Author Topic: k7000 Black bar in middle, horiz position off  (Read 1579 times)
Zunni
  • Last login:March 17, 2014, 04:49:48 pm
« on: October 25, 2013, 09:13:41 pm »
So I finally have progressed to getting a picture on my monitor and the picture is actually really good.
My last problem is I had the screen shifted to the right causing the image to be wrapped and a black bar in the middle of the screen. I had a broken horizontal position pot on my control board, which I replaced with a new 500 Ohm pot. Now I can slightly adjust the black bar around a bit but I can't get it off the screen.
I looked at the spec and it's supposed to be a 500 ohm trim pot (the broken one also said 500 ohm).
How can I shift this black bar out of the middle of the screen and shift the image so it's sitting correctly...
Is it a sync issue? Is it that the pot needs to be a larger size perhaps?
Thanks for your help through this, it's coming together beautifully.
ed12
Re: k7000 Black bar in middle, horiz position off
« Reply #1 on: October 25, 2013, 10:10:26 pm »
500 ohm or 500k ohm ?
large dif there
ed
Zunni
« Reply #2 on: October 28, 2013, 11:33:52 am »
Hey Ed:
According to what I can see on the existing Pot and what's on page 23 of the manual found here
http://arcarc.xmission.com/PDF_Monitors/Wells%20Gardner%20K7000%20Manual.pdf
Cross referenced with the H-Pos pot found on page 20 (labelled Vr1) indicates it's a 500, other entries have the K beside them so I feel confident that it's just 500 Ohm.
If I got my hands on a 1K or 2K would that be worth trying in that spot to see if it makes a larger difference?
ed12
« Reply #3 on: October 28, 2013, 12:46:48 pm »
the 1k would be
as it would not be that far out of range
i will chk my stash of control boards and let u know what i get
ed
lilshawn
  • Last login:October 22, 2025, 11:23:16 am
« Reply #4 on: October 31, 2013, 04:59:53 pm »
yes it is indeed a 500 ohm.
Zunni
« Reply #5 on: January 20, 2014, 04:15:52 pm »
Now that the holidays are over, I've come back to this.
I'm stymied as I've tried a 1k and 2k ohm pot and it barely moves the picture more than an inch or two.
Does anyone have any additional ideas on what I may be looking at here?
I can provide whatever information is necessary to try to squash this problem. It sucks having this beautiful cabinet sitting unfinished because of a lame video issue.. :(
buffett
  • Last login:December 13, 2016, 01:28:10 am
« Reply #6 on: January 22, 2014, 01:42:36 am »
if you do not put a 500 ohm pot in there the adjustment will never work correctly.
if you need a pot i stock them.
if you need the chassis and remote board repaired i can do it.
if you are in the US email me from my website.
thearcadebuffett.com
Peace
Buffett
Come to MAGfest and game in the 24-7 arcade for 4 days. www.magfest.org  And see my collection of 90+ Arcades and growing.
Need your (K7000, 4900, std/med res 13"-25") or Sanyo fixed!!!! pm me.
Visit my website. www.thearcadebuffett.com For Monitor and PCB repairs.
Fully rebuilt chassis ready to ship. Trade'ins welcome
I have met --- Tim McVey --- world nibbler champion and many of you have not.
