Author Topic: [SOLVED - basically] I need some help with a laptop touchpad. Not game related.  (Read 5012 times)
Louis Tully
« Last Edit: February 12, 2015, 03:55:35 pm by Louis Tully »
ed12
first welcome aboard
second your thread is fine
just hang tight a more refined linux person will come in and drop u the .bash u need
i ran into the exact problem when i first loaded ub
but was lucky enough to lacth on to a linux fourm
ed
sairuk
  • Last login:August 25, 2019, 02:24:17 am
    • mameau
Not having used this script before I will be running blind here. I will try to spell out what steps I would go through based on the information available and hope that addresses your needs.
Open Terminal from the Xubuntu Applications Menu>Accessories>Terminal
From what I can see the id you are after is 13, with that in mind you would execute. (# is a prompt in the terminal)
Code: [Select]
# chmod a+x enable-rightbutton.sh
# ./enable-rightbutton.sh 13
If it needs to be run an Xorg startup you should be able to place a call to execute the script in an .xprofile file located in your home directory
Create the ~/.xprofile file
Code: [Select]
# touch ~/.xprofile
# gedit ~/.xprofile
Add the following line to the .xprofile file and save it
Code: [Select]
/<absolute path to file>/enable-rightbutton.sh 13
I use this .xprofile trick to set my resolutions through xrandr, control volumes/muting of devices, etc at xorg startup.
Not come across this issue myself, so i'm working on the assumption that you were after how best to implement the script.
mameau - My random bits | Wah!Ki - A Wah!Cade wiki | Mah!Cade - Experimental Wah!cade Branch | ListGen | Lazarus
Louis Tully
« Last Edit: February 12, 2015, 03:57:33 pm by Louis Tully »
sairuk
    • mameau
All good mate, glad you are enjoying linux. I'd forgotten about crunchbag, will grab that for the wifes netbook.
