Author Topic: Several questions about groovymame using intervideo arcade crt  (Read 4436 times)
mitsurugi
  • Last login:November 07, 2025, 04:57:10 am
« on: October 05, 2013, 05:00:17 am »
Hi. I', using winxp64, crt_emudriver and vmaker for 15hz with groovymame 0.149. My arcade monitor is a intervideo 28" (always 15hz).
My vmmaker ini is:
Code: [Select]
; VideoModeMaker - Options
; 1. MAME
; Path for Mame executable, in case we want to extract xml information from it.
MameExe = "C:\Emuladores\Mame 0.149\groovymame64_0149.014b.exe"
; Path for Mame ini folder, in case we want to create an ini file for each game.
; Important: existing ini files will be overwritten.
IniPath = "C:\Emuladores\Mame 0.149\mame.ini"
; Mame options.
ListFromXML = 1 ; Processes Mame XML and get video mode list from it
GenerateXML = 1 ; Extracts XML from Mame (only needed once)
OnlyListMain = 0 ; Only list resolutions for games contained in MameMain.txt
GenerateInis = 0 ; Creates an ini file for each Mame game, in the IniPath folder
SDLMame = 0 ; Use SDLMame specific options
; Monitor orientation
MonitorHorizontal = 1 ; 0 = Rotating monitor: horizontal and vertical games at their native resolution
;     Suitable for users that physically rotate their CRTs
; 1 = Horizontal monitor: horizontal games run at their native resolution and
;     vertical games are rotated to fit in horizontal monitor
RotatingDesktop = 0 ; Specifies if both desktop and monitor are rotated
; Aspect ratio for vertical games on horizontal monitor
; 4:3 (keeps original aspect ratio)
; 3:3 (stretches to square format)
; 3:4 (stretches to full screen)
; h:v (custom aspect ratio)
VerticalAspect = "4:3"
; 2. MONITOR
; Monitor Type. Valid types: D9800, D9400, D9200, EGA, VGA, MULTI, H9110, PAL, NTSC, GENERIC, CUSTOM
MonitorType = "CUSTOM"
; Monitor CUSTOM. These values will be used if MonitorType = "CUSTOM"
; monitor_specs0-6  HfreqMin-HfreqMax, VfreqMin,VfreqMax, HFrontPorch, HSyncPulse, HBackPorch, VfrontPorch, VSyncPulse, VBackPorch, HSyncPol, VSyncPol, ActiveLinesLimit, VirtualLinesLimit
; * HfreqMin-HfreqMax: Minimum and maximum horizontal frequency, in Hz. Defines the range of horizontal frequencies the monitor is capable to sync.
; The higher the horizontal frequency, the higher the vertical resolution available for the same vertical refresh.
; The higher the horizontal frequency, the higher the vertical refresh available for the same vertical resolution.
; The higher the horizontal frequency, the lower the horizontal amplitude of active video (narrower picture).
; * VFreqMin-VfreqMax: Minimum and maximum vertical frequency, in Hz, Defines the range of vertical frequencies the monitor is capable to sync.
; * HFrontPorch, HSyncPulse, HBackPorch: Horizontal timing and geometry, values in µs
; * VfrontPorch, VSyncPulse, VBackPorch: Vertical timing and geometry, values in ms
; * HSyncPol,VSyncPol: sync polarities, 0 = negative, 1 = positive.
; * ActiveLinesLimit: Vertical resolutions until ActiveLinesLimit value included, are generated as progressive, regardless the possibility
;                           of obtaining the required vertical refresh value.
; * VirtualLinesLimit: Vertical resolutions above ActiveLinesLimit and below VirtualLinesLimit are virtualized, that is, an interlaced resolution
;                            bigger that the native one is generated, with the right refresh, and "hardware stretch" is applied.
;                            Vertical resolutions above VirtulaLinesLimit are generated as interlaced, without any stretching.
monitor_specs0    15625-16200, 49.50-65.00, 2.000, 4.700, 8.000, 0.064, 0.160, 1.056, 0, 0, 288, 448
; Tolerance for horizontal frequency, in kHz, enables extending the range defined by [ HfreqMin, HfreqMax ]
; The resulting allowed frequency range will be [ HfreqMin - HfreqTolerance, HfreqMax + HfreqTolerance ]
HfreqTolerance = 0.010
; 3. MODELINE GENERATOR
; Total number of modelines to generate. Here are the recommended values for each driver version:
; CRT_Emudriver, based on Catalyst 6.5: 160 modes (accepts up to 200, but above 160 HyperSpin will refuse to load)
; CRT_Emudriver, based on Catalyst 9.3: 120 modes (accepts some more but above 120 you can get some blue screens)
; Regular Catalyst                    : 60 modes (won't accept any more)
TotalModes = 120
; If enabled, only creates modes with 32 bits per pixel color depth
Only32BPPModes = 0
; Method for mode table generation. If Mame xml is processed, that will create a lot of different video modes, so the mode table
; will be optimized keeping the most relevant ones, and dropping the rest, to keep below the TotalModes value.
