Author Topic: Joystick Orientation  (Read 1354 times)
Richardgregory
  • Last login:November 17, 2021, 01:15:10 pm
« on: September 11, 2013, 09:52:14 am »
Ok, perhaps this is a dumb question - I"m allowed one here no?
I'm mounting a Mag Stik Plus, and the mounting plate horizontal distance is around 95 mm and 64 mm vertical - I would rather have it mounted (turned 90 deg) clockwise such that the horizontal becomes vertically placed - to save CP space for a trackball placemnet and spinner.
It shouldn't matter if I make this change provided that the joystick wires are respectively wired mapped to reflect their direction.
Okay, shoot me now. :)
  • Last login:December 19, 2025, 12:23:29 pm
Re: Joystick Orientation
« Reply #1 on: September 11, 2013, 10:06:59 am »
Yeah, UP is whatever direction you want UP to be.
This usually only comes up when people ask for a wiring diagram for the Japanese sticks that come with multi-colored harnesses.
BobA
  • What Me Worry?
« Reply #2 on: September 11, 2013, 11:37:30 am »
I always thought that the larger measurement was vertical and the smaller was horizontal.  I have always mounted them this way.
  • Last login:Today at 02:25:46 am
« Reply #3 on: September 11, 2013, 11:52:30 am »
The sticks I've seen with a metal mounting plate that connects to the body of the joystick have a square pattern for the screws holding the plate to the body.
This comes in useful when you want to turn the mount plate 90 degrees for an LS-32-01/LS-32-02 type stick like Badmouth mentioned or a triggerstick like this.
