Author Topic: Happ Controls Trackball Question  (Read 1288 times)
davidsz
  • Last login:October 09, 2004, 11:55:54 am
« on: November 18, 2003, 09:17:38 pm »
I am in the last stages of wiring my control panel up and have a question in regards to the two green wires that are on a Happ Controls Trackball.
These are supposed to be a ground of some type to stop static from building up.  What should I hook these 2 wires to?
Hopefully this weekend I can finally get it up and running to try it out.
Thanks,
David
aricade
  • Last login:August 15, 2004, 01:38:26 pm
  • Wamma langa ding dong!
    • Isaacade
Re:Happ Controls Trackball Question
« Reply #1 on: November 19, 2003, 10:50:25 pm »
Check out the Atari Missle Command Optical boards  post
http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=13494
follow the green wires of the wiring harness back to the optic boards that the spoked wheels pass through when you roll the TrackBall.
use the links in that post to determine what those green wires actually connect to on the optic boards...
here is another good tb hack site:
http://www.members.shaw.ca/bakaye/tballhack.htm
I am assuming that you are hacking this to mouse?
If so just hook it up to common ground (IF the green wires are GROUND) on your mouse.  I used the common ground of the mouse buttons.  Basically the trace/cricuit that all the mice buttons share...   This worked for me ....
But if you really want to be safe.  Get a 12 foot metal rod from home depot.. Ram it into the ground about 11 ft. Then run a big copper cable from the ground of your track ball harness out the window and to the metal rod.  Your Trackball will be safe during all lightening storms!!!  That'll ground that BABY!!!! This would be known as the tim the toolman approach  :)
Oh and yes, I am a retard just ask my wife!
Off all the things I've lost I miss my mind the most!!
