Author Topic: S.A.M. - Stand Alone MAME  (Read 36830 times)
  • Last login:Today at 03:26:04 pm
Re: S.A.M. - Stand Alone MAME
« Reply #80 on: September 25, 2013, 08:28:56 pm »
Good thing that Mikey's not facing front.
P2 joystick would be . . . well, you get the idea.
  • Last login:Today at 08:33:03 am
« Reply #81 on: September 27, 2013, 06:40:34 pm »
Good thing that Mikey's not facing front. P2 joystick would be . . . well, you get the idea.
"Hey, Mikey! How's it hangin'?!"
"Umm, to the right!"
Would not be lying.
:D
CoryBee
  • Bopity Boopy
« Reply #82 on: September 27, 2013, 08:13:30 pm »
Would not be lying.
:D
You really have a "hard on" for making innuendos over here. Too bad you aren't dealing with your own "wood" in the CNC Bartop thread.......OOOOOooOOoOOO  :o
« Reply #83 on: September 27, 2013, 08:22:55 pm »
Don't worry. My Wife handles that work. And ... "innuendo". LOL.
  • Last login:September 19, 2025, 01:42:20 am
« Reply #84 on: September 27, 2013, 09:46:51 pm »
It's like a 70s BBC comedy up in here.
Re: Re: S.A.M. - Stand Alone MAME
« Reply #85 on: September 27, 2013, 10:00:02 pm »
Dude. I'm Canadian. We're all "King of Kensington" up in this ---smurfette---.
:D
CoryBee
  • Bopity Boopy
« Reply #86 on: September 27, 2013, 10:34:44 pm »
« Reply #87 on: September 27, 2013, 10:42:15 pm »
CoryBee
  • Bopity Boopy
« Reply #88 on: September 29, 2013, 07:52:21 am »
Gotta show some turtle (yea i know the placement of the joystick is iffy but it isn't noticeable unless you are a perv like Rick  :laugh2: )
Can't forget sleepy Yoshi
« Reply #89 on: September 29, 2013, 07:54:54 am »
Is it just me, or are the rounded edges ... not so rounded? Was this deliberate?
CoryBee
  • Bopity Boopy
« Reply #90 on: September 29, 2013, 08:45:15 am »
You are correct good sir. And no it was not deliberate. Not sure why that happened. I traced the Slag coin template with a circle thingy in Photoshop then did the stroke thing and I don't know how it has the not so rounded effect when you look closely. It isn't noticeable from a distance but it would be nice to fix that.
It is the same thing on all of my art unfortunately, but the white sticks out the most. The others are fine.
« Reply #91 on: September 29, 2013, 09:34:47 am »
It isn't noticeable from a distance but it would be nice to fix that. It is the same thing on all of my art unfortunately, but the white sticks out the most.
While you're fixing that, you can fix that whole "A"/"&" thing too.
;) :D
« Reply #92 on: September 29, 2013, 11:16:27 am »
Great -- Now I'm a perv for warning about iffy joystick placement. :badmood:   ::)    :duckhunt
Martijn
  • Akira!
    • ModMyBox
« Reply #93 on: September 29, 2013, 01:53:12 pm »
Did you do stroke and outerglow with normal settings? because using outerglow will result in those not round shapes.
best you make a 300 dpi image, create the first dot, then copy the whole thing and past it
then stroke it again and copy the whole image , that will give round borders
Monkeyvoodoo
  • Last login:November 16, 2024, 01:36:41 am
  • I swear I can stop at one. Or two.
    • threefoldhorse Custom
« Reply #94 on: September 29, 2013, 04:25:20 pm »
Did you expand your selection circle from the slag coin template? If you expand too far from the original the circle loses it's roundness.
If you make a selection circle and then place snapable guidelines to give you center points, you should be able to create a smooth circle selection at the size you want.
CoryBee
  • Bopity Boopy
« Reply #95 on: September 30, 2013, 11:58:11 am »
I just did the "stroke", no glow. hmmm.....
Did not mess with the circle besides moving it around.
This doesn't seem to be a big issue, I will mess around with it more but as for now I wont be doing any more builds for a while. Trying to knock out the ones I have going on before I make myself feel insignificant for not completing something I started.
