Author Topic: help with soft 15khz  (Read 1490 times)
Caparo8bit
  • Last login:April 28, 2018, 02:13:32 am
  • Hyperspin/Maximus
« on: July 25, 2013, 12:46:19 am »
im testing my emulators on my computer using soft 15khz and i get error msg in all emulators (nes ,snes,64 ) planing to use this set up with a old arcade monitor ..
pc specs ProcessorCeleron 1.06 GHz
Memory256.0 MB
Display Type14.1 in
Graphics ProcessorATI Mobility Radeon M6P
i dont want to use a lcd/led HELP :banghead:
ahofle
    • Arcade Ambience Project
Re: help with soft 15khz
« Reply #1 on: July 25, 2013, 12:59:26 am »
Sounds like a pretty old computer.  The error looks like it's from the emulator, not Soft15khz and is fairly self explanatory...you need to update the version of DirectX you have installed.
Rigby
  • Last login:August 26, 2014, 09:40:59 am
  • I am good at liking video games
« Reply #2 on: July 25, 2013, 01:23:02 am »
Yeah, that error message is REALLY clear about what needs to happen.
Caparo8bit
  • Hyperspin/Maximus
« Reply #3 on: July 25, 2013, 12:46:21 pm »
how come all emu and maximus arcade works on computer when im not usimg soft 15khz ????????????
ahofle
« Reply #4 on: July 26, 2013, 10:35:21 pm »
Well that's a good question.  Have you tried upgrading DirectX to see what happens?  You probably want version 9.
Caparo8bit
  • Hyperspin/Maximus
« Reply #5 on: July 27, 2013, 12:24:55 am »
Naaaahh im done with soft15 i removed arcade monitor and im using led 32" and jPAC now the qstn is how do i connect the speakers to the j-pac my arcade comes with 3 spkrs  . I have a show case 32" deluxe  if that helps