; 0 = Static table: modelines are generated keeping their original vertical refresh. This method is intended to be used in
;     combination with ini files for each game.
; 1 = Dynamic table: a table of dummy modes is created using xres and yres values while ignoring vfreq. This method is intended
;     to be used in combination with Switchres or Groovymame. No ini files are required using this method (you should disable the
;     GenerateInis option).
; 2 = Magic table: a table of 'magic resolutions' is created, by ignoring xres and vfreq and just keeping yres. This method greatly reduces
;     the total number of modes in the list. It's only supported by GroovyMAME, and is intended as a workaround for the Hyperspin issue.
ModeTableMethod_Custom = 0
ModeTableMethod_XML = 1
; Minimum resolution values (these will be used instead of lower values)
XresMin_XML = 240
YresMin_XML = 240
YresRound_XML = 4
XresMin_Custom = 240
YresMin_Custom = 160
YresRound_Custom = 0
; Minimum dotclock value allowed by the video card, in MHz (i.e. DotClockMin = 7.010)
DotClockMin = 0
; Number of iterations used by the mode generator [0,5]. The higher the number of iterations, the bigger the accuracy of the vertical
; refreshed obtained, normally at the cost of increasing the horizontal frequency strictly required.
Iterations = 0
; Specifies if the refresh label is multiplied by 10 before rounding (experimental).
VFreqLabelx10 = 0
; 4. DRIVER
; Path for the driver folder
DriverPath = ".\Driver\"
; If UpdateRegistry is enabled, UpdateDriver will only work if the driver version found in DriverPath matches the one installed
; in the system.
UpdateRegistry = 1 ; Specifies if the video card registry section will be updated with the new video modes
; (will only work in combination with CRT_EMUDriver).
UpdateDriver = 0 ; Specifies if the driver files in DriverPath will be updated with the new video modes, for
; future installations.
AnyCatalyst = 0 ; Allows modelines to be installed for any Catalyst version. This option is experimental and
; known to produce some problems.
Mame.ini:
Code: [Select]
# CORE CONFIGURATION OPTIONS
readconfig                1
writeconfig               0
# CORE SEARCH PATH OPTIONS
rompath                   D:\Roms\Mame0.149;D:\Roms\MAME_0.147_CHD_FULL_SET
hashpath                  hash
samplepath                samples
artpath                   artwork
ctrlrpath                 ctrlr
inipath                   .;ini
fontpath                  .
cheatpath                 cheat
crosshairpath             crosshair
# CORE OUTPUT DIRECTORY OPTIONS
cfg_directory             cfg
nvram_directory           nvram
memcard_directory         memcard
input_directory           inp
state_directory           sta
snapshot_directory        snap
diff_directory            diff
comment_directory         comments
hiscore_directory         hi
# CORE STATE/PLAYBACK OPTIONS
state
autosave                  0
playback
record
mngwrite
aviwrite
wavwrite
snapname                  %g/%i
snapsize                  auto
snapview                  internal
statename                 %g
burnin                    0
# CORE PERFORMANCE OPTIONS
autoframeskip             0
frameskip                 0
seconds_to_run            0
throttle                  1
syncrefresh               1
sleep                     1
speed                     1.0
refreshspeed              0
# CORE ROTATION OPTIONS
rotate                    1
ror                       0
rol                       0
autoror                   0
autorol                   0
flipx                     0
flipy                     0
# CORE ARTWORK OPTIONS
artwork_crop              1
use_backdrops             0
use_overlays              0
use_bezels                0
use_cpanels               0
use_marquees              0
# CORE SCREEN OPTIONS
brightness                1.0
contrast                  1.0
gamma                     1.0
pause_brightness          0.65
effect                    none
# CORE VECTOR OPTIONS
antialias                 1
beam                      1.0
flicker                   0
# CORE SOUND OPTIONS
sound                     1
samplerate                48000
samples                   1
volume                    0
# CORE INPUT OPTIONS
coin_lockout              1
ctrlr
mouse                     0
joystick                  1
lightgun                  0
multikeyboard             0
multimouse                0
steadykey                 0
ui_active                 0
offscreen_reload          0
joystick_map              auto
joystick_deadzone         0.3
joystick_saturation       0.85
natural                   0
joystick_contradictory    0
coin_impulse              0
# CORE INPUT AUTOMATIC ENABLE OPTIONS
paddle_device             keyboard
adstick_device            keyboard
pedal_device              keyboard
dial_device               keyboard
trackball_device          keyboard
lightgun_device           keyboard
positional_device         keyboard
mouse_device              mouse
# CORE DEBUGGING OPTIONS
log                       0
verbose                   0
update_in_pause           0
