Author Topic: Only nine modes found from vmmaker and only two work??  (Read 6181 times)
jtslade
  • Last login:February 13, 2025, 10:06:51 pm
  • Keep it looking originallish!
« on: September 07, 2013, 05:54:20 pm »
I have xp 64
Asus m2v mx mobo
Ati HD 2600 pcie card
Going to a Nanao 25" arcade monitor set to 15khz on the jumper..
After installing CRT emu driver 1.2a 64bit and running vmmaker/ then reboot
I edited the ini to point to groovy Mame..
Reboot and I can get 640x 480 and
512x448
Are the only two that work
All others like 320x448 look like the picture attached..
Any help would be greatly appreciated!!
Ms. Pacman Original Cocktail with Non destructive mod to Groovy Arcade Linux with All 4way Vertical Cocktail capable 2 button or less games.
Neo Geo MVS Mame Cab Running Hyperspin, 25" Nanao Arcade Monitor, Mini-pac, ATI Radeon HD 4850 (ATOM-15), IL 8 Way Euro-Sticks from Paradise Arcade, Win XP 64bit, and tons of other junk.
Calamity
  • Moderator
  • Last login:Today at 09:01:21 am
  • Quote me with care
Re: Only nine modes found from vmmaker and only two work??
« Reply #1 on: September 07, 2013, 07:53:50 pm »
Hi jtslade,
1.- Download the latest version of VMMaker (1.3c) from here: http://mame.3feetunder.com/windows-ati-crt-emudriver/
2.- Replace the version in the CRT Emudriver package with this one.
3.- Use the "dotclock_min 8.0" option both in vmmaker.ini and mame.ini
4.- Run VMMaker to recalculate modelines.
(This is because HD 2xxx cards don't support low dotclocks)
Steps to create a log:
jtslade
« Reply #2 on: September 08, 2013, 06:45:07 pm »
Ok so now instead of two working, I have 9 working..
None of the lower 320x200 to 400x300 are working/ split screen rolling
The ones in white work..  Some 512 some 640 and a 664 and a 792 horizontals
Any ideas??
jtslade
« Reply #3 on: September 08, 2013, 06:54:58 pm »
Monitor is a NANAO MS8-26SU Monitor - 26inch
Sledge
  • Last login:August 02, 2025, 01:37:53 am
« Reply #4 on: September 08, 2013, 07:02:30 pm »
For reference, with my 2600pro, I get 79 modelines created I think...
So you must be doing something wrong...
attach your VMMaker.ini
jtslade
« Reply #5 on: September 08, 2013, 08:37:19 pm »
VMMaker.ini::
; VideoModeMaker - Options
; 1. MAME
; Path for Mame executable, in case we want to extract xml information from it.
   MameExe = "E:\Emulators\GroovyMame64\groovymame64.exe"
; Path for Mame ini folder, in case we want to create an ini file for each game.
; Important: existing ini files will be overwritten.
   IniPath = "E:\Emulators\GroovyMame64\ini\"
; Mame options.
   ListFromXML = 1      ; Processes Mame XML and get video mode list from it
   GenerateXML = 1      ; Extracts XML from Mame (only needed once)
   GenerateInis = 0   ; Creates an ini file for each Mame game, in the IniPath folder
   SDLMame = 0      ; Use SDLMame specific options
; Monitor orientation
   MonitorHorizontal = 1   ; 0 = Rotating monitor: horizontal and vertical games at their native resolution
            ;     Suitable for users that physically rotate their CRTs
            ; 1 = Horizontal monitor: horizontal games run at their native resolution and
            ;     vertical games are rotated to fit in horizontal monitor
   RotatingDesktop = 0   ; Specifies if both desktop and monitor are rotated
; Aspect ratio for vertical games on horizontal monitor
;    4:3 (keeps original aspect ratio)
;    3:3 (stretches to square format)
;    3:4 (stretches to full screen)
;   h:v (custom aspect ratio)
   VerticalAspect = "4:3"
; 2. MONITOR
; Monitor Type. Valid types: D9800, D9400, D9200, EGA, VGA, MULTI, H9110, PAL, NTSC, GENERIC, CUSTOM
   MonitorType = "CUSTOM"
; Monitor CUSTOM. These values will be used if MonitorType = "CUSTOM"
; monitor_specs_0-6 = "HfreqMin-HfreqMax, VfreqMin,VfreqMax, HFrontPorch, HSyncPulse, HBackPorch, VfrontPorch, VSyncPulse, VBackPorch, HSyncPol, VSyncPol, ActiveLinesLimit, VirtualLinesLimit"
;    * HfreqMin-HfreqMax: Minimum and maximum horizontal frequency, in Hz. Defines the range of horizontal frequencies the monitor is capable to sync.
