Author Topic: Adhesive vinyl and particleboard.  (Read 3444 times)
Monkeyvoodoo
  • Last login:November 16, 2024, 01:36:41 am
  • I swear I can stop at one. Or two.
    • threefoldhorse Custom
« on: September 25, 2013, 02:20:25 am »
I was wondering if anyone had tips on applying vinyl to particleboard and plywood?
Should I paint it first or get a sealant?
Anyone ever try a watered down wood glue as a sealant?
michelevit
  • Last login:December 25, 2024, 06:57:41 pm
Re: Adhesive vinyl and particleboard.
« Reply #1 on: September 26, 2013, 07:27:54 pm »
What do you mean by 'vinyl'?
Pliable Upholstery type material or unbendable tap plastic type material.
If your referring to diner booth, sit on it vinyl, then I would recommend sprayable 3m contact adhesive or brushable weldwood contact cement. Both products work great.
If you are referring to unbendable tap plastic type material i've sucessfully used titebond II wood glue. Scuff up the glueing surface, apply glue and clamp.
Monkeyvoodoo
« Reply #2 on: September 26, 2013, 09:25:41 pm »
I'm talking about self adhesive vinyl like what is used for vehicle graphics, signs and cabinet side art.
My concern is that there could be difficulties adhering to naked wood.
nordemoniac
  • Weee! Hahaha...
« Reply #3 on: September 27, 2013, 08:14:21 am »
On particleboard my experiences are good with:
- Sanding everything smooth (min 240 sandpaper)
- Paint it
- Apply stickers
This should give a nice smooth surface.
Steve248
  • Last login:November 18, 2013, 06:24:13 am
« Reply #4 on: October 31, 2013, 03:52:47 pm »
I made the mistake of not sanding and cleaning ply enough before applying vinyl. It does not look great, but OK. OK for me is just not good enough.
I am tempted to start again and apply some laminate first. On to laminate it looks absolutely great.
matt4949
« Reply #5 on: October 31, 2013, 04:15:32 pm »
1 part glue/ 1 to 2 parts water. apply with foam brush, let dry and sand with 220 grit. repeat process.
 I think Bruce Lee used this method but I'm having trouble finding any documentation
kahlid74
  • Gaming for a better future!
    • GamersAnon
« Reply #6 on: November 05, 2013, 10:43:40 am »
Matt is on the spot with this.  I have however applied Vinyl on Sanded ply from a big box store directly and it's rock solid too.  If it's not sanded ply from the store, then you gotta sand it well and then use an air compress to blow it clean.