debug                     0
debugscript
debug_internal            0
# CORE MISC OPTIONS
bios
cheat                     0
skip_gameinfo             0
uifont                    default
ramsize
confirm_quit              0
ui_mouse                  0
autoboot_command
autoboot_delay            2
autoboot_script
# CORE MKChamp OPTIONS
disable_hiscore_patch     0
disable_nagscreen_patch   0
disable_loading_patch     1
# CORE SWITCHRES OPTIONS
modeline                  1
monitor                   lcd
orientation               horizontal
connector                 auto
interlace                 1
doublescan                1
cleanstretch              0
changeres                 1
powerstrip                0
lock_system_modes         1
lock_unsupported_modes    1
refresh_dont_care         0
dotclock_min              0
sync_refresh_tolerance    2.0
frame_delay               0
lcd_range                 auto
crt_range0                auto
crt_range1                auto
crt_range2                auto
crt_range3                auto
crt_range4                auto
crt_range5                auto
crt_range6                auto
crt_range7                auto
crt_range8                auto
crt_range9                auto
# WINDOWS DEBUGGING OPTIONS
oslog                     0
watchdog                  0
debugger_font             "Lucida Console"
debugger_font_size        9
# WINDOWS PERFORMANCE OPTIONS
priority                  0
multithreading            1
numprocessors             auto
profile                   0
bench                     0
# WINDOWS VIDEO OPTIONS
video                     d3d
numscreens                1
window                    0
maximize                  1
keepaspect                0
prescale                  1
waitvsync                 1
menu                      0
# DIRECTDRAW-SPECIFIC OPTIONS
hwstretch                 0
# DIRECT3D-SPECIFIC OPTIONS
filter                    0
# DIRECT3D POST-PROCESSING OPTIONS
hlsl_enable               0
hlslpath                  hlsl
hlsl_ini_read             0
hlsl_ini_write            0
hlslini                   %g
hlsl_prescale_x           0
hlsl_prescale_y           0
hlsl_preset               -1
hlsl_write
hlsl_snap_width           2048
hlsl_snap_height          1536
shadow_mask_alpha         0.0
shadow_mask_x_count       320
shadow_mask_y_count       240
shadow_mask_usize         0.09375
shadow_mask_vsize         0.109375
curvature                 0.03
pincushion                0.03
scanline_alpha            1.0
scanline_size             1.0
scanline_height           1.0
scanline_bright_scale     1.0
scanline_bright_offset    0.0
scanline_jitter           0.0
defocus                   0.0,0.0
converge_x                0.3,0.0,-0.3
converge_y                0.0,0.3,-0.3
radial_converge_x         0.0,0.0,0.0
radial_converge_y         0.0,0.0,0.0
red_ratio                 1.0,0.0,0.0
grn_ratio                 0.0,1.0,0.0
blu_ratio                 0.0,0.0,1.0
saturation                1.4
offset                    0.0,0.0,0.0
scale                     0.95,0.95,0.95
power                     0.8,0.8,0.8
floor                     0.05,0.05,0.05
phosphor_life             0.4,0.4,0.4
# NTSC POST-PROCESSING OPTIONS
yiq_enable                0
yiq_cc                    3.59754545
yiq_a                     0.5
yiq_b                     0.5
yiq_o                     0.0
yiq_p                     1.0
yiq_n                     1.0
yiq_y                     6.0
yiq_i                     1.2
yiq_q                     0.6
yiq_scan_time             52.6
yiq_phase_count           2
# VECTOR POST-PROCESSING OPTIONS
vector_length_scale       0.8
vector_length_ratio       500.0
# BLOOM POST-PROCESSING OPTIONS
vector_bloom_scale        0.3
raster_bloom_scale        0.225
bloom_lvl0_weight         1.0
bloom_lvl1_weight         0.21
bloom_lvl2_weight         0.19
bloom_lvl3_weight         0.17
bloom_lvl4_weight         0.15
bloom_lvl5_weight         0.14
bloom_lvl6_weight         0.13
bloom_lvl7_weight         0.12
bloom_lvl8_weight         0.11
bloom_lvl9_weight         0.10
bloom_lvl10_weight        0.09
# PER-WINDOW VIDEO OPTIONS
screen                    auto
aspect                    auto
resolution                auto
view                      auto
screen0                   auto
aspect0                   auto
resolution0               auto
view0                     auto
screen1                   auto
aspect1                   auto
resolution1               auto
view1                     auto
screen2                   auto
aspect2                   auto
resolution2               auto
view2                     auto
screen3                   auto
aspect3                   auto
resolution3               auto
view3                     auto
# FULL SCREEN OPTIONS
triplebuffer              0
switchres                 1
full_screen_brightness    1.0
full_screen_contrast      1.0
full_screen_gamma         1.0
# WINDOWS SOUND OPTIONS
audio_latency             2
# INPUT DEVICE OPTIONS
dual_lightgun             0
I have several questions.-
-Why in mame.ini monitor type is lcd?
