Author Topic: I-pac problem  (Read 1100 times)
thefox
  • Last login:November 30, 2021, 05:09:11 am
    • From The Old Arcade
I-pac problem
« on: August 02, 2013, 01:48:04 am »
Another i-pac problem I am hoping someone can help with. I have an i-pac 2 wired via USB. Whenever I switch on my cab, none of the controls work. Then, if I unplug the USB from the i-pac and plug it back in again, everything works fine. I find I have to do this each time I shut down and restart.
Strangely, when I tried disconnecting and reconnecting the USB end of the cable, it didn't seem to help (although I need to re-test this part a few more times to make sure I'm not going mad).
I have checked all my connections and cant see anything crossed or out of place. Any ideas please ?
Born in the early seventies
Grew up in the arcades in the 80's
Built "The Fox-Box" in 2012.
https://fromtheoldarcade.wordpress.com/
  • Last login:Yesterday at 02:46:44 pm
Re: I-pac problem
« Reply #1 on: August 02, 2013, 02:33:19 am »
Not sure what would cause that, but maybe some more info on your setup and configuration might help.   :dunno
- Operating system?
- Steps taken to hide windows?
- Front end program?
- System set to shutdown/standby/hibernate?