;       The higher the horizontal frequency, the higher the vertical resolution available for the same vertical refresh.
;       The higher the horizontal frequency, the higher the vertical refresh available for the same vertical resolution.
;       The higher the horizontal frequency, the lower the horizontal amplitude of active video (narrower picture).
;   * VFreqMin-VfreqMax: Minimum and maximum vertical frequency, in Hz, Defines the range of vertical frequencies the monitor is capable to sync.
;   * HFrontPorch, HSyncPulse, HBackPorch: Horizontal timing and geometry, values in µs
;   * VfrontPorch, VSyncPulse, VBackPorch: Vertical timing and geometry, values in ms
;   * HSyncPol,VSyncPol: polarities, not in use! defaults to negative.
;   * ActiveLinesLimit: Vertical resolutions until ActiveLinesLimit value included, are generated as progressive, regardless the possibility
;                           of obtaining the required vertical refresh value.
;   * VirtualLinesLimit: Vertical resolutions above ActiveLinesLimit and below VirtualLinesLimit are virtualized, that is, an interlaced resolution
;                            bigger that the native one is generated, with the right refresh, and "hardware stretch" is applied.
;                            Vertical resolutions above VirtulaLinesLimit are generated as interlaced, without any stretching.
   monitor_specs_0 = "15625-16200, 49.50-65.00, 2.000, 4.700, 8.000, 0.064, 0.160, 1.056, 0, 0, 288, 448"
; Tolerance for horizontal frequency, in kHz, enables extending the range defined by [ HfreqMin, HfreqMax ]
; The resulting allowed frequency range will be [ HfreqMin - HfreqTolerance, HfreqMax + HfreqTolerance ]
   HfreqTolerance = 0.010
; 3. MODELINE GENERATOR
; Total number of modelines to generate. Here are the recommended values for each driver version:
; CRT_Emudriver, based on Catalyst 6.5 XP32:   160 modes (accepts up to 200, but above 160 HyperSpin will refuse to load)
; CRT_Emudriver, based on Catalyst 6.5 XP64:   120 modes
; CRT_Emudriver, based on Catalyst 9.3 XP32/64:   120 modes (accepts some more but above 120 you can get some blue screens)
; Regular Catalyst:             60 modes (won't accept any more)
   TotalModes = 120
; Method for mode table generation. If Mame xml is processed, that will create a lot of different video modes, so the mode table
; will be optimized keeping the most relevant ones, and dropping the rest, to keep below the TotalModes value.
   ModeTableMethod = 1   ; 0 = Static table: modelines are generated keeping their original vertical refresh. This
            ;     method is intended to be used in combination with ini files for each game.
            ; 1 = Dynamic table: a table of dummy modes is created using xres and yres values while ignoring
            ;     vfreq. This method is intended to be used in combination with Switchres or Groovymame. No ini
            ;     files are required using this method (you should disable the GenerateInis option).
; Minimum resolution values (these will be used instead of lower values)
   XresMin = 184
   YresMin = 192
; Minimum dotclock value allowed by the video card, in MHz (i.e. DotClockMin = 7.010)
   DotClockMin = 8
; Number of iterations used by the mode generator [0,5]. The higher the number of iterations, the bigger the accuracy of the vertical
; refreshed obtained, normally at the cost of increasing the horizontal frequency strictly required.
   Iterations = 0
; Specifies if the refresh label is multiplied by 10 before rounding (experimental).
   VFreqLabelx10 = 0
; 4. DRIVER
; Path for the driver folder
   DriverPath = "E:\Temp\crt_emudriver_9.3_1.2a_x64_multisync\crt_emudriver_9.3_1.2a_x64\Driver"
; If UpdateRegistry is enabled, UpdateDriver will only work if the driver version found in DriverPath matches the one installed
; in the system.
   UpdateRegistry = 1   ; Specifies if the video card registry section will be updated with the new video modes
            ; (will only work in combination with CRT_EMUDriver).
   UpdateDriver = 0   ; Specifies if the driver files in DriverPath will be updated with the new video modes, for
            ; future installations.
   AnyCatalyst = 0      ; Allows modelines to be installed for any Catalyst version. This option is experimental and
            ; known to produce some problems.
