 on: March 26, 2002, 01:42:30 PM »
This issue was solved using AdvanceMAME v0.59.0
Thanks Guys!
Mike
Pages: [1]   Go Up
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC | Sitemap Valid XHTML 1.0! Valid CSS!
Page created in 0.132 seconds with 22 queries.
