Author Topic: PC Games, Model 2 & 3 and Daphne emus with no video on 480i CRT TV. Why???  (Read 1868 times)
Bob Sakamanno
  • Last login:March 04, 2016, 07:06:11 am
Dear friends,
(i posted this on another topic, but with no results)
i did spend some years here at Arcade Controls reading about building a cabinet.
Finally i build mine (if someone desires, i can send pictures), but i have problem with some machines.
For the vintage look, i used a 21" CRT TV for my cabinet. Wonderful visual on MAME, AAE, Daphne, PSONE, Saturn, etc.
But when i trie PC Games, Model 2 and Model 3 games in full screen, i just get a blue screen. The game is working (because of music and other sounds), but i have no image. These systems works pretty good in windowed mode, but nothing in fullscreen.
I use a Geforce 285 with Component output to this TV. When connected to a PC Monitor using VGA, DVI, HDMI, i have no problem.
Any ideas what's going on?
Frequency, maybe?
I'm waiting for your tips.
Best regards.
Bob Sakamanno
Re: PC Games, Model 2 & 3 and Daphne emus with no video on 480i CRT TV. Why???
« Reply #1 on: November 06, 2013, 08:36:30 am »
Hello,
one good news: Model 2 games are working fullscreen. The solution was silly. I just erased the folder and put a new one in place. With Model 3 this method didn't worked. Later i'll try the same with PC games and Daphne. Let's see.
SailorSat
  • Last login:Today at 03:55:11 am
    • For Amusement Only e.V.
« Reply #2 on: November 08, 2013, 04:09:39 am »
Most likely a resolution issue. Double check the emulators run at 640x480 or something like that.
I do all that stuff even without a Joystick ;)
Soft-15kHz, cabMAME, For Amusement Only e.V.
Bob Sakamanno
« Reply #3 on: November 08, 2013, 09:37:27 am »
Hello, Sat,
i tried it at 320x240 and 640x480.
No solution.
Anyone here uses these emulators hooked at a 480i TV using RGB component cables?
Bob Sakamanno
After some time i'm back with the solution.
As i remember, the emulador have its pre-defined resolutions.
What i did to make it work was lower the resolution a little on the TXT file. No the games are fully working inside Hyperspin.
(now if someboy have this issue around the internet, might find the solution right here)
