Author Topic: Steel tabletop cab  (Read 3453 times)
grumdrig
  • Last login:February 10, 2014, 07:32:35 pm
Steel tabletop cab
« on: August 27, 2013, 03:58:36 pm »
Hi folks! I'm building a tabletop arcade cab in sort of an open clamshell shape out of 16 gauge stainless steel. I haven't worked with metal very much and I'm learning to TIG weld, so I decided to overbuild this for the sake of practice.
This'll be my second cabinet. The first a coworker and I built to go into the lobby of the place we worked, years ago. We put a CRT in a upright MDF cabinet. Much Robotron ensued.
I don't have a good drawing that is amenable to being photographed. All I have is this sketch:
It'll be thinner than that though - only about 2 1/2" deep in both the horizontal and vertical sections.
For this one I'm using a 19" LCD donated by my brother. It's quite heavy. I've removed the casing and here it is with the bezel I welded together sitting on it. It'll be 3/4" thick which is about the minimum I could probably make it.
For brains, there's not much room, and I don't want a fan, so I'll probably use AdvMAME on a Raspberry Pi. It seems to run the games I have in mind reasonably well, mostly. I have a BeagleBone black which I'll probably try out too. Much faster CPU but much slower graphics, so I don't know how that will work.
Here's a mockup of the control panel:
No fighting games buttons. I'm going to keep the games list well-edited. I want just these to start with:
- Defender
- Galaga
- Joust
- Robotron
- Asteroids
I'll leave it there for now and post more details (and hopefully progress) later. Any feedback is very welcome!
Well Fed Games
  • Last login:January 07, 2025, 04:42:47 pm
  • Delicious!
Re: Steel tabletop cab
« Reply #1 on: August 27, 2013, 04:11:26 pm »
Sweet. How do you interface controls to the Pi?
CoryBee
  • Bopity Boopy
« Reply #2 on: August 27, 2013, 04:15:49 pm »
Well Fed Games
  • Delicious!
Steel tabletop cab
« Reply #3 on: August 27, 2013, 04:32:25 pm »
Well done, sir.
grumdrig
« Reply #4 on: August 27, 2013, 04:33:45 pm »
I'm using an I-PAC 2.
CoryBee
  • Bopity Boopy
« Reply #5 on: August 27, 2013, 04:49:38 pm »
grumdrig
« Reply #6 on: August 27, 2013, 05:04:29 pm »
Well played indeed!
Incidentally, I tried various different buttons and I really like the feedback of the old Happ controls best. But they're too deep so I'll be using shallower Gold Leaf buttons.
I also switched from the MagStick to the ServoStick (all this is from Ultimarc) for the same reason. Instead of using the servos, though, I'm planning to put a knob above the joysticks to switch between 4-way and 8-way modes.
  • Last login:May 19, 2025, 11:21:11 am
« Reply #7 on: August 27, 2013, 06:30:31 pm »
Dean Winchester does not approve of your shenanigans.
« Last Edit: August 28, 2013, 11:18:51 am by Rick »
CoryBee
  • Bopity Boopy
« Reply #8 on: August 27, 2013, 10:26:35 pm »