MAME.ini::
# CORE CONFIGURATION OPTIONS
readconfig                1
writeconfig               0
# CORE SEARCH PATH OPTIONS
rompath                   roms
hashpath                  hash
samplepath                samples
artpath                   artwork
ctrlrpath                 ctrlr
inipath                   .;ini
fontpath                  .
cheatpath                 cheat
crosshairpath             crosshair
# CORE OUTPUT DIRECTORY OPTIONS
cfg_directory             cfg
nvram_directory           nvram
memcard_directory         memcard
input_directory           inp
state_directory           sta
snapshot_directory        snap
diff_directory            diff
comment_directory         comments
hiscore_directory         hi
# CORE STATE/PLAYBACK OPTIONS
state
autosave                  0
playback
record
mngwrite
aviwrite
wavwrite
snapname                  %g/%i
snapsize                  auto
snapview                  internal
statename                 %g
burnin                    0
# CORE PERFORMANCE OPTIONS
autoframeskip             0
frameskip                 0
seconds_to_run            0
throttle                  1
syncrefresh               0
sleep                     1
speed                     1.0
refreshspeed              0
# CORE ROTATION OPTIONS
rotate                    1
ror                       0
rol                       0
autoror                   0
autorol                   0
flipx                     0
flipy                     0
# CORE ARTWORK OPTIONS
artwork_crop              1
use_backdrops             0
use_overlays              0
use_bezels                0
use_cpanels               0
use_marquees              0
# CORE SCREEN OPTIONS
brightness                1.0
contrast                  1.0
gamma                     1.0
pause_brightness          0.65
effect                    none
# CORE VECTOR OPTIONS
antialias                 1
beam                      1.0
flicker                   0
# CORE SOUND OPTIONS
sound                     1
samplerate                48000
samples                   1
volume                    0
# CORE INPUT OPTIONS
coin_lockout              1
ctrlr
mouse                     0
joystick                  1
lightgun                  0
multikeyboard             0
multimouse                0
steadykey                 0
ui_active                 0
offscreen_reload          0
joystick_map              auto
joystick_deadzone         0.3
joystick_saturation       0.85
natural                   0
joystick_contradictory    0
coin_impulse              0
# CORE INPUT AUTOMATIC ENABLE OPTIONS
paddle_device             keyboard
adstick_device            keyboard
pedal_device              keyboard
dial_device               keyboard
trackball_device          keyboard
lightgun_device           keyboard
positional_device         keyboard
mouse_device              mouse
# CORE DEBUGGING OPTIONS
log                       0
verbose                   0
update_in_pause           0
debug                     0
debugscript
debug_internal            0
# CORE MISC OPTIONS
bios
cheat                     0
skip_gameinfo             0
uifont                    default
ramsize
confirm_quit              0
ui_mouse                  0
autoboot_command
autoboot_delay            2
autoboot_script
# CORE MKChamp OPTIONS
disable_hiscore_patch     0
disable_nagscreen_patch   0
disable_loading_patch     0
# CORE SWITCHRES OPTIONS
modeline                  1
monitor                   arcade_15
orientation               horizontal
connector                 auto
interlace                 1
doublescan                1
cleanstretch              1
changeres                 1
powerstrip                0
lock_system_modes         1
lock_unsupported_modes    1
refresh_dont_care         0
dotclock_min              8.0
sync_refresh_tolerance    2.0
frame_delay               1
lcd_range                 auto
crt_range0                auto
crt_range1                auto
crt_range2                auto
crt_range3                auto
crt_range4                auto
crt_range5                auto
crt_range6                auto
crt_range7                auto
crt_range8                auto
crt_range9                auto
## WINDOWS DEBUGGING OPTIONS
oslog                     0
watchdog                  0
debugger_font             "Lucida Console"
debugger_font_size        9
# WINDOWS PERFORMANCE OPTIONS
priority                  0
multithreading            1
numprocessors             auto
profile                   0
bench                     0
# WINDOWS VIDEO OPTIONS
video                     ddraw
numscreens                1
window                    0
maximize                  1
keepaspect                0
prescale                  1
waitvsync                 0
