Author Topic: WTB: Tron upright Brackets  (Read 813 times)
SORHP
  • Last login:July 14, 2025, 12:28:55 am
« on: August 12, 2013, 11:34:30 pm »
I need everything NOT Circled in orange, please help me find these parts! :)
Thank you!
Ben
Games: Super Punch Out, Fix It Felix Jr, DK, DKjr, DK3, PC10, UMK3, TRON, MS-Pac, Pac, Centipede (2x), Robotron, Galaga, Space Invaders, Street Fighter 2 CE, X-Men vs SF, BuckHunter HD, 2X Custom Vewlix, Custom Nintendo VS 3/4, Atomiswave
Paladin
  • Mmmm llamaburgers!
Re: WTB: Tron upright Brackets
« Reply #1 on: August 13, 2013, 11:25:43 am »
In case you didn't know, the brackets I bordered in blue are light fixtures.
Left side:
The top one is the light that goes behind the curved plexi in front of the control panel, and takes a 'black light blue' bulb.  The middle one is the marquee light, same part was used on Ms. Pac Man, Galaga and most likely other Midway games and uses a cool white bulb.  The bottom one is the translight fixture, this is the hard one to find as it goes behind the monitor in the back of the cabinet and lights up the translight artwork with a cool white bulb.
Right side:
This is the fixture that goes below the control panel and houses a 'black light white' bulb.  The top longer part of the bracket attaches to the plexi piece that is found below the control panel.
I have 3 of the 4 fixtures available, I sold the harder to find translight fixture already. I also have the piece below the fixture on the right, it's attached to the other end of the front plexi piece and supports the front of the control panel.  You would still need the 3rd piece down on the right that supports the back of the control panel and the upper right piece that I can't quite place at the moment.  What I don't see pictured is the small metal piece that the top of the translight artwork is adhered to in the back of the cab, which I also have.  It only has two screw holes in it which doesn't match anything in that photo.
Edit: Looking at a pic on my own website reminded me that there's a small piece of metal that supports the back side of the monitor glass, it might be that piece.  The picture also reminded me that Tron used two types of coin bucket holders.  The one pictured below is wire frame, the other is solid metal.  I have the solid metal one.  The bolt holes should be the same.
« Last Edit: August 13, 2013, 11:50:56 am by Paladin »
SORHP
« Reply #2 on: August 20, 2013, 07:14:03 pm »
Pm sent