-Why i have 2 mame.xml? one mame.xml in grooymame folder and another in vmmaker folder. Is this normal?
-What is the diferent between: ModeTableMethod_Custom and ModeTableMethod_XML? and when bust be one activated?
-Can you take a look in the inis for see some fails configs?
I have some problems with mame 3d games, because the resolution is too small for my arcade monitor.-
Uploaded with ImageShack.us
« Last Edit: October 05, 2013, 05:46:35 am by Calamity »
mitsurugi
Re: Several questions about groovymame using intervideo arcade crt
« Reply #1 on: October 05, 2013, 05:41:49 am »
I have changed this in mame.ini.-
modeline                  1
monitor                   CUSTOM
connector                 auto
interlace                 1
doublescan                1
cleanstretch              0
changeres                 1
powerstrip                0
lock_system_modes         1
refresh_dont_care         0
dotclock_min              0
frame_delay               0
lcd_range                 auto
crt_range0                15625-16200, 49.50-65.00, 2.000, 4.700, 8.000, 0.064, 0.160, 1.056, 0, 0, 288, 448
crt_range1                auto
crt_range2                auto
crt_range3                auto
crt_range4                auto
crt_range5                auto
crt_range6                auto
crt_range7                auto
crt_range8                auto
crt_range9                auto
But when i launch games, switchres: could not find a video mode that meets your specs
and all games at same resolution...
Calamity
  • Moderator
  • Last login:Yesterday at 10:56:16 pm
  • Quote me with care
« Reply #2 on: October 05, 2013, 05:53:41 am »
Hi misurugi,
First of all: it's 15 kHz, not 15hz. Each time I read 15hz my eyes bleed.
Because you changed it for some reason. The default value is generic_15, it's there when you create a fresh mame.ini by running: groovymame -cc
Because you created them? Or maybe some frontend you're using?
VMMaker takes resolutions from two sources: mame.xml and ReslList.txt. ModeTableMethod_XML is applied to the resolutions taken from mame.xml, and ModeTableMethod_Custom to the ones from ReslList.txt
It's better to post a log instead of inis: groovymame romname -v >romname.txt
It shows which resolution is picked and why, so I can help you more efficiently.
« Last Edit: October 05, 2013, 05:58:32 am by Calamity »
Steps to create a log:
Calamity
  • Moderator
« Reply #3 on: October 05, 2013, 05:57:10 am »
You are mixing VMMaker and GroovyMAME formats, it won't work like that. Use either one of these settings:
Code: [Select]
monitor arcade_15
crt_range0 auto
or
Code: [Select]
monitor custom
crt_range0 15625-16200, 49.50-65.00, 2.000, 4.700, 8.000, 0.064, 0.160, 1.056, 0, 0, 192, 288, 448, 576
(notice the crt_range format has 2 extra numbers at the end, as compared to a monitor_specs line)
mitsurugi
« Reply #4 on: October 05, 2013, 08:12:47 am »
I have deleted mame.ini and generate a new one, then execute vmmaker and test groovymame again.
Now 3d games are good. In mame.ini monitor arcade_15 works good.
I have uploaded txt generated with tekken tag. Do you think is good?
Calamity
  • Moderator
« Reply #5 on: October 09, 2013, 02:01:22 pm »
Hi mitsurugi,
Your tekken log looks perfect to me.
mitsurugi
« Reply #6 on: October 09, 2013, 06:15:13 pm »
Thank you very much for your reply. I was doing several test and i think groovymame is working perfect in my computer!  ;D