menu                      0
# DIRECTDRAW-SPECIFIC OPTIONS
hwstretch                 0
# DIRECT3D-SPECIFIC OPTIONS
filter                    0
# DIRECT3D POST-PROCESSING OPTIONS
hlsl_enable               0
hlslpath                  hlsl
hlsl_ini_read             0
hlsl_ini_write            0
hlslini                   %g
hlsl_prescale_x           0
hlsl_prescale_y           0
hlsl_preset               -1
hlsl_write
hlsl_snap_width           2048
hlsl_snap_height          1536
shadow_mask_alpha         0.0
shadow_mask_x_count       320
shadow_mask_y_count       240
shadow_mask_usize         0.09375
shadow_mask_vsize         0.109375
curvature                 0.03
pincushion                0.03
scanline_alpha            1.0
scanline_size             1.0
scanline_height           1.0
scanline_bright_scale     1.0
scanline_bright_offset    0.0
scanline_jitter           0.0
defocus                   0.0,0.0
converge_x                0.3,0.0,-0.3
converge_y                0.0,0.3,-0.3
radial_converge_x         0.0,0.0,0.0
radial_converge_y         0.0,0.0,0.0
red_ratio                 1.0,0.0,0.0
grn_ratio                 0.0,1.0,0.0
blu_ratio                 0.0,0.0,1.0
saturation                1.4
offset                    0.0,0.0,0.0
scale                     0.95,0.95,0.95
power                     0.8,0.8,0.8
floor                     0.05,0.05,0.05
phosphor_life             0.4,0.4,0.4
# NTSC POST-PROCESSING OPTIONS
yiq_enable                0
yiq_cc                    3.59754545
yiq_a                     0.5
yiq_b                     0.5
yiq_o                     0.0
yiq_p                     1.0
yiq_n                     1.0
yiq_y                     6.0
yiq_i                     1.2
yiq_q                     0.6
yiq_scan_time             52.6
yiq_phase_count           2
# VECTOR POST-PROCESSING OPTIONS
vector_length_scale       0.8
vector_length_ratio       500.0
# BLOOM POST-PROCESSING OPTIONS
vector_bloom_scale        0.3
raster_bloom_scale        0.225
bloom_lvl0_weight         1.0
bloom_lvl1_weight         0.21
bloom_lvl2_weight         0.19
bloom_lvl3_weight         0.17
bloom_lvl4_weight         0.15
bloom_lvl5_weight         0.14
bloom_lvl6_weight         0.13
bloom_lvl7_weight         0.12
bloom_lvl8_weight         0.11
bloom_lvl9_weight         0.10
bloom_lvl10_weight        0.09
# PER-WINDOW VIDEO OPTIONS
screen                    auto
aspect                    auto
resolution                auto
view                      auto
screen0                   auto
aspect0                   auto
resolution0               auto
view0                     auto
screen1                   auto
aspect1                   auto
resolution1               auto
view1                     auto
screen2                   auto
aspect2                   auto
resolution2               auto
view2                     auto
screen3                   auto
aspect3                   auto
resolution3               auto
view3                     auto
# FULL SCREEN OPTIONS
triplebuffer              0
switchres                 1
full_screen_brightness    1.0
full_screen_contrast      1.0
full_screen_gamma         1.0
# WINDOWS SOUND OPTIONS
audio_latency             2
# INPUT DEVICE OPTIONS
dual_lightgun             0
Sledge
« Reply #6 on: September 09, 2013, 03:27:58 am »
VMMaker.ini::
not sure if it matters, but mine doesn't have the "  ", so:
monitor_specs_0 = 15625-16200, 49.50-65.00, 2.000, 4.700, 8.000, 0.064, 0.160, 1.056, 0, 0, 288, 448
Calamity
  • Moderator
« Reply #7 on: September 09, 2013, 05:39:50 am »
Hi jtslade,
jtslade
« Reply #8 on: September 09, 2013, 12:36:06 pm »
Maybe I have not got alot sleep but I can't find what I am missing to do. I got the latest version vmmaker 1.3
I'll remote the " " from the custom modeline section of the vmmaker ini file this evening.
Thank you for any help///
Calamity
  • Moderator
« Reply #9 on: September 09, 2013, 01:35:23 pm »
You may have got it but definitely you are not using it, the ini you pasted is outdated, as well as the pics of ArcadeOSD. The new version is required to deal with the new MAME's XML format in order to get the resolutions.
jtslade
« Reply #10 on: September 10, 2013, 06:52:47 pm »
Thank you for the help, I must have been sleepy and copied from an old directory the old crt emu driver and osd files from way back.
Installed with the current vmmaker and now I have about 110 modes.
Any advice on what to do to protect the monitor during boot up (31khz) which shows as a split screen.
What is the common practice?
Sledge
« Reply #11 on: September 11, 2013, 07:24:20 am »
Usually putting it through a J-Pac...(or wait until it's booted to turn on the monitor) how do you connect it currently?
