Author Topic: Calamitys drivers won't install with ArcadeVGA 9200 ???  (Read 2538 times)
pakoman
  • Last login:November 05, 2024, 08:36:26 am
« on: August 20, 2013, 04:55:14 pm »
Hi.
I'm trying to install the drivers with an Arcadevga AGP 9200, in a clean Windows XP corporate installation.
It boots into windows and I install the drivers 6'5 32bits. It detects the arcadevga 9200 and installs, then asks for a system restart.
When restarts, nothing happens, there is no driver at all installed.
What's wrong? I installed the drivers in several setups without trouble, this is the first ArcadeVGA I try and it seems not to work.
Thanks.
Calamity
  • Moderator
  • Last login:Today at 03:21:24 am
  • Quote me with care
Re: Calamitys drivers won't install with ArcadeVGA 9200 ???
« Reply #1 on: August 21, 2013, 06:17:51 am »
This can be a problem with some Windows "distributi0ns".  Before installing CRT Emudriver, make sure to uninstall the default ATI driver by manually removing it from device manager/display devices, booting in safe mode. You will know your  system is ready when you see a yellow exclamation on the devive manager after booting.
Steps to create a log:
pakoman
« Reply #2 on: August 23, 2013, 11:28:56 am »
Thanks.
It helps a lot to fit an extra graphic card, an old PCI one as a primary device in BIOS. Then install the drivers through this card and when it's done remove the PCI card.
Calamity
  • Moderator
« Reply #3 on: August 27, 2013, 02:50:19 pm »
Hi pakoman,
Nice trick, thanks for sharing it.
