Author Topic: Cheapest way to make a 4-Way joystick function on its own?  (Read 4144 times)
DarthMarino
  • Last login:September 06, 2025, 02:38:47 pm
« on: September 30, 2013, 05:16:34 pm »
I’ve been eyeing some of the 4/8 way switchable joysticks for a while as a replacement to one of my x-arcade sticks.  I’ve heard mixed things about doing this.  I am toying with the idea of making a separate 4-way stick on its own but have a feeling it will cost more than I would like it to.  What is the cheapest way to have a 4 way stick work on its own through a USB connection (gamepad or keyboard, doesn’t matter).  I’m assuming the sticks come with microswitches but none of the cables, terminals, etc.
michelevit
  • Last login:December 25, 2024, 06:57:41 pm
Slippyblade
Re: Cheapest way to make a 4-Way joystick function on its own?
« Reply #2 on: September 30, 2013, 06:31:54 pm »
Keep in mind that having a dedicated 4-way stick doesn't mean it needs it own encoder.  Simply wire the 4-way in parallel with whatever you have for the regular player 1 stick.  The only real difference between a 4-way and an 8-way is that a 4-way is constructed or limited so that it CANNOT click two switches at once.
DarthMarino
« Reply #3 on: September 30, 2013, 07:18:47 pm »
I would definitely do this if I had a big panel but there's no room to fit another stick on the X-Arcade.
DarthMarino
« Reply #4 on: September 30, 2013, 07:23:14 pm »
ebay baby.
usb arcade controller is $11.
i've used them and they work great.
http://www.ebay.com/itm/New-Zero-Delay-Arcade-USB-Encoder-PC-to-joystick-for-MAME-Fight-Stick-Controls-/171017609206?pt=LH_DefaultDomain_0&hash=item27d1719ff6
This is probably perfect.  Any recommendations for a 4-way stick that will work well with this? I am eyeing the Leaf Pro.
« Last Edit: September 30, 2013, 07:58:46 pm by DarthMarino »
michelevit
« Reply #5 on: September 30, 2013, 08:15:18 pm »
this is correct. you can easily wire up your 8 way and 4 way to the same encoder. The joystick buttons are simple momentary buttons.
You can also use a simple toggle switch to lift the shared ground to disable the stick if that is a concern.
Slippyblade
« Reply #6 on: September 30, 2013, 08:25:30 pm »
Ohhh.  I didn't realize you were still using the X-Arcade CP.  From the tone of your post I thought you had just used the guts of an X-Arcade in a separate CP.  That's what I did.
DarthMarino
« Reply #7 on: September 30, 2013, 08:33:08 pm »
^Yeah. I am liking the idea of making a small controller similar to a single X-Arcade for use with games like Pac-Man and Donkey Kong.  With the encoder suggested above, I'll throw on a few buttons. Nothing fancy. Should cover most single player games needing a 4-way.
paigeoliver
  • Awesome face!
« Reply #8 on: September 30, 2013, 08:40:23 pm »
You can still have your standalone 4-way panel plug into your existing X-arcade panel.
JDFan
« Reply #9 on: September 30, 2013, 10:36:14 pm »
The encoder linked earlier is designed to be used with the Sanwa (Japanese type) Joysticks that use a 5 pin connector -- they also make the same thing with wiring for the Happ type joysticks -- so be sure to order the correct one for the joystick\buttons you are going to use !!
For example here is a link to the same supplier with the Happ type wiring instead ( http://www.ebay.com/itm/Zero-Delay-Arcade-USB-Encoder-PC-to-Joystick-For-2pin-Happ-Type-Push-buttons-/171033729825?pt=LH_DefaultDomain_0&hash=item27d2679b21 )
So just be sure to get the right type to fit the parts you purchase.
I used the same type of encoder in my single player dual joystick bartop (for Robotron and Smash TV) by wiring it so that the second joystick and buttons 3-6 share the same inputs (since both are not used at the same time) and it works great ! And shipping only took 10 days from Hong Kong !
« Last Edit: September 30, 2013, 10:47:23 pm by JDFan »
DarthMarino
JDFan
« Reply #11 on: October 01, 2013, 12:25:53 am »
Stick says it uses Standard .187" female QD terminal compatible connections and buttons also  .187" Female Quick-Disconnect.
So yes the one I linked would be the one you want !
Here is a pic of the 2 types - the joystick you are getting uses the 2 pin type shown on the right side not the 5 pin which was the type linked in the first post about the encoders.
« Last Edit: October 01, 2013, 12:57:04 am by JDFan »
DarthMarino
« Reply #12 on: October 29, 2013, 09:45:38 am »
I finished the controller this weekend.  Works great with that controller. Thanks for the help.
