Author Topic: Help with Groovyarcade Video settings  (Read 2199 times)
epicfatigue
  • Last login:May 15, 2016, 08:16:08 pm
    • http://www.retromods.com.au
« on: November 05, 2013, 04:19:15 am »
Hey Everyone,
I am very new to the Groovyarcade linux side of things.
I have installed in and am loving the look of it however before i go any further i wanted some help with configuring my monitor.
Its a PC CRT Philips 109B40
Full specs can be found here.   http://www.p4c.philips.com/files/1/109b4374/109b4374_pss_aen.pdf
Scanning
• Horizontal Scanning 30 - 97kHz
• Vertical Scanning 50 - 160Hz
CRT
• Size (inch/cm) 19"/46 cm (18.0" VIS)
• Deflection Angle (degrees) 90°
• Dot Pitch 0.25 mm
• Horizontal Pitch 0.21 mm
Resolution H.freq V.freq
640 x 480 31.5(kHz) 60(Hz)
640 x 480 37.9(kHz) 72(Hz)
640 x 480 37.5(kHz) 75(Hz)
640 x 480 43.3(kHz) 85(Hz)
640 x 480 50.6(kHz) 100(Hz)
720 x 400 31.5(kHz) 70(Hz)
720 x 400 37.9(kHz) 85(Hz)
800 x 600 37.9(kHz) 60(Hz)
800 x 600 48.1(kHz) 72(Hz)
800 x 600 46.9(kHz) 75(Hz)
800 x 600 53.7(kHz) 85(Hz)
800 x 600 63.9(kHz) 100(Hz)
832 x 624 49.7(kHz) 75(Hz)
1024 x 768 48.4(kHz) 60(Hz)
1024 x 768 56.5(kHz) 70(Hz)
1024 x 768 60.0(kHz) 75(Hz)
1024 x 768 68.7(kHz) 85(Hz)
1152 x 864 67.5(kHz) 75(Hz)
1152 x 864 77.0(kHz) 85(Hz)
1152 x 870 68.7(kHz) 75(Hz)
1152 x 900 71.8(kHz) 76(Hz)
1280 x 960 60.0(kHz) 60(Hz)
1280 x 960 85.9(kHz) 85(Hz)
1280 x 1024 64.0(kHz) 60(Hz)
1280 x 1024 80.0(kHz) 75(Hz)
1280 x 1024 91.1(kHz) 85(Hz)
1600 x 1200 75.0(kHz) 60(Hz)
1600 x 1200 81.3(kHz) 65(Hz)
1600 x 1200 87.5(kHz) 70(Hz)
1600 x 1200 93.8(kHz) 75(Hz)
1792 x 1344 83.6(kHz) 60(Hz)
1856 x 1392 86.3(kHz) 60(Hz)
1920 x 1440 90.0(kHz) 60(Hz)
epicfatigue
Re: Help with Groovyarcade Video settings
« Reply #1 on: November 05, 2013, 04:24:18 am »
Here is some photos of the job thus far
