August 15, 2025, 03:47:36 pm
ok so now every time a connect the usb from the j-pac (PC KB/USB) in to my laptop usb for some reason the computer starts tapping q569 q569 q569 and wont stop............. help please
Quote from: Caparo8bit on August 06, 2013, 10:16:48 pmok so now every time a connect the usb from the j-pac (PC KB/USB) in to my laptop usb for some reason the computer starts tapping q569 q569 q569 and wont stop............. help pleaseYou probably have those inputs shorted in your arcade wiring.
Quote from: paigeoliver on August 06, 2013, 11:06:51 pmQuote from: Caparo8bit on August 06, 2013, 10:16:48 pmok so now every time a connect the usb from the j-pac (PC KB/USB) in to my laptop usb for some reason the computer starts tapping q569 q569 q569 and wont stop............. help pleaseYou probably have those inputs shorted in your arcade wiring.That or you have the wires hooked to the Normally Closed (NC) and common (COM) tabs on the microswitch instead of the Normally Open (NO) and COM tabs.Scott
ground cable was on ( NO) and and 2nd cable was on (com)
Thank you. Quote from: Caparo8bit on August 07, 2013, 12:56:23 amground cable was on ( NO) and and 2nd cable was on (com)Looks like you were using part of my "backward" wiring trick.More on a similar, but larger-scale related wiring technique soon. . . . Right, Jon? Scott
Are you sure you want to get rid of the monitor?Instead of a laptop, you can use a cheap PC to get it up and running.BTW, the thread offering the monitor for trade should be in the Buy/Sell/Trade forum.Scott
