Author Topic: Continental Circuit -Taito - controls just went on me  (Read 1439 times)
BC_Jeffro
  • Last login:March 09, 2020, 04:55:23 pm
  • you can never leave the game!
« on: July 24, 2013, 12:19:39 am »
hi my CC worked fine westerday  then turnd it on today and had stearing for a couple of seconds then nothing just went crazy on me
 it always turns right with a little spot were you can make it go right slower ?
not sure what happened
any help would be great
thanks
  • Last login:Today at 11:09:41 am
Re: Continental Circuit -Taito - controls just went on me
« Reply #1 on: July 24, 2013, 11:36:54 am »
It sounds like the potentiometer is going bad -- assuming that it is a 270 degree wheel instead of a 360 degree wheel.
If you go into Self-Test mode, you can test the whole steering circuit (labeled "handle") as described on pg. 9 of the Operating Manual.
Not sure of the operating voltage or if it is connected to pin 1 or 3 on the steering potentiometer. :dunno
Test the voltage between pins 1 and 2 or 2 and 3 to see if you get a smooth range of values as you turn the wheel.
Schematics available here, but I didn't notice the steering circuit when I thumbed through it.
You can also unplug the steering panel to test the potentiometer separately from the game board.
See if it gives a smooth range of resistance values as the wheel is turned.
** As always, ensure the potentiometer is unpowered when measuring resistance so you don't fry your meter. **
BC_Jeffro
« Reply #2 on: July 24, 2013, 12:51:55 pm »
thanks ill give it a try