CoryBee
  • Bopity Boopy
« Reply #96 on: September 30, 2013, 12:03:37 pm »
Marquee retained  :cheers:
Turned out pretty good and was a pretty simple solution
A view from the underside for the hell of it
Just finished the painting the last coat, not much left to do once it is dried. Just assemble and software  ;D (oh and solder a couple things like the power button and external USB port)
CoryBee
  • Bopity Boopy
« Reply #97 on: October 02, 2013, 09:13:57 am »
SAM is complete. I have been playing this thing on the big screen and I absolutely love it. Will have some pictures of it being played soon.
I had a couple of small issues I had to deal with. Worst of it was after I put together the control panel and started assembling everything I noticed I could not move player one's joystick very much because it was pressed against the laptop hard drive!!  :banghead:
I had to remove all buttons, basically strip down the CP back to bare wood. I then recessed the joysticks enough to barely miss the hard drive this time. All is well now though and S.A.M. is just waiting for a custom MALA theme. Turn the thing on and it kicks into the frontend with a ton of games and console systems. Definitely taking it with me to the UK, might even try selling it there for a bit of cash before my trip back.
« Reply #98 on: October 02, 2013, 10:26:14 am »
Looks great!  :cheers:
« Reply #99 on: October 02, 2013, 11:02:08 am »
Nice job Cory! ...But it reminds me of this:
« Reply #100 on: October 02, 2013, 12:10:50 pm »
OMG, sorry. I couldn't resist.
:D
« Reply #101 on: October 02, 2013, 12:30:08 pm »
I think it's time we stage an intervention for you, Rick.
« Reply #102 on: October 02, 2013, 12:35:29 pm »
Who can take care of the Gimp while Rick's in rehab?   :lol
« Reply #103 on: October 02, 2013, 12:36:26 pm »
I'm sorry, but acronyms always bring out the worst in me. ;)
CoryBee
  • Bopity Boopy
« Reply #104 on: October 02, 2013, 07:26:17 pm »
matt4949
« Reply #105 on: October 02, 2013, 07:37:29 pm »
And rick......
[/quote]
 That is why I always wear an undershirt that says "Hi Chris Hanson, Look Mom I'm on TV!" When I go to meet my interweb dates.
CoryBee
  • Bopity Boopy
« Reply #106 on: October 02, 2013, 09:55:18 pm »
The boot screen
CoryBee
  • Bopity Boopy
« Reply #107 on: October 02, 2013, 09:55:57 pm »
Not sure if I should do a blue and white themed Mala layout or just leave it to the one I have been using lately. Hmmm.....
Monkeyvoodoo
« Reply #108 on: October 02, 2013, 09:59:19 pm »
What about staying with the blue and white but reversing the colours? Blue on white?
CoryBee
  • Bopity Boopy
« Reply #109 on: October 03, 2013, 06:11:56 am »
I like this idea. Will play with it a bit.
Brian74
  • Last login:April 21, 2025, 11:11:53 am
  • Yep... I built that!!
« Reply #110 on: October 03, 2013, 02:38:49 pm »
There is a lot of stroking going on in this thread lol
Sent from my SGH-M919 using Tapatalk 2
« Reply #111 on: October 03, 2013, 02:39:36 pm »
THIS thread?
« Reply #112 on: October 03, 2013, 02:44:04 pm »
THIS thread?
 :duckhunt
CoryBee
  • Bopity Boopy
« Reply #113 on: October 03, 2013, 02:53:45 pm »
What is wrong with a bit of stroking?
rablack97
« Reply #114 on: October 03, 2013, 04:03:33 pm »
i just saw that guy on a VINES marathon...... :laugh2:
CoryBee
  • Bopity Boopy
« Reply #115 on: October 03, 2013, 04:17:07 pm »
HAHAHAHA, ---smurfin--- vines
lcmgadgets
« Reply #116 on: October 07, 2013, 09:54:33 am »
Nice build Corybee.  :applaud:
Professor Hayashida
CoryBee
  • Bopity Boopy
« Reply #117 on: October 07, 2013, 10:30:45 am »
Thanks man, quite a lot of fun playing this thing in front of the big screen. We will see if the brits will be as interested as I am in this thing.
Glad I got it completed cause I have 3 more project to complete in 6 days......
1 full size
1 half size
1 bartop
All in final stages, give or take......
a1pharm
  • Last login:September 15, 2025, 09:38:15 pm
« Reply #118 on: October 07, 2013, 12:34:07 pm »
1 full size
1 half size
1 bartop
I wonder how productive you'll be when your blue crystal runs out...
CoryBee
  • Bopity Boopy
« Reply #119 on: October 07, 2013, 02:58:42 pm »
WHO TOLD YOU MY SECRETS!
Rick! Get back to the basement and get to work!
