Author Topic: Confused: Wells Gardner Monitor Id? (Solved)  (Read 3777 times)
rawbe
  • Last login:June 17, 2025, 05:54:46 pm
« on: September 03, 2013, 12:09:49 pm »
Hello-
I recently purchased a 19" Wells Gardner (serial unknown) for a cab I am building. I was told this monitor needed an Isolation Transformer so I purchased one and should have it today or tomorrow. After reading about how to set it up (Bob Roberts http://homearcade.org/BBBB/acwiring.html) I am wondering do I need  all the components in this particular setup? I only need power to my monitor.
I am excited to set this up but scared I will not hook up correctly and damage the monitor!!! Any suggestions?
Robbie
« Last Edit: September 10, 2013, 02:06:17 pm by rawbe »
rawbe
Re: Wells Gardner power setup
« Reply #1 on: September 03, 2013, 01:58:28 pm »
Let me simplify my question.....Is this a safe setup: Monitor>Isolation Transformer>Hacked Computer Power Cable>Power Strip
Robbie
ed12
« Reply #2 on: September 03, 2013, 04:24:48 pm »
it is easy
ANY NON SMPS UNIT SHOULD BE ROUTED TO THE ISO TRANSFORMER
if it has a smps style power supply then u are good to go
the well's need the iso transformer beacause it is called hot to ground
same with normal 2 wire lamps >117vac<.,where as a smps switch mode powersupply,is already isolated by the very nature of its design
u can plug it into the hot >input side< of the iso transformer without
fear of shock,and or blowning up down stream stuff
where the monitor is hot to ground it requires the iso
ed
rawbe
« Reply #3 on: September 03, 2013, 07:41:19 pm »
 Here are some pics of the monitor. Any help on what model the WG is?
« Last Edit: September 04, 2013, 10:07:52 am by rawbe »
rawbe
Re: Confused: Wells Gardner Monitor Id?
« Reply #4 on: September 04, 2013, 02:37:32 pm »
Any help?
« Reply #5 on: September 04, 2013, 02:54:00 pm »
Your pics suck.
grantspain
« Reply #6 on: September 04, 2013, 04:35:20 pm »
looks like a k7000 to me
rawbe
« Reply #7 on: September 04, 2013, 07:22:57 pm »
I hope these give you a better look
grantspain
« Reply #8 on: September 04, 2013, 07:28:04 pm »
yeah like i said a k7000
« Reply #9 on: September 04, 2013, 10:07:10 pm »
What the hell is going on with the signal connector(s)?
Ken Layton
  • Guru
  • Technician
« Reply #10 on: September 05, 2013, 12:32:43 am »
Yeh, what's up with that? Looks like you plugged a computer power supply into the video input connector.
rawbe
« Reply #11 on: September 05, 2013, 07:24:07 am »
Thanks for the reply guys.... I haven't modified this monitor at all. I just bought it off Craigslist. I received my isolation transformer in the mail yesterday and was planning on trying to hook everything up this weekend. Should I be concerned with the setup of this monitor?
rawbe
« Reply #12 on: September 05, 2013, 07:30:20 am »
The cable that is connected to the video input is a modified vga cord. This allows the monitor to be connected to an arcadevga card.
« Reply #13 on: September 05, 2013, 11:20:00 am »
I'm concerned about your VGA breakout cable not having the proper connector on the monitor end. Here's what the connector should look like:
And here's the Molex part numbers:
Connector - 0009507101
Pins - 0008500105
rawbe
« Reply #14 on: September 05, 2013, 01:17:01 pm »
grantspain- Thanks for the info!
Nephasth- I was thinking his homemade cable looked "different" He assured me it was good and he had been using it with no problems. With that being said, I will take your advice and look into making a new one. Could his cable have damage the monitor at all?
Thanks guys!
grantspain
« Reply #15 on: September 06, 2013, 01:13:37 pm »
cable is probably ok,they work or do not-just looks like a lash up
lilshawn
  • Last login:February 20, 2026, 07:25:33 pm
« Reply #16 on: September 07, 2013, 08:09:52 pm »
I think people where more concerned that the connectors from an AT motherboard power supply were going to the video input, and that possibly someone has attempted to power it via said power supply.
don't ask why, we've seen some craaaaazy stuff.  :o
MonMotha
« Reply #17 on: September 07, 2013, 09:27:52 pm »
It's quite possible that they have compatible pin pitch and somebody just hacked up a wiring harness using what they had laying around - an old AT power supply (and probably a boat-load of wire nuts...)
rawbe
« Reply #18 on: September 10, 2013, 02:05:55 pm »
I still haven't had a chance to hook up the monitor.....I have been reading the proper setup for wiring. I wasn't 100% on the proper "grounding" for the monitor. Fingers crossed the previous owner did not try to use this monitor without an isolation transformer.
